Problemas com o ttyUSB, não aparece o script
dae, galera eu estou com problemas com a porta ttyUSB e ttyACM como visto na imagem
estou tentando compilar com o make para o esp8266 mas este erro aparece e se relaciona a não exitencia da porta:
Toolchain path: /home/miguel/esp/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc
Toolchain version: esp-2020r3-49-gd5524c1
Compiler version: 8.4.0
Python requirements from /home/miguel/esp/ESP8266_RTOS_SDK/requirements.txt are satisfied.
Project is not inside a git repository, or git repository has no commits
will not use 'git describe' to determine PROJECT_VER.
App "ex0_esqueleto" version: 1
Flashing binaries to serial port /dev/ttyUSB0 (app at offset 0x10000)...
esptool.py v2.4.0
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 322, in open
    self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyUSB0'
During handling of the above exception, another exception occurred:
  File "/home/miguel/esp/ESP8266_RTOS_SDK/components/esptool_py/esptool/esptool.py", line 3034, in <module>
    _main()
  File "/home/miguel/esp/ESP8266_RTOS_SDK/components/esptool_py/esptool/esptool.py", line 3027, in _main
    main()
  File "/home/miguel/esp/ESP8266_RTOS_SDK/components/esptool_py/esptool/esptool.py", line 2735, in main
    esp = chip_class(args.port, initial_baud, args.trace)
  File "/home/miguel/esp/ESP8266_RTOS_SDK/components/esptool_py/esptool/esptool.py", line 212, in __init__
    self._port = serial.serial_for_url(port)
  File "/usr/lib/python3/dist-packages/serial/__init__.py", line 90, in serial_for_url
    instance.open()
  File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 325, in open
    raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
make: *** [/home/miguel/esp/ESP8266_RTOS_SDK/components/esptool_py/Makefile.projbuild:76: flash] Erro 1
eu queria saber como se resolver esta situação eu estou usando o sistema linux-mint 21.1
v s ajuda: Porta serial no Linux: Habilitar e permitir • Do bit Ao Byte
