Comecei a usar o MX Linux a algumas semanas e no início o wifi nunca deu problema; porém, hoje ele começou a apresentar o seguinte problema: após alguns poucos minutos o wifi simplesmente para de funcionar, ele funciona na inicialização mas depois de uns 5 minutos não funciona mais, não conecta na minha rede e nem procura por outras redes.
Vinicius@Vinicius-MX:~
$ inxi -F --filter
System: Kernel: 5.10.0-14-amd64 x86_64 bits: 64 Desktop: Xfce 4.16.0
Distro: MX-21.1_x64 Wildflower April 9 2022
Machine: Type: Laptop System: Positivo Informatica SA product: S14BW01 v: 1.03.I
serial: <filter>
Mobo: Positivo Informatica SA model: S14BW01 serial: <filter>
UEFI: American Megatrends v: 1.03.I date: 08/22/2016
Battery: ID-1: BAT0 charge: N/A condition: N/A
CPU: Info: Dual Core model: Intel Celeron N3010 bits: 64 type: MCP cache: L2: 1024 KiB
Speed: 589 MHz min/max: 480/2240 MHz Core speeds (MHz): 1: 589 2: 678
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated
Graphics
driver: i915 v: kernel
Device-2: Chicony VGA WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.3.5
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High
Definition Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.0-14-amd64 running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi
IF: wlan0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 2.1
Drives: Local Storage: total: 465.76 GiB used: 86 GiB (18.5%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-00VHAT0 size: 465.76 GiB
Partition: ID-1: / size: 58.54 GiB used: 16.99 GiB (29.0%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 252 MiB used: 274 KiB (0.1%) fs: vfat dev: /dev/sda1
ID-3: /home size: 392.74 GiB used: 69.01 GiB (17.6%) fs: ext4 dev: /dev/sda4
Swap: ID-1: swap-1 type: partition size: 5.62 GiB used: 0 KiB (0.0%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 206 Uptime: 53m Memory: 3.7 GiB used: 1.54 GiB (41.6%) Shell: Bash
inxi: 3.3.06
