Olá Pessoal tudo bem?
Atualmente instalei o Linux mint e ao instalar o davinc o mesmo congela a tela quando faz o carregamento do (LOADING WAVEFORM MONITOR) já tentei instalar novamente mas não resolveu, fiz a instalação de um driver de vídeo anterior mas não resolveu.
Se eu esperar não sai dessa tela, para sair tem que matar a sessão do aplicativo.
Abrindo pelo terminal é apresentando esse log.
$ /opt/resolve/bin/resolve
ActCCMessage Already in Table: Code= c005, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode= 0, Level= 0, CmdKey= 8, Option= 0
PnlMsgActionStringAdapter Already in Table: Code= 615e, Mode= 0, Level= 0, CmdKey= -1, Option= 0
16.1.1 (#005) Linux/Clang
Main thread starts: 04CF6000
[0x7f8c04cf6000] | Undefined | INFO | 2019-11-07 17:54:20,854 | --------------------------------------------------------------------------------
[0x7f8c04cf6000] | Undefined | INFO | 2019-11-07 17:54:20,855 | Loaded log config from /home/daniel/.local/share/DaVinciResolve/configs/log-conf.xml
[0x7f8c04cf6000] | Undefined | INFO | 2019-11-07 17:54:20,855 | --------------------------------------------------------------------------------
Playback/recording through the PulseAudio sound server
Discard all samples (playback) or generate zero samples (capture)
PulseAudio Sound Server
HDA NVidia, HDMI 0HDMI Audio Output
HDA NVidia, HDMI 1HDMI Audio Output
HDA NVidia, HDMI 2HDMI Audio Output
HDA NVidia, HDMI 0Direct sample mixing device
HDA NVidia, HDMI 1Direct sample mixing device
HDA NVidia, HDMI 2Direct sample mixing device
HDA NVidia, HDMI 0Direct sample snooping device
HDA NVidia, HDMI 1Direct sample snooping device
HDA NVidia, HDMI 2Direct sample snooping device
HDA NVidia, HDMI 0Direct hardware device without any conversions
HDA NVidia, HDMI 1Direct hardware device without any conversions
HDA NVidia, HDMI 2Direct hardware device without any conversions
HDA NVidia, HDMI 0Hardware device with all software conversions
HDA NVidia, HDMI 1Hardware device with all software conversions
HDA NVidia, HDMI 2Hardware device with all software conversions
HD-Audio Generic, ALC887-VD AnalogDefault Audio Device
HD-Audio Generic, ALC887-VD AnalogFront speakers
HD-Audio Generic, ALC887-VD Analog2.1 Surround output to Front and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog4.0 Surround output to Front and Rear speakers
HD-Audio Generic, ALC887-VD Analog4.1 Surround output to Front, Rear and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog5.0 Surround output to Front, Center and Rear speakers
HD-Audio Generic, ALC887-VD Analog5.1 Surround output to Front, Center, Rear and Subwoofer speakers
HD-Audio Generic, ALC887-VD Analog7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
HD-Audio Generic, ALC887-VD DigitalIEC958 (S/PDIF) Digital Audio Output
HD-Audio Generic, ALC887-VD AnalogDirect sample mixing device
HD-Audio Generic, ALC887-VD DigitalDirect sample mixing device
HD-Audio Generic, ALC887-VD AnalogDirect sample snooping device
HD-Audio Generic, ALC887-VD DigitalDirect sample snooping device
HD-Audio Generic, ALC887-VD AnalogDirect hardware device without any conversions
HD-Audio Generic, ALC887-VD DigitalDirect hardware device without any conversions
HD-Audio Generic, ALC887-VD AnalogHardware device with all software conversions
HD-Audio Generic, ALC887-VD DigitalHardware device with all software conversions
FusionScript Server [4818] Started
Host ‘Fusion’ [4529] Added
Existe alguma solução para esse problema?
