Ao desconectar o carregador do laptop o mesmo não funciona o Bluetooth e as portas USB 2.0 3.0, não encontrei solução por meio do site oficial.
Modelo da máquina:
Laptop ACER A315-42G-R5Z7 AMD
CPU: AMD Ryzen 5 3500U with Radeon V
GPU: AMD ATI Radeon Vega Series / Radeon
GPU: AMD ATI Radeon RX 540X
Logs que parecem suspeitos:
ML_OPERAND_VALUE) (20210730/psparse-531)
[ 32.262201] usb 3-1: hub failed to enable device, error -108
[ 32.390117] usb 3-1: hub failed to enable device, error -108
[ 32.946128] usb 3-1: device not accepting address 2, error -108
[ 33.498720] usb 3-1: device not accepting address 2, error -108
[ 34.006793] usb 1-4: hub failed to enable device, error -108
[ 34.134688] usb 1-4: hub failed to enable device, error -108
[ 34.678751] usb 1-4: device not accepting address 3, error -108
[ 35.226103] usb 1-4: device not accepting address 3, error -108
[ 914.667070] xhci_hcd 0000:05:00.4: xHC error in resume, USBSTS 0x411, Reinit
[ 33.734083] Bluetooth: hci0: command 0x0408 tx timeout
[ 33.734094] Bluetooth: hci0: Multiple cmd timeouts seen. Resetting usb device.
[ 33.734131] Bluetooth: hci0: sending frame failed (-19)
