Bom dia senhores, desde a chegada do Kernel 6.14 meu PC tem demonstrado instabilidades, como por exemplo: Após logar a tela ficar escura, PC desligando sozinho e agora com versões mais atualizadas desse kernel como 6.14.4-300 o PC nem vai pro login, exibe as seguintes mensagens:
error: ../../grub-core/fs/fshelp.c:257:file /initramfs-6.14.4-300.fc42.x86_64.img not found
e após isso KERNEL PANIC! VFS: Unable to mount root fs on unknown-block(0,0)
Como proceder?
System:
Kernel: 6.14.2-300.fc42.x86_64 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.3.4 Distro: Fedora Linux 42 (KDE Plasma Desktop
Edition)
Machine:
Type: Desktop Mobo: Gigabyte model: B550M AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F20a
date: 04/11/2024
CPU:
Info: 6-core model: AMD Ryzen 5 5600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 3551 min/max: 550/4470 cores: 1: 3551 2: 3551 3: 3551
4: 3551 5: 3551 6: 3551 7: 3551 8: 3551 9: 3551 10: 3551 11: 3551 12: 3551
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] driver: amdgpu v: kernel
Display: wayland server: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: gpu: amdgpu resolution: 1: 1920x1080~144Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4 renderer: AMD
Radeon RX 6750 XT (radeonsi navi22 LLVM 20.1.2 DRM 3.61
6.14.2-300.fc42.x86_64)
API: Vulkan v: 1.4.309 drivers: radv,llvmpipe surfaces: xcb,xlib,wayland
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
API: ALSA v: k6.14.2-300.fc42.x86_64 status: kernel-api
Server-1: PipeWire v: 1.4.2 status: active
Network:
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 1.82 TiB used: 487.59 GiB (26.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 1TB
ID-2: /dev/nvme1n1 vendor: Western Digital model: WD Green SN350 1TB 2G0C
Partition:
ID-1: / size: 929.93 GiB used: 487.15 GiB (52.4%) fs: btrfs
dev: /dev/nvme1n1p3
ID-2: /boot size: 973.4 MiB used: 430.6 MiB (44.2%) fs: ext4
dev: /dev/nvme1n1p2
ID-3: /boot/efi size: 598.8 MiB used: 19.3 MiB (3.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-4: /home size: 929.93 GiB used: 487.15 GiB (52.4%) fs: btrfs
dev: /dev/nvme1n1p3
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 42.8 C mobo: 30.0 C gpu: amdgpu temp: 59.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Info:
Memory: total: 16 GiB available: 15.51 GiB used: 6.19 GiB (39.9%)
Processes: 401 Uptime: 10m Shell: Bash inxi: 3.3.38
