Mudei de DISTRO linux há alguns dias (usava ElementaryOS) e estava funcionando perfeitamente. Até que resolvi instalar as atualizações. Depois disso, as portas USB pararam de funcionar. E hoje, milagrosamente, a porta 2.0 voltou a funcionar.
Bem-vindo, Gabriel!
Qual é a sua nova distro?
Pelo perfil dele diz ser o Mint, talvez o 20.2. O X da questão é saber qual a especificação da máquina e o problema que ocorreu.
Desculpe. Mint 20.2, Mate
System:
Kernel: 5.4.0-88-generic x86_64 bits: 64 Desktop: MATE 1.24.0
Distro: Linux Mint 20.2 Uma
Machine:
Type: Laptop System: ASUSTeK product: K45A v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K45A v: 1.0 serial: <filter>
UEFI: American Megatrends v: 221 date: 08/31/2012
Battery:
ID-1: BAT1 charge: 40.3 Wh condition: 40.3/50.8 Wh (79%)
CPU:
Topology: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 1198 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1197
Graphics:
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Display: x11 server: X.Org 1.20.11 driver: modesetting
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.0.3
Audio:
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
Sound Server: ALSA v: k5.4.0-88-generic
Network:
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
IF: wlp3s0 state: up mac: <filter>
Drives:
Local Storage: total: 149.05 GiB used: 23.18 GiB (15.6%)
ID-1: /dev/sda vendor: Samsung model: HM160HI size: 149.05 GiB
Partition:
ID-1: / size: 56.07 GiB used: 21.49 GiB (38.3%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 85.67 GiB used: 1.47 GiB (1.7%) fs: ext4 dev: /dev/sda4
ID-3: swap-1 size: 3.81 GiB used: 220.7 MiB (5.7%) fs: swap dev: /dev/sda2
Sensors:
System Temperatures: cpu: 6280.0 C mobo: 58.0 C
Fan Speeds (RPM): N/A
Info:
Processes: 239 Uptime: 1d 18h 45m Memory: 5.69 GiB used: 2.69 GiB (47.3%)
Shell: bash inxi: 3.0.38
Só a porta 2.0 voltou a funcionar?
O Ubuntu passou por atualização de segurança no kernel esta semana, e isso envolveu os sistemas nele baseados, como o Mint.
Sim. Só a porta 2.0. E foi essa semana que fiz a atualização. Estava funcionando tudo bem. Todas as portas. Depois da atualização o sistema não reconhecia nenhuma. E hoje voltou a funcionar. Mas a 3.0 não.
Meu notebook com o Mint 20.2 está com o USB 3.0 ok.
Será que o problema tem a ver com a seguinte correção no kernel?
Talvez. Mas como faço para reverter? Só essa correção?
Estou monitorando os fóruns. Nas últimas 24h apareceu um usuário do Ubuntu com problema semelhante. O sistema dele reconhece unidades 2.0 nas portas 3.0.
Portas USB que param de funcionar são uma questão relativamente comum entre usuários do Linux Mint. Ver na BIOS a configuração de ativação das portas e adotar um kernel mais recente são propostas de solução frequentes.
Mudar de kernel é um procedimento simples no Mint, pois pode ser feito no Gerenciador de Atualizações, clicando-se em “Ver” e “Kernels Linux”. Estão disponíveis muitas edições do kernel nas versões 5.4, 5.8 e 5.11.
No mais, @Gabriel_Lorenzato, a sua pós-instalação do Mint teve ativação do TimeShift?
Não vi que era tão fácil assim mudar o kernel. Acho que é a minha solução. E tenho o TimeShift ativado sim. Mas estava em dúvida em usa-lo. Tens alguma sugestão do que seria melhor para eu fazer?
Eu verificaria se há imagem do sistema feita pelo TimeShift anterior à última atualização. Mas não a utilizaria para restauração agora. Eu testaria o Mint sob outra versão de kernel, antes.
(Não sou expert em resolver problemas em distros Linux. Mas vi nos fóruns sobre o Mint e o Ubuntu que alguns usuários resolveram o problema de porta USB inativada trocando de kernel.)
Certo, vou restaurar uma versão anterior então. Obrigado
Se você restaurar, numa nova atualização o problema pode se repetir. Eu trocaria de kernel.
consegui fazer somente ontem. Mas não funcionou. USB 3.0 ainda sem funcionar
Já ia perguntar se funcionou. Obrigado pelo retorno!
vou tentar restaurar o sistema hoje.
