Meu projeto Redux usa Redux-Thunk para trabalhar com uma API, não renderiza o elemento Header.js como deveria, vou mostrar os arquivos (são MUITO curtos). Não vou perder tempo mostrando a store e o App.js porque tenho certeza que está configurado corretamente. (mas se quiser eu compartilho)
Redux > actions:
export const FETCH_CHARACTERS_BEGIN = 'FETCH_CHARACTERS_BEGIN';
export const FETCH_CHARACTERS_SUCCESS = 'FETCH_CHARACTERS_SUCCESS';
export const FETCH_CHARACTERS_FAILURE = 'FETCH_CHARACTERS_FAILURE';
export const actionFetchCharactersBegin = () => ({
type: FETCH_CHARACTERS_BEGIN,
export const actionFetchCharactersSucess = (characters) => ({
type: FETCH_CHARACTERS_SUCCESS,
payload: characters,
export const actionFetchCharactersFailure = (error) => ({
type: FETCH_CHARACTERS_FAILURE,
payload: error,
const API = 'https://rickandmortyapi.com/api/character';
export function fetchCharacters() {
return async (dispatch) => {
dispatch(actionFetchCharactersBegin());
try {
const response = await fetch(API);
const { results } = await response.json();
dispatch(actionFetchCharactersSucess(results));
return results;
} catch (error) {
dispatch(actionFetchCharactersFailure(error));
redux > reducers:
import {
} from '../actions';
const initialState = {
characters: [],
loading: false,
error: null
export default function characterReducer(state = initialState, action) {
switch (action.type) {
case FETCH_CHARACTERS_BEGIN:
return {
...state,
loading: true,
error: null
case FETCH_CHARACTERS_SUCCESS:
return {
...state,
loading: false,
characters: [...state.characters, action.payload]
case FETCH_CHARACTERS_FAILURE:
return {
...state,
loading: false,
error: action.payload,
characters: []
default:
return state;
components > Header.js:
import React, { useEffect } from 'react';
import { useSelector, useDispatch } from 'react-redux';
import { fetchCharacters } from '../redux/actions';
import './Header.css'
function Header() {
const characters = useSelector(state => state.characters);
const loading = useSelector(state => state.loading);
const error = useSelector(state => state.error);
const dispatch = useDispatch();
useEffect(() => {
dispatch(fetchCharacters())
}, [dispatch]);
if (loading) {
return <div>Loading...</div>
if (error) {
return <div>{error.message}</div>
return (
<div className='container-header'>
<div className='header'>
<div className='header_logo'>
<div className='logo_text'>
<h3>Rick And Morty Character's</h3>
</div>
</div>
<h1>Characters</h1>
<ul>
{characters.map(character => (
<li key={character.id}>
{character.name} ({character.status})
</li>
</ul>
</div>
</div>
export default Header;
