possuo um Lenovo IdeaPad 3 15ITL6. ocorre que o wifi só conecta quando uso o fedora. Windows 10, 11, ubuntu ou outra distribuição vindo do Debian nada de conectar, embora reconheça o dispositivo e as redes disponíveis. Mistério…
Deve ser driver
Pensei nisso, mas instalando o Windows 10 e 11 nos últimos tempos tudo perfeito.
para ajudar forneca a config do seu note,
olhe esse post:
https://plus.diolinux.com.br/t/como-fornecer-boas-informacoes/38398
nos forneca o conteudo do
inxi -F --filter
System:
Kernel: 6.18.16-200.fc43.x86_64 arch: x86_64 bits: 64
Desktop: GNOME v: 49.4 Distro: Fedora Linux 43 (Workstation Edition)
Machine:
Type: Laptop System: LENOVO product: 82MD v: IdeaPad 3 15ITL6
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0T76466 WIN
serial: Firmware: UEFI vendor: LENOVO v: GGCN61WW
date: 11/28/2024
Battery:
ID-1: BAT0 charge: 38.7 Wh (100%) condition: 38.7/38 Wh (101.9%)
CPU:
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 400 min/max: 400/4200 cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400
Graphics:
Device-1: Intel TigerLake-LP GT2 \[Iris Xe Graphics\] driver: i915 v: kernel
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB
Display: wayland server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
compositor: gnome-shell driver: dri: iris gpu: i915
resolution: 1920x1080\~60Hz
API: OpenGL v: 4.6 vendor: intel mesa v: 25.3.6 renderer: Mesa Intel Iris
Xe Graphics (TGL GT2)
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Info: Tools: api: glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.18.16-200.fc43.x86_64 status: kernel-api
Server-1: PipeWire v: 1.4.10 status: active
Network:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
IF: wlp0s20f3 state: up mac:
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
type: USB
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: bt-v: 5.1
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Drives:
Local Storage: total: 476.95 GiB used: 25.93 GiB (5.4%)
ID-1: /dev/nvme0n1 model: NVMe IM2P33F4 256GB size: 238.47 GiB
ID-2: /dev/sda vendor: XrayDisk model: 256GB SSD size: 238.47 GiB
Partition:
ID-1: / size: 228.12 GiB used: 18.83 GiB (8.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 952.1 MiB used: 19.3 MiB (2.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 233.67 GiB used: 7.07 GiB (3.0%) fs: ext4 dev: /dev/sda1
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: partition size: 4.71 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 16 GiB note: est. available: 15.39 GiB used: 2.94 GiB (19.1%)
Processes: 328 Uptime: 4m Shell: Bash inxi: 3.3.40
Outros sintomas: Samsung A56 em alguns momentos avisa que está sem internet, muito embora conectado no wifi. Iphone 16 normal. Pode ser o roteador. Escolha da Criptografia da senha do wifi?
qual modelo do roteador wifi?
Olá t1t4,
Esse driver iwlwifi teoricamente deveria funcionar sem problemas.
Confere se nas configurações da firmware/bios da placa mãe, se está desativado o fastboot e o security boot.
o fastboot perincipalmente quando ativado pode afetar a detecção de drivers e dispositivos.
EDITADO
A desculpa, agora que entendi ele detecta o wifi…
Reconhece a rede mas não navega, seria isso mesmo?
ou quando vc digita a senha não dá certo?
Não tem misterio o fedora e arch usam kernel mais Novos
e drivers de novos dispositivos são incluindos em novas versões de kernel, se vc quiser que funcione no ubuntu é só ver qual versão do kernel o fedora ta rodando e instalar ou compilar a mesma no ubuntu.
Ontem, 15 de março, windows 11 conectou normalmente. Ubuntu também nada nem windows 11. fedora nem se fala, sempre conecta. Hoje nada. Só o fedora. Atualizei o drive no Windows para última versão e nada.
A observar: já foi tentado resetar roteador, trocar criptografia da senha wifi, IP fixo, vários DNS, 2gzh ou 5ghz. Outros roteadores que testei e usando wifi do telefone para ter acesso a Internet funciona perfeitamente. É algo misterioso no ax12 tp link e que está devidamente atualizado.
Recomendo resetar a configuração do roteador para de fábrica.
E veja se o problema persiste.
Muitas vezes o roteador tem características de configuração não suportadas pelo dispositivo.
Tente tirar elas.
Por exemplo
Beamforming
Roaming rápido
Já fi tudo isso. Nada. Em certos dias o windows 10, 11 e ubuntu conectam e em outros nao. Só o fedora nao possui esse problema
Ok
Cria o arquivo e adicione o conteúdo.
Reinicie o pc e veja se funciona
/etc/modprobe.d/iwlwifi.conf
options iwlwifi 11n_disable=1 swcrypto=1
Se a velocidade ficar baixa
Remova
11n_disable=1
Deixando
options iwlwifi swcrypto=1
Para windows
Se não funcionar, informe
Outro caminho
Bluetooth coexistence
Crie o arquivo e adicione o conteúdo
options iwlwifi bt_coex_active=0
Boa sorte
Bluetooth Coexistence (Coexistência Bluetooth) é uma técnica de gerenciamento que permite que rádios Bluetooth e Wi-Fi operem simultaneamente na mesma banda de 2,4 GHz, sem interferência mútua. Ela coordena o uso do espectro, evitando colisão de pacotes, garantindo que dispositivos funcionem
Tenta fazer o upgrade do kernel para o mais recente possível
Pode também desativar o powersave
/etc/udev/rules.d/81-wifi-powersave.rules
ACTION=="add", SUBSYSTEM=="net", KERNEL=="wl*", RUN+="/usr/bin/iw dev $name set power_save off"
Tem que instalar o iw
Vc tem outros roteadores conectados na casa?
