Nao consigo instalar nada, que da este erro de linux headers
Por favor alguem me ajude, estou tentando baixar/atualizar qualquer coisa, mas sempre da o mesmo erro.
terminal:
configurando linux-headers-6.8.0-79-generic (6.8.0-79.79) ...
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 6.8.0-79-generic
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/rtl8188fu/1.0.2/source/dkms.con
f)
f)
f)
Deprecated feature: REMAKE_INITRD (/etc/dkms/framework.conf)
Sign command: /usr/bin/kmodsign
Binary update-secureboot-policy not found, modules won't be signed
applying patch buildfix_kernel_5.13_armhf.patch...patching file common/inc/nv-li
nux.h
patching file nvidia-drm/nvidia-drm-linux.c
Hunk #1 succeeded at 85 (offset 10 lines).
patching file nvidia-modeset/nvidia-modeset-linux.c
applying patch buildfix_kernel_6.2.patch...patching file nvidia-drm/nvidia-drm-c
onnector.c
patching file nvidia-drm/nvidia-drm-drv.c
Hunk #2 succeeded at 240 with fuzz 2 (offset -1 lines).
patching file nvidia/nv-acpi.c
Hunk #1 succeeded at 8 with fuzz 1.
Hunk #2 succeeded at 24 (offset -1 lines).
Hunk #3 succeeded at 77 with fuzz 1 (offset -7 lines).
Hunk #4 succeeded at 338 (offset -11 lines).
Hunk #5 succeeded at 395 with fuzz 1 (offset -11 lines).
Building module:
Cleaning build area...
unset ARCH; [ ! -h /usr/bin/cc ] && export CC=/usr/bin/gcc; env NV_VERBOSE=1 'ma
ke' -j16 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=6.8.0-79-generic IGNORE_XEN_PR
ESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/6.8.0-79-generic/build LD=/usr
/bin/ld.bfd CONFIG_X86_KERNEL_IBT= modules....(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.8.0-79-generic (x86_64)
Consult /var/lib/dkms/nvidia/390.157/build/make.log for more information.
f)
Building module:
'make' all KVER=6.8.0-79-generic...(bad exit status: 2)
Consult /var/lib/dkms/rtl8188fu/1.0.2/build/make.log for more information.
dkms autoinstall on 6.8.0-79-generic/x86_64 succeeded for virtualbox
dkms autoinstall on 6.8.0-79-generic/x86_64 failed for nvidia(10) rtl8188fu(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
 * dkms: autoinstall for kernel 6.8.0-79-generic
   ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: erro ao processar o pacote linux-headers-6.8.0-79-generic (--configure):
 o subprocesso instalado, do pacote linux-headers-6.8.0-79-generic, o script pos
t-installation retornou erro do status de saída 11
dpkg: problemas com dependências impedem a configuração de linux-headers-generic
 linux-headers-generic depende de linux-headers-6.8.0-79-generic; porém:
  Pacote linux-headers-6.8.0-79-generic não está configurado ainda.
dpkg: erro ao processar o pacote linux-headers-generic (--configure):
 problemas de dependência - deixando desconfigurado
dpkg: problemas com dependências impedem a configuração de linux-generic:
 linux-generic depende de linux-headers-generic (= 6.8.0-79.79); porém:
  Pacote linux-headers-generic não está configurado ainda.
dpkg: erro ao processar o pacote linux-generic (--configure):
 linux-generic
E: Sub-process /usr/bin/dpkg returned an error code (1)
Qual distro?
sudo apt install shim-signed
vc precisa compilar o driver rtl8188fu? se não, pode desinstalar o dkms e headers s não precisar deles para compilar mais nada
Linux mint
Obrigado, consegui de novo
