Problema com o wi-fi muito lento
Comecei a usar o linux recentemente estou usando a distro ubuntu mate 22.04. e estou com problema, reparei que o wi-fi está ficando muito lento não alcança nem metade da velocidade que alcançava quando usava o Windows, e às vezes até para de funcionar aí eu tenho que desconectar e conectar de novo para a internet e voltar a funcionar.
O que posso fazer para resolver isso?
    System:
  Kernel: 5.15.0-52-generic x86_64 bits: 64 Desktop: MATE 1.26.0
    Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
Machine:
  Type: Laptop System: Positivo Informatica SA product: C14CU51 v: 2.01.U_POS
    serial: <superuser required>
  Mobo: Positivo Informatica SA model: C14CU51 v: POSITIVO
    serial: <superuser required> UEFI: American Megatrends v: 2.01.U
    date: 10/28/2013
CPU:
  Info: dual core model: Intel Celeron 1007U bits: 64 type: MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 798 min/max: 800/1500 cores: 1: 798 2: 798
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
  Device-2: Acer HD Webcam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 2500 (IVB GT1)
    v: 4.2 Mesa 22.0.5
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-52-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
  IF: wlp1s0 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp2s0f2 state: down mac: <filter>
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
    driver: btusb
  Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 1.2
Drives:
  Local Storage: total: 301.88 GiB used: 93.76 GiB (31.1%)
  ID-1: /dev/sda vendor: Seagate model: ST320LM001 HN-M320MBB
  ID-2: /dev/sdb type: USB vendor: Toshiba model: USB Flash Memory
Partition:
  ID-1: / size: 48.07 GiB used: 15.9 GiB (33.1%) fs: ext4 dev: /dev/sda7
  ID-2: /boot/efi size: 96 MiB used: 34 MiB (35.4%) fs: vfat dev: /dev/sda1
  ID-3: /home size: 91.82 GiB used: 75.58 GiB (82.3%) fs: ext4
    dev: /dev/sda8
Swap:
  ID-1: swap-1 type: partition size: 4.77 GiB used: 0 KiB (0.0%)
    dev: /dev/sda6
Sensors:
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 193 Uptime: 12m Memory: 3.72 GiB used: 896.4 MiB (23.5%)
  Shell: Zsh inxi: 3.3.13
Bem vindo ao fórum @Noir!
Acredito que não tenha instalado manualmente o drive da sua placa, com isso está usando o drive fornecido pelo kernel da sua distribuição, o que nos leva a duas conclusões: o kernel em uso não é compatível 100% com sua placa, sendo necessário trocar ou, dependendo da placa, uma instalação manual do drive pode corrigir.
Para sabermos qual pode ser a melhor saída, siga esse outro tópico para nos passar algumas informações:
