Problema esquisito ao instalar o Pulse Efects
Eu tentei instalar o famoso Software de mixagem de áudio no meu PopOS(?)
Mas não consigo :(
Alguém aí já teve esse problema ou sabe como resolver?
Eis minhas especificações
System:
  Kernel: 5.17.5-76051705-generic x86_64 bits: 64 Desktop: GNOME 42.1
    Distro: Pop!_OS 22.04 LTS
Machine:
  Type: Desktop System: Dell product: OptiPlex 7010 v: 01
    serial: <superuser required>
  Mobo: Dell model: 0773VG v: A00 serial: <superuser required> BIOS: Dell
    v: A05 date: 07/31/2012
CPU:
  Info: quad core model: Intel Core i5-3570 bits: 64 type: MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 3377 min/max: 1600/3800 cores: 1: 3593 2: 3649 3: 3590
    4: 2679
Graphics:
  Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] driver: nvidia v: 510.73.05
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution:
    1: 1600x900~60Hz 2: 1920x1080~60Hz
  OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 510.73.05
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
  Device-3: Generalplus USB Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.17.5-76051705-generic running: yes
  Sound Server-2: PipeWire v: 0.3.51 running: yes
Network:
  Device-1: Intel 82579LM Gigabit Network driver: e1000e
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 1.02 TiB used: 158.55 GiB (15.2%)
  ID-1: /dev/sda model: SATA SSD size: 111.79 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD5000AZLX-60K2TA0
  ID-3: /dev/sdc vendor: Hitachi model: HDP725050GLA360 size: 465.76 GiB
Partition:
  ID-1: / size: 40.84 GiB used: 22.14 GiB (54.2%) fs: ext4 dev: /dev/sda4
  ID-2: /home size: 453.44 GiB used: 136.41 GiB (30.1%) fs: ext4
    dev: /dev/sdc1
Swap:
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) dev: /dev/dm-0
Sensors:
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 38 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Info:
  Processes: 303 Uptime: 21m Memory: 13.61 GiB used: 4.63 GiB (34.0%)
  Shell: Bash inxi: 3.3.13
Se não estiver enganado, a partir da versão 22.04 o Pop, utiliza o Pipewire como servidor de áudio o qual o mesmo entra em conflito com o usado anteriormente, no caso o Pulseaudio, portanto utilize o EasyEffects ao inves do PulseEffects.
Além de agora ser EasyEffects, foca no Pipewire no roteamento de som (é compatível com Ubuntu 22+) fastoslinux.com - This website is for sale! - fastoslinux Resources and Information.
PulseEffects → PulseAudio
EasyEffects → Pipewire
