Tela secundária piscando no Manajaro
Olá, boa tarde. Estou utilizando o Manjaro com dois monitores, porém quando passo o cursor do mouse para o monitor secundário, a tela desse monitor fica piscando. Isso só acontece no momento em que passo o cursor para a outra tela, depois não acontece mais.
Erro3
System:
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 Desktop: GNOME v: 41.4
    Distro: Manjaro Linux
Machine:
  Type: Laptop System: ASUSTeK product: Z550SA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: Z550SA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: Z550SA.303 date: 09/20/2016
Battery:
  ID-1: BAT0 charge: 25.7 Wh (100.0%) condition: 25.7/38.0 Wh (67.7%)
    volts: 7.6 min: 7.6
CPU:
  Info: quad core model: Intel Celeron N3160 bits: 64 type: MCP cache:
    L2: 2 MiB
  Speed (MHz): avg: 791 min/max: 480/2240 cores: 1: 480 2: 480 3: 1601
    4: 605
Graphics:
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
    Integrated Graphics
    driver: i915 v: kernel
  Device-2: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: gpu: i915 resolution: 1: 1920x1080~60Hz
    2: 1360x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 21.3.7
Audio:
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
    High Definition Audio
    driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
  IF: wlp2s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp3s0f2 state: down mac: <filter>
Bluetooth:
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb
  Report: rfkill ID: hci0 state: up address: see --recommends
Drives:
  Local Storage: total: 577.56 GiB used: 206.09 GiB (35.7%)
  ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 120GB size: 111.8 GiB
  ID-2: /dev/sdb type: USB vendor: Western Digital
    model: WD5000LPCX-80VHAT0 size: 465.76 GiB
Partition:
  ID-1: / size: 101.14 GiB used: 16.8 GiB (16.6%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 8.18 GiB used: 2.8 MiB (0.0%)
    dev: /dev/sda3
Sensors:
  System Temperatures: cpu: 6280.4 C mobo: 39.0 C
  Fan Speeds (RPM): cpu: 3100
Info:
  Processes: 238 Uptime: 4h 43m Memory: 3.72 GiB used: 2.3 GiB (61.8%)
  Shell: Zsh inxi: 3.3.14
Qual é a interface gráfica? Wayland ou XOrg? Coloca a config da máquina:
A interface gráfica é o Wayland.
O kernel 5.15 tem esse problema com processadores da Intel, eu tinha presenciado isso no Pop!_OS, é um problema específico do kernel 5.15, sugiro vc usar o kernel 5.13 ou 5.10
No Manjaro o 5.13 é End of Life, não está mais disponível para download no Manjaro Settings. Use o 5.10, que é LTS. E vc ainda não nos disse as informações do teu equipamento, isso é necessário pra poder te ajudar e não apenas dar palpites
Ele inseriu sim as informações no post dele.
Não tinha visto…
Olhei o processador dele aqui, segundo o ark ele aceita 3 monitores, não deveria dar problemas. Contudo, pode ser que esteja usando a resolução incorreta, o segundo monitor reclame de estar em full HD.
O problema acontece ao se usar Xorg?
(Apenas a título de curiosidade - meu processador, apesar de ser um i3, é mais antigo e apenas de 2 núcleos, mas com 4 threads. E isso não acontece, mesmo o segundo monitor não suportando oficialmente 1920x1080 e eu forçá-lo a fazer isso)
Sem problemas
Tenho certeza que é problema específico do kernel 5.15, a minha tela no Pop piscava com esse kernel, eu tenho um I5 de 8ª geração, o kernel 5.15 tem um problema com CPUs da Intel que faz a tela piscar.
Eu uso o mesmo kernel e não, isso não acontece aqui. Cada distro coloca backports diferentes em seus kernels. Ou seja, o 5.15 do Pop não é exatamente o mesmo que o do Manjaro
Vc tem um ponto, mais vale testar um kernel diferente como o 5.10, se não for relacionado ao kernel poderia ser um problema de driver ou alguma outra coisa.
Qual a fonte dessa informação? Dos cinco computadores que tenho aqui, quatro têm processador Intel, e em nenhum deles houve qualquer problema. Atualizei para o 5.16 posteriormente, mas não tive qualquer problema enquanto usei o 5.15.
Por sinal, o kernel 5.15 é LTS.
https://bbs.archlinux.org/viewtopic.php?id=272404
Quanto ao problema específico com processadores da Intel eu não consegui encontrar a fonte, tinha ouvido falar no Reddit mais não consigo achar, o kernel tem um problema que afeta somente CPUs da Intel fazendo com que a tela pisque, é um problema num negócio de sleep alguma coisa.
EDIT: acabei de encontrar a fonte, a resposta tá no primeiro comentário, “You have an Intel processor with integrated graphics? The flickering could be due to kernel version 5.15 not playing nice with CPU sleep states.”
https://jamochl.com/p/linux-intel-screen-flickering-psa/
Entendi, mas como eu faço a alteração para o kernel 5.10 pra ver se é isso mesmo?
Consegui alterar o Kernel para 5.10, mas o problema ainda permanece.
Vc tbm alterou o kernel durante o boot ou só instalou? Pra iniciar com um kernel diferente aperta esc quando aparecer o logotipo da marca, em seguida entra nas opções avançadas e seleciona o kernel 5.10.
Sim, eu fiz isso. Instalei o Kernel e depois selecionei ele no Recovery Mode.
Acho que deve ser algo relacionado a algum drive, sei lá…
Olha, eu já tentei usar outras distribuições como, por exemplo, o Ubuntu, Mint, KDE Neon e Zorin. E o problema da tela ficava até pior nessas outras distros (acredito que elas usem Xorg). Já no Manjaro, reduziu bastante, porém ainda continua.
