Wifi 5g nao funciona corretamente
boa tarde, preciso da ajuda de vcs, sou novo no mundo linux, e recentemente tirei o windows 11 do meu note e coloquei o mint ultima versao, ate ai blz, gostei e estava usando de boa, mais reparei o meu 5g nao passa de 30mb, sendo minha net de 700mb, no cabo chega a velocidade contratada.
ai reinstalei o mint e nao deu em nada, coloquei o ubuntu e nada tb,
mas no windows 11 a rede 5g roda normal fica entre 150 a 200 mb.
valeu galera.
Saida dos comandos
lspci -v
lsudb
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Root Complex
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 IOMMU
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Subsystem: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
	Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 3000-3fff [size=4K] [16-bit]
	Memory behind bridge: c0a00000-c0bfffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: c0c00000-c0dfffff [size=2M] [32-bit]
	Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: [disabled] [32-bit]
	Memory behind bridge: c0200000-c03fffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 3
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 2000-2fff [size=4K] [16-bit]
	Memory behind bridge: c0900000-c09fffff [size=1M] [32-bit]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 4
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A (prog-if 00 [Normal decode])
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 1000-1fff [size=4K] [16-bit]
	Memory behind bridge: c0500000-c08fffff [size=4M] [32-bit]
	Prefetchable memory behind bridge: b0000000-c01fffff [size=258M] [32-bit]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B (prog-if 00 [Normal decode])
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
	Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	Memory behind bridge: c0400000-c04fffff [size=1M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
	Subsystem: Acer Incorporated [ALI] FCH SMBus Controller
	Flags: 66MHz, medium devsel, IOMMU group 7
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Subsystem: Acer Incorporated [ALI] FCH LPC Bridge
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 7
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
	Flags: fast devsel, IOMMU group 8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
02:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
	Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
	Flags: bus master, fast devsel, latency 0, IRQ 47, IOMMU group 9
	Memory at c0200000 (64-bit, non-prefetchable) [size=2M]
	Kernel driver in use: ath10k_pci
	Kernel modules: ath10k_pci
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Acer Incorporated [ALI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 10
	I/O ports at 2000 [size=256]
	Memory at c0904000 (64-bit, non-prefetchable) [size=4K]
	Memory at c0900000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4) (prog-if 00 [VGA controller])
	Subsystem: Acer Incorporated [ALI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
	Flags: bus master, fast devsel, latency 0, IRQ 50, IOMMU group 11
	Memory at b0000000 (64-bit, prefetchable) [size=256M]
	Memory at c0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at 1000 [size=256]
	Memory at c0800000 (32-bit, non-prefetchable) [size=512K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
	Subsystem: Acer Incorporated [ALI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 48, IOMMU group 12
	Memory at c08c8000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Subsystem: Acer Incorporated [ALI] Family 17h (Models 10h-1fh) Platform Security Processor
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 12
	Memory at c0700000 (32-bit, non-prefetchable) [size=1M]
	Memory at c08ce000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: ccp
	Kernel modules: ccp
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven2 USB 3.1 (prog-if 30 [XHCI])
	Subsystem: Acer Incorporated [ALI] Raven2 USB 3.1
	Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 12
	Memory at c0600000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
	Subsystem: Acer Incorporated [ALI] ACP/ACP3X/ACP6x Audio Coprocessor
	Flags: bus master, fast devsel, latency 0, IRQ 45, IOMMU group 12
	Memory at c0880000 (32-bit, non-prefetchable) [size=256K]
	Kernel driver in use: snd_pci_acp3x
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
	Subsystem: Acer Incorporated [ALI] Family 17h/19h HD Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 49, IOMMU group 12
	Memory at c08c0000 (32-bit, non-prefetchable) [size=32K]
04:00.7 Non-VGA unclassified device: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
	Subsystem: Acer Incorporated [ALI] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
	Flags: fast devsel, IRQ 32, IOMMU group 12
	Memory at c0500000 (32-bit, non-prefetchable) [size=1M]
	Memory at c08cc000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: i2c_amd_mp2
	Kernel modules: i2c_amd_mp2_pci
05:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61) (prog-if 01 [AHCI 1.0])
	Subsystem: Acer Incorporated [ALI] FCH SATA Controller [AHCI mode]
	Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 13
	Memory at c0400000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: ahci
	Kernel modules: ahci
ubuntu@ubuntu:~$
lsudb
Command 'lsudb' not found, did you mean:
  command 'lsusb' from deb usbutils (1:017-1)
Try: sudo apt install <deb name>
Qual a saĂ­da dos comandos
iplink
iplink addr
Tem certeza que está no 5g?
Veja se não está comectando no 2.4g.
Command 'iplink' not found, did you mean:
  command 'plink' from deb putty-tools (0.79-1)
  command 'gplink' from deb gputils (1.4.0-0.2)
  command 'ilink' from deb fastlink (4.1P-fix100+dfsg-4)
buntu@ubuntu:~$ iplink addr
Entao, obrigado pela ajuda,
estou sim na 5g, porem eu reinstalei o windows 11 por causa da wifi, e estou usando o ubuntu via pendrive agora no caso, porque caso nao consiga resolver o problema talvez fa;a um dual boot.
Foi mal
ip link
ip addr
ubuntu@ubuntu:~$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
    link/ether 70:69:79:a8:54:d0 brd ff:ff:ff:ff:ff:ff
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
    link/ether 94:08:53:36:bb:49 brd ff:ff:ff:ff:ff:ff
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.0.45/24 brd 192.168.0.255 scope global dynamic noprefixroute wlp2s0
       valid_lft 86229sec preferred_lft 86229sec
    inet6 2804:14d:2a91:8168:6e95:17d4:b013:7caf/128 scope global dynamic noprefixroute
       valid_lft 71829sec preferred_lft 71829sec
    inet6 2804:14d:2a91:8168:1906:635c:a39e:c72a/64 scope global temporary dynamic
       valid_lft 86400sec preferred_lft 72000sec
    inet6 2804:14d:2a91:8168:da7c:4e69:9b3:26a8/64 scope global dynamic mngtmpaddr noprefixroute
    inet6 fe80::336b:38a4:bafb:2e9b/64 scope link noprefixroute
Parece tudo normal
Você tem certeza que está no 5g?
No networkmanager trm como escolher manualmente a banda
po tenho sim, as redes tem nomes diferentes, mas eu conecto na rede 5g porem a velocidade dela nĂŁo passa de 30mbps, ai Ă© preferĂ­vel usar a 2.4 porque chega perto dos 50 a 60mbps mais isso no linux, testei em duas distro mint e ubuntu.(errata, testei aqui tanto a rede 2.4 e 5 g estao com a mesma velocidade) 20mbps
no windows a 5g roda liso, uso o windows 11.
vi na net um caras falando em usar kernel mais atualizado, mas nao manjo nada disso.
opa, agora vou mandar a saida dos comandos so que conectado na rede 2.4
buntu@ubuntu:~$ ip addr
       valid_lft 86247sec preferred_lft 86247sec
    inet6 2804:14d:2a91:8168:ce03:dd43:148d:fcdc/128 scope global dynamic noprefixroute
       valid_lft 71846sec preferred_lft 71846sec
    inet6 2804:14d:2a91:8168:6507:14d4:c1e5:d3c5/64 scope global temporary dynamic
       valid_lft 86397sec preferred_lft 71997sec
    inet6 2804:14d:2a91:8168:34aa:421a:2f11:fc2/64 scope global dynamic mngtmpaddr noprefixroute
    inet6 fe80::32f9:a438:2586:ba6f/64 scope link noprefixroute
No Fedora, usando o nmcli (vem instalado) se consegue verificar com o comando:
nmcli -t -f ACTIVE,SSID,FREQ dev wifi
Resulta em algo como:
nĂŁo:CLARO_110B1E:2457 MHz
sim:CLARO_110B1E:5180 MHz
sim = rede ativa.
Bate uns 400MB no wifi no mesmo quarto onde está o roteador, contratado é 600 ~.
Para ver o modelo e driver usado da placa wifi:
lspci -nnk | grep -iA3 "network"
04:00.0 Network controller [0280]: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter [14c3:7961]
Subsystem: Lite-On Communications Inc Device [11ad:3802]
Kernel driver in use: mt7921e
Kernel modules: mt7921e
ubuntu@ubuntu:~$ nmcli -t -f ACTIVE,SSID,FREQ dev wifi
no:Janborg:2412 MHz
no:NISE_2.4G:2437 MHz
no:borg ex:2437 MHz
yes:Janborg-5G:5640 MHz
no::2417 MHz
no:CARLOS:2457 MHz
no:FAMILIA_LIMA:2417 MHz
no::2457 MHz
no:AP_1760415111:2437 MHz
no:CARLOS_EXT:2457 MHz
no:Velociraptor:2462 MHz
buntu@ubuntu:~$ lspci -nnk | grep -iA3 "network"
02:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31)
	Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [11ad:08a6]
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
entao, estou na sala do lado do roteador, e nao passa de 30mbps, mais so no linux no windows bate ate 300, minha net eh de 700.
ele não é o unico com problemas com este wifi qualcom, Mint: Reddit - Dive into anything no arch também… [SOLVED] Qualcomm Atheros QCA9377 not working / Newbie Corner / Arch Linux Forums
alguma dica de como resolver isso?
Problema de 5 anos atrás e ainda continua, então provavelmente ninguém conseguiu resolver ou não quiseram.
Set Active-State Power Management (ASPM) to off at runtime.
Create a grub config backup:
cp /etc/default/grub /etc/default/grub.bak
Open the grub configuration file located in:
/etc/default/grub
Add the “pcie_aspm=off” kernel boot parameter to the the end of the grub load line.
The line you will need to edit will look similar to the line below:
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=e677590f-a8b0-49ad-a6a1-bed005449d2f"
There will be many other entries with btrfs used with Garuda.
Add this parameter at the end of that line:
pcie_aspm=off
The modified grub load line should now look similar to this (there will be many other entries with btrfs):
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=e677590f-YOUR-NUMB-BERS-HEREo449d2f pcie_aspm=off"
After adding the boot parameter and saving your changes, run:
sudo update-grub
Reboot.
Achoq que vocĂŞ nĂŁo leu
Sorry, realmente nĂŁo tinha visto, vou testar aqui obrigado
fiz assim pelo menos foi o que entendi, mas tb nao deu nao.
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
pcie_aspm=off
