Então, estou tendo um problema: quando uso o Parsec, ou o Moonlight, dois softwares focados em streaming de desktop pra jogos, eles não rodam nada bem. Suspeito que seja pelo fato de que ele não está conseguindo pegar qualquer enconding de vídeo, está fazendo pelo Software mesmo, mas não acertei instalar nada que ajudasse a resolver isso. Alguma dica?
Só pra contextualizar:
ele não aparece outra opção além de software, mesma coisa no Moonlight
EDIT:
O log do Moonlight:
00:00:00 - Qt Info: Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
00:00:00 - SDL Info (0): Compiled with SDL 2.29.0
00:00:00 - SDL Info (0): Running with SDL 2.29.0
00:00:00 - Qt Info: Successfully loaded translation for "pt_BR"
00:00:00 - Qt Warning: qrc:/gui/main.qml:13:1: QML ApplicationWindow: ToolTip must be attached to an Item
00:00:00 - Qt Info: Found "gamecontrollerdb.txt" at "/home/gustavo/.cache/Moonlight Game Streaming Project/Moonlight/gamecontrollerdb.txt"
00:00:00 - SDL Info (0): Loaded 320 new gamepad mappings
00:00:00 - SDL Info (0): V-sync disabled
libva info: VA-API version 1.20.0
libva info: Trying to open /usr/local/lib/dri/radeonsi_drv_video.so
libva info: va_openDriver() returns -1
00:00:00 - SDL Info (0): Trying fallback VAAPI driver names
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so
libva info: User environment variable requested driver 'i965'
libva info: Trying to open /usr/local/lib/dri/i965_drv_video.so
libva info: User environment variable requested driver 'radeonsi'
00:00:00 - SDL Info (0): Trying fallback VAAPI driver paths
libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so
libva info: Trying to open /usr/lib64/va/drivers/radeonsi_drv_video.so
libva info: Trying to open /usr/lib/dri/radeonsi_drv_video.so
libva info: Trying to open /usr/lib/va/drivers/radeonsi_drv_video.so
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva info: va_openDriver() returns 0
00:00:00 - SDL Info (0): Initialized VAAPI 1.20
00:00:00 - SDL Info (0): Driver: Mesa Gallium driver 24.0.0-1pop0~1706872735~22.04~0fa430c for AMD Radeon Graphics (radeonsi, renoir, LLVM 15.0.7, DRM 3.57, 6.8.0-76060800daily20240311-generic)
00:00:00 - SDL Warn (0): VAAPI driver is affected by RFI latency bug
00:00:00 - SDL Warn (0): Deprioritizing VAAPI on Gallium driver. Set FORCE_VAAPI=1 to override.
00:00:00 - FFmpeg: [AVHWDeviceContext @ 0x7139280c9900] Successfully created a VDPAU device (G3DVL VDPAU Driver Shared Library version 1.0) on X11 display :0
00:00:00 - SDL Info (0): Driver: G3DVL VDPAU Driver Shared Library version 1.0
00:00:00 - FFmpeg: [AVHWDeviceContext @ 0x713928392a40] Successfully created a VDPAU device (G3DVL VDPAU Driver Shared Library version 1.0) on X11 display :0
00:00:00 - SDL Info (0): Using VDPAU accelerated renderer
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] nal_unit_type: 21(CRA_NUT), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Decoding VPS
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Main 10 profile bitstream
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Decoding SPS
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Decoding VUI
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Decoding PPS
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Format vdpau chosen by get_format().
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Format vdpau requires hwaccel initialisation.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x71392804d380] Unsupported sw format: yuv420p10le
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Failed setup for format vdpau: hwaccel initialisation returned error.
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Format vdpau not usable, retrying get_format() without it.
00:00:01 - FFmpeg: [hevc @ 0x7139282dbe00] Error parsing NAL unit #3.
00:00:01 - SDL Warn (0): Test decode failed (avcodec_send_packet): Operação não permitida
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x71392828b2c0] Cannot load libcuda.so.1
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x71392828b2c0] Could not dynamically load CUDA
00:00:01 - SDL Error (0): av_hwdevice_ctx_create(CUDA) failed: -1
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x71392834d380] Cannot load libcuda.so.1
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x71392834d380] Could not dynamically load CUDA
00:00:01 - SDL Info (0): Initialized VAAPI 1.20
00:00:01 - SDL Info (0): Driver: Mesa Gallium driver 24.0.0-1pop0~1706872735~22.04~0fa430c for AMD Radeon Graphics (radeonsi, renoir, LLVM 15.0.7, DRM 3.57, 6.8.0-76060800daily20240311-generic)
00:00:01 - SDL Warn (0): VAAPI driver is affected by RFI latency bug
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x3231564e -> nv12.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x30313050 -> p010le.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x36313050 -> unknown.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x30323449 -> yuv420p.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x32315659 -> yuv420p.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x56595559 -> unknown.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x32595559 -> yuyv422.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x59565955 -> uyvy422.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x30303859 -> gray.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x50343434 -> yuv444p.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x50424752 -> unknown.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x41524742 -> bgra.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x41424752 -> rgba.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x42475241 -> argb.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x58524742 -> bgr0.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Format 0x58424752 -> rgb0.
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] VAAPI driver: Mesa Gallium driver 24.0.0-1pop0~1706872735~22.04~0fa430c for AMD Radeon Graphics (radeonsi, renoir, LLVM 15.0.7, DRM 3.57, 6.8.0-76060800daily20240311-generic).
00:00:01 - FFmpeg: [AVHWDeviceContext @ 0x713928056d80] Driver not found in known nonstandard list, using standard behaviour.
00:00:01 - SDL Info (0): Selected overlay subpicture format: BGRA8888
00:00:01 - SDL Info (0): VAAPI driver supports exporting DRM PRIME surface handles with composed layers
00:00:01 - SDL Info (0): Color buffer is: R8G8B8A0
00:00:01 - SDL Info (0): Exporting composed layers with format and modifier: 30313050 0000000000000000
00:00:01 - SDL Info (0): EGL passed preflight checks. Using EGL for GL context creation.
00:00:01 - SDL Info (0): Using VAAPI accelerated renderer on x11
00:00:01 - FFmpeg: [hevc @ 0x713929158240] nal_unit_type: 32(VPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x713929158240] nal_unit_type: 33(SPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x713929158240] nal_unit_type: 34(PPS), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x713929158240] nal_unit_type: 21(CRA_NUT), nuh_layer_id: 0, temporal_id: 0
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decoding VPS
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Main 10 profile bitstream
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decoding SPS
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decoding VUI
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decoding PPS
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Format vaapi chosen by get_format().
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Format vaapi requires hwaccel initialisation.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Considering format 0x3231564e -> nv12.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Considering format 0x30313050 -> p010le.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Ignoring unknown format 0x36313050.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Picked p010le (0x30313050) as best match for yuv420p10le.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x1.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Direct mapping possible.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x2.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x3.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x4.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x5.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x6.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x7.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x8.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x9.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xa.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xb.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xc.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xd.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xe.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0xf.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x10.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x11.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x12.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x13.
00:00:01 - FFmpeg: [AVHWFramesContext @ 0x713929155000] Created surface 0x14.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decode context initialised: 0x15/0x16.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Output frame with POC 3.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Param buffer (type 0, 604 bytes) is 0x17.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 0 param buffer (264 bytes) is 0x18.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 0 data buffer (77 bytes) is 0x19.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 1 param buffer (264 bytes) is 0x1a.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 1 data buffer (87 bytes) is 0x1b.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 2 param buffer (264 bytes) is 0x1c.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 2 data buffer (96 bytes) is 0x1d.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 3 param buffer (264 bytes) is 0x1e.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Slice 3 data buffer (77 bytes) is 0x1f.
00:00:01 - FFmpeg: [hevc @ 0x713929158240] Decode to surface 0x14.
00:00:01 - SDL Info (0): FFmpeg-based video decoder chosen
00:00:01 - Qt Info: Found "gamecontrollerdb.txt" at "/home/gustavo/.cache/Moonlight Game Streaming Project/Moonlight/gamecontrollerdb.txt"
00:00:01 - SDL Info (0): Loaded 320 new gamepad mappings
00:00:01 - Qt Debug: Current Moonlight version: "5.0.1"
00:00:01 - Qt Info: Gamepad mappings are up to date
00:00:01 - Qt Info: Latest supported GFE server: "99.99.99.99"
00:00:01 - Qt Debug: Found update manifest match for current platform
00:00:01 - Qt Debug: Latest version of Moonlight for this platform is: "5.0.1"
00:00:01 - Qt Debug: Update manifest version equal to current version
