deu isso
00:00.0 Host bridge: Intel Corporation Mobile 945GSE Express Memory Controller Hub (rev 03)
Subsystem: Acer Incorporated [ALI] Mobile 945GSE Express Memory Controller Hub
Flags: bus master, fast devsel, latency 0
Capabilities:
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GSE Express Integrated Graphics Controller (rev 03) (prog-if 00 [VGA controller])
Subsystem: Acer Incorporated [ALI] Mobile 945GSE Express Integrated Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 56280000 (32-bit, non-prefetchable) [size=512K]
I/O ports at 50f0 [size=8]
Memory at 40000000 (32-bit, prefetchable) [size=256M]
Memory at 56300000 (32-bit, non-prefetchable) [size=256K]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: i915
Kernel modules: i915, intelfb
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
Subsystem: Acer Incorporated [ALI] Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
Memory at 56200000 (32-bit, non-prefetchable) [size=512K]
Capabilities:
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02)
Subsystem: Acer Incorporated [ALI] NM10/ICH7 Family High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at 56340000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: 55100000-561fffff
Prefetchable memory behind bridge: 0000000050000000-0000000050ffffff
Capabilities:
Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: 54100000-550fffff
Prefetchable memory behind bridge: 0000000051000000-0000000051ffffff
Capabilities:
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00001000-00002fff
Memory behind bridge: 53000000-540fffff
Prefetchable memory behind bridge: 0000000052000000-0000000052ffffff
Capabilities:
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Subsystem: Acer Incorporated [ALI] NM10/ICH7 Family USB UHCI Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 50a0 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at 5080 [size=32]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 5060 [size=32]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 5040 [size=32]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
Subsystem: Acer Incorporated [ALI] NM10/ICH7 Family USB2 EHCI Controller
Memory at 56344400 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
Capabilities:
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
Subsystem: Acer Incorporated [ALI] 82801GBM (ICH7-M) LPC Interface Bridge
Capabilities:
Kernel driver in use: lpc_ich
Kernel modules: intel_rng, lpc_ich, leds_ss4200
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02) (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
Subsystem: Acer Incorporated [ALI] 82801G (ICH7 Family) IDE Controller
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at 50c0 [size=16]
Kernel driver in use: ata_piix
Kernel modules: pata_acpi
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7-M Family) SATA Controller [AHCI mode] (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: Acer Incorporated [ALI] 82801GBM/GHM (ICH7-M Family) SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 27
I/O ports at 50d8 [size=8]
I/O ports at 50fc [size=4]
I/O ports at 50d0 [size=8]
I/O ports at 50f8 [size=4]
I/O ports at 5020 [size=16]
Memory at 56344000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 02)
Subsystem: Acer Incorporated [ALI] NM10/ICH7 Family SMBus Controller
Flags: medium devsel, IRQ 11
I/O ports at 5000 [size=32]
Kernel modules: i2c_i801
01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4312 802.11b/g LP-PHY (rev 01)
Subsystem: Foxconn International, Inc. BCM4312 802.11b/g LP-PHY
Physical Slot: 1
Memory at 55100000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: b43-pci-bridge
Kernel modules: ssb
03:00.0 Ethernet controller: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet (rev b0)
Subsystem: Acer Incorporated [ALI] AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 53000000 (64-bit, non-prefetchable) [size=256K]
I/O ports at 1000 [size=128]
Capabilities:
Kernel driver in use: ATL1E
Kernel modules: atl1e
