Problema com repositório ao usar o termux no android
Olá a todos, eu recentemente estou usando o terminal do Android, o Termux, estou baixando alguns arquivos q diz q dá pra baixar, vou ir direto ao ponto, isso é oq mostra qnd tento baixar um desses arquivos
~ $ pkg install xorg-xwininfo
Checking availability of current mirror: ok
Hit:1 https://termux.mentality.rip/termux-main stable InRelease
Hit:2 https://packages.termux.org/apt/termux-games games InRelease
Hit:3 https://packages.termux.org/apt/termux-science science InRelease
Hit:4 https://packages.termux.org/apt/termux-x11 x11 InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 xournal : Depends: poppler but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
~ $ apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
  poppler
The following NEW packages will be installed:
  poppler
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
Need to get 0 B/948 kB of archives.
After this operation, 4686 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 36889 files and directories currently installed.)
Preparing to unpack .../poppler_21.08.0_arm.deb ...
Unpacking poppler (21.08.0) ...
dpkg: error processing archive /data/data/com.termux/cache/apt/archives/poppler_21.08.0_arm.deb (--unpack):
 trying to overwrite '/data/data/com.termux/files/usr/bin/pdftohtml', which is also in package xpdf 4.03-2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /data/data/com.termux/files/usr/bin/dpkg returned an error code (1)
Obs:
Essas são as informações do meu celular:
  • É um j400M, j4lte ou j4 2018
  • Android 10
  • 4 cores
  • 4Gb RAM
  • 16Gb armazenamento
É um conflito de arquivos com o pacote citado (xpdf). Não há muito o que fazer salvo atualizar e tentar de novo esperando que o conflito tenha sido corrigido, ou remover um dos pacotes.
Antes msm de ver sua msg eu removi o tal do xournal e consegui instalar outros arquivos, obrg pela ajuda, até.
