Ola eu estou com um erro ao iniciar apache2 da esse erro.
Job for apache2.service failed because the control process exited with error code.
See “systemctl status apache2.service” and “journalctl -xe” for details.
Dou o comando journalctl -xe e aparece isso.
jul 30 22:43:02 kali apachectl[3947]: Action ‘start’ failed.
jul 30 22:43:02 kali apachectl[3947]: The Apache error log may have more information.
jul 30 22:43:02 kali systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
– Subject: Unit process exited
– Defined-By: systemd
– Support:
– An ExecStart= process belonging to unit apache2.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 1.
jul 30 22:43:02 kali systemd[1]: apache2.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– Support: debian site
– The unit apache2.service has entered the ‘failed’ state with result ‘exit-code’.
jul 30 22:43:02 kali systemd[1]: Failed to start The Apache HTTP Server.
– Subject: A unidade apache2.service falhou
– Support: Debian -- Support
– A unidade apache2.service falhou.
– O resultado é failed.
jul 30 22:45:01 kali CRON[3958]: pam_unix(cron:session): session opened for user root by (uid=0)
jul 30 22:45:01 kali CRON[3964]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
jul 30 22:45:02 kali CRON[3958]: pam_unix(cron:session): session closed for user root
jul 30 22:45:02 kali sudo[3966]: root : TTY=pts/1 ; PWD=/root ; USER=root ; COMMAND=/etc/init.d/apache2 status
jul 30 22:45:02 kali sudo[3966]: pam_unix(sudo:session): session opened for user root by (uid=0)
jul 30 22:45:07 kali sudo[3966]: pam_unix(sudo:session): session closed for user root
jul 30 22:45:17 kali PackageKit[3290]: daemon quit
jul 30 22:45:17 kali systemd[1]: packagekit.service: Succeeded.
– Subject: Unit succeeded
– The unit packagekit.service has successfully entered the ‘dead’ state.
Como posso resolver?
