Olá, meu celular é a52s
Sempre quando uso o comando pkg update ou upgrade aparece esse erro:
Checking availability of current mirror: ok
Get:1 packages.termux.dev/apt/termux-main stable InRelease [14.0 kB]
Get:2 packages.termux.dev/apt/termux-main stable/main aarch64 Packages [428 kB]
Err:2 packages.termux.dev/apt/termux-main stable/main aarch64 Packages
Writing more data than expected (428066 > 427722)
Hashes of expected file:
- Filesize:427722 [weak]
- SHA512:663437ccbcc507ef492491b425d946ac4f7c460c9ceb341a0ea35cb4f220b8ddc4d6453176b3936dd248f2f1737e0a15954871c203fa8d37c65df847f9e9e9fc
- SHA256:8669e4aa9365a191946ab4b5bce6f28dcec4a30d8d4db40de15b54fb6039d2c5
- SHA1:12846940ccd633a6042e4c8ab367b5a84448b260 [weak]
- MD5Sum:eb831dffcf8d2f85e386d4ca070bc766 [weak]
Release file created at: Fri, 08 Jul 2022 18:22:00 +0000
Fetched 14.0 kB in 4s (2988 B/s)
Reading package lists… Done
E: Failed to fetch packages.termux.dev/apt/termux-main/dists/stable/main/binary-aarch64/Packages.bz2 Writing more data than expected (428066 > 427722)
E: Some index files failed to download. They have been ignored, or old ones used instead.
Alguem me ajuda!!!
