comprei um usb 2.0 wireless 802.iin para o meu note com lubuntu
porém não estou sabendo instalar.
alguém pode me ajudar porfavor.
redeme.txt
Software Package - Component
1. ReleaseNotes.pdf
2. document/
2.1 Quick_Start_Guide_for_Driver_Compilation_and_Installation.pdf
2.2 Quick_Start_Guide_for_Station_Mode.pdf
2.3 wpa_cli_with_wpa_supplicant.pdf
2.4 HowTo_support_more_VidPids.pdf
2.5 Wireless_tools_porting_guide.pdf
2.6 HowTo_enable_driver_to_support_WIFI_certification_test.pdf
2.7 HowTo_enable_the_power_saving_functionality.pdf
2.8 Quick_Start_Guide_for_SoftAP.pdf
2.9 SoftAP_Mode_features.pdf
2.10 linux_dhcp_server_notes.txt
2.11 Quick_Start_Guide_for_Bridge.pdf
2.12 RTK_P2P_WFD_Programming_guide.pdf
2.13 HowTo_enable_driver_to_support_80211d.pdf
2.14 Realtek_WiFi_concurrent_mode_Introduction.pdf
3. driver/
3.1 rtl8188EUS_linux_v4.1.4_6773.20130222.tar.gz
Naming rule: rtlCHIPS_linux_vM.N.P_ssss.yyyymmdd.tar.gz
where:
CHIPS: supported chips
M: Major version
N: miNor version
P: Patch number
s: SVN number
y: package year
m: package month
d: package day
4. wpa_supplicant_hostapd/
4.1 wpa_supplicant_hostapd-0.8_rtw_r6747.20130222.tar.gz
4.1.1 wpa_supplicant
The tool help the wlan network to communicate under the
protection of WPAPSK mechanism (WPA/WPA2) and add WPS patch
4.1.2 hostapd
4.2 wpa_0_8.conf
Configure file sample for wpa_supplicant-0.8
4.3 rtl_hostapd_2G.conf
4.4 rtl_hostapd_5G.conf
Configure files for Soft-AP mode 2.4G/5G
4.5 p2p_hostapd.conf
Configure file for hostapd for Wi-Fi Direct (P2P)
4.6 wpa_supplicant_8_jb_4.1_rtw_r6358_20130117.tar.gz
wpa_supplicant_8 from Android 4.1 SDK and patched by Realtek
could be used for pure-linux and Android 4.1. Support only cfg80211/nl80211.
4.7 wpa_supplicant_8_jb_4.2_rtw_r6732.20130207.tar.gz
wpa_supplicant_8 from Android 4.2 SDK and patched by Realtek
could be used for pure-linux and Android 4.2. Support only cfg80211/nl80211.
5. wireless_tools/
5.1 wireless_tools.30.rtl.tar.gz
6. hardware_wps_pbc/
6.1 Readme.txt
6.2 sample.c
7. WiFi_Direct_User_Interface/
7.1 p2p_api_test_linux.c
7.2 p2p_ui_test_linux.c
7.3 p2p_test.h
7.4 Start_Guide_P2P_User_Interface_Linux.pdf
8. android_reference_codes/
8.1 realtek_wifi_SDK_for_android_20111103.tar.gz
This tar ball includes our android wifi reference codes
8.2 realtek_wifi_SDK_for_android.txt
Guide for porting Realtek wifi onto your Android system
9. android_reference_codes_ICS_nl80211/
9.1 realtek_wifi_SDK_for_android_ICS_20120404.tar.gz
This tar ball includes our android wifi reference codes for Android 4.0
9.2 Realtek_Wi-Fi_SDK_for_Android_ICS.pdf
Guide for porting Realtek wifi onto your Android 4.0 system
10. android_ref_codes_JB_4.1
10.1 linux-3.0.42_STATION_INFO_ASSOC_REQ_IES.diff
Kernel patch file for config80211's STATION_INFO_ASSOC_REQ_IES event for kernel 3.0.
10.2 realtek_wifi_SDK_for_android_JB_4.1_20130206.tar.gz
This tar ball includes our android wifi reference codes for Android 4.1
10.3 Realtek_Wi-Fi_SDK_for_Android_JB_4.1.pdf
Guide for porting Realtek wifi onto your Android 4.1 system
11. android_ref_codes_JB_4.2
11.1 linux-3.0.42_STATION_INFO_ASSOC_REQ_IES.diff
11.2 realtek_wifi_SDK_for_android_JB_4.2_20130208.tar.gz
This tar ball includes our android wifi reference codes for Android 4.2
11.3 Realtek_Wi-Fi_SDK_for_Android_JB_4.2.pdf
Guide for porting Realtek wifi onto your Android 4.2 system
12. install.sh
Script to compile and install WiFi driver easily in PC-Linux
13. mp_tools/88_89ENormalMPDoc/NormalSwitchMP_package -20121204.zip
Document, utilities for MP mode.
Could be used for EMI tests such as FCC and ETSI tests.
User Guide for Driver compilation and installation
(*) Please refer to document/Quick_Start_Guide_for_Driver_Compilation_and_Installation.pdf
User Guide for Station mode
(*) Please refer to document/Quick_Start_Guide_for_Station_Mode.pdf
User Guide for Soft-AP mode
(*) Please refer to document/Quick_Start_Guide_for_SoftAP.pdf
(*) Please use wpa_supplicant_hostapd-0.8_rtw_r6747.20130222.tar.gz
(*) Please refer to document/linux_dhcp_server_notes.txt
User Guide for Wi-Fi Direct
Realtek Legacy Wi-Fi Direct:
(*) Please refer to document/RTK_P2P_WFD_Programming_guide.pdf
(*) Please refer to WiFi_Direct_User_Interface/
Wi-Fi Direct with nl80211
(*) Please use:
or
(*) For P2P instruction/command, please refer to:
README-P2P inside the wpa_supplicant folder of the wpa_supplicant_8 you choose
(*) For DHCP server, please refer to:
User Guide for WPS2.0
User Guide for Power Saving Mode
(*) Please refer to document/HowTo_enable_the_power_saving_functionality.pdf
User Guide for Applying Wi-Fi solution onto Andriod System
(*) For Android 1.6 ~ 2.3, Please refer to android_reference_codes/realtek_wifi_SDK_for_android.txt
(*) For Android 4.0, please refer to android_reference_codes_ICS_nl80211/Realtek_Wi-Fi_SDK_for_Android_ICS.pdf
(*) For Android 4.1, please refer to android_ref_codes_JB_4.1/Realtek_Wi-Fi_SDK_for_Android_JB_4.1.pdf
(*) For Android 4.2, please refer to android_ref_codes_JB_4.2/Realtek_Wi-Fi_SDK_for_Android_JB_4.2.pdf
