Kde plasma não carregar painel e nem papel de parede
Notebook Dell Latitude 3470 com distro Kubuntu;
não está carregando painel de notificações que fica na parte superior, e nem papel de parede,
e também não me aparece as opções ao clicar com botão direito na área de trabalho.
$ inxi -F --filter
System:
  Kernel: 5.15.0-30-generic x86_64 bits: 64 Desktop: KDE Plasma 5.24.5
    Distro: Ubuntu 22.04 LTS (Jammy Jellyfish)
Machine:
  Type: Laptop System: Dell product: Latitude 3470 v: N/A
    serial: <superuser required>
  Mobo: Dell model: 0YKP8M v: A00 serial: <superuser required> UEFI: Dell
    v: 1.24.0 date: 03/23/2022
Battery:
  ID-1: BAT0 charge: 20.4 Wh (77.6%) condition: 26.3/41.4 Wh (63.5%)
CPU:
  Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 900 min/max: 400/2800 cores: 1: 900 2: 900 3: 900
    4: 900
Graphics:
  Device-1: Intel Skylake GT2 [HD Graphics 520] driver: i915 v: kernel
  Device-2: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.1
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-30-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  IF: wlp1s0 state: up mac:
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp2s0 state: down mac:
Bluetooth:
  Device-1: Qualcomm Atheros type: USB driver: btusb
  Report: hciconfig ID: hci0 state: up address:  bt-v: 2.1
Drives:
  Local Storage: total: 59.63 GiB used: 16.49 GiB (27.7%)
  ID-1: /dev/sda vendor: Transcend model: TS64GSSD370 size: 59.63 GiB
Partition:
  ID-1: / size: 57.9 GiB used: 16.46 GiB (28.4%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 27.1 MiB (5.3%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 29.0 C pch: 24.5 C mobo: 24.0 C
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 206 Uptime: 10m Memory: 7.38 GiB used: 1.64 GiB (22.2%)
  Shell: Bash inxi: 3.3.13
Nos ajude a te ajudar: Como fornecer boas informações
Seja bem vindo ao fórum @Admti2!
@frc_kde, poderia nos ajudar a tentar entender o que pode estar causando isso?
Para completar, poderia postar a resposta a este comando?
echo $XDG_SESSION_TYPE
Saida do comando;
x11
Obrigado. Isso já elimina uma hipótese de que estivesse numa sessão Wayland.
Vamos tentar outras possibilidades – uma ou duas de cada vez, pois atualmente não tenho Kubuntu 22.04 LTS instalado. – Tive um problema “parecido” com o seu (que removeu kwin-x11 sem eu pedir, e tive de reinstalar manualmente), mas foi no KDE Neon, que não é exatamente igual, embora também esteja com o KDE Plasma 5.24.5.
Veja se você tem o kwin-x11 instalado. – O modo mais fácil de verificar é tentar instalar. – Se receber aviso de que já está instalado, por favor, diga para a gente, pois facilitará outros colegas ajudarem também (além de eliminar esta hipótese específica).
Em seguida, tente este comando, que tentará “consertar” a falta de algum pacote (há vários pacotes kwin) – mas tenha muito cuidado de não teclar Enter, caso ele proponha remover um ou vários pacotes. – Apenas copie e poste aqui a resposta do comando, para analisarmos:
sudo apt-get install -f
(Para evitar riscos, tecle “n” de não, e depois Enter).
Também seria importante sabermos como o problem apareceu: - Seu Kubuntu estava funcionando e deu problema após atualizar? – Ou você acabou de instalar e já veio com esse problema? – E se você tiver acabado de instalar, já fez a atualização inicial?
kwin-x11 já é a versão mais recente (4:5.24.5-0ubuntu1)
Fiz a instalação do kubuntu e algumas customizações pós instalação, estava funcionando normalmente e deu problema após te realizado atualização, acredito eu.
Se você tiver algum registro dessa última atualização (que provocou o problema) – o que foi atualizado, removido, instalado – poste aqui para a gente analisar.
Se não tiver esse registro à mão, poderá encontrá-lo no arquivo /var/log/dpkg.log (um arquivo enorme, com datas e horas) ou talvez no /var/log/alternatives.log (que é menor e mais fácil, também datado).
Estes 2 arquivos são os registros mais recentes – mas ambos têm versões anteriores, numerados – por exemplo: alternatives.log.1, alternatives.log.2.gzip etc.
Poste aqui – apenas o que se refere à data da última atualização, que causou o problema.
Se você ainda não fez outra atualização desde que o problema apareceu, talvez seja bom fazer agora. – Pode ser que já exista algum pacote com a solução.
Uma outra possibilidade, que você pode testar rapidamente: – Reinicie o computador, escolha o Kubuntu no Grub, e tecle “E” para editar.
Na penúltima linha, que começa com linux /boot/ (etc.), acrescente nomodeset – e em seguida tecle CTRL-X para prosseguir com o boot.
Se resolver o problema, então veremos como tornar isso permanente.
Nesse diretório conseguir encontrar o arquivo de log (“dpkg.log”) estou tentando realizar algum tipo de filtro para trazer apenas informação que condiz com a data, “que eu imagino que foi”
Por agora irei compartilhar o arquivo menor (“alternatives.log”)
Realizei um filtro com as datas que eu acredito ter sido,
update-alternatives 2022-05-16 14:36:48: run with --install /usr/bin/x-www-browser x-www-browser /usr/bin/google-chrome-stable 200
update-alternatives 2022-05-16 14:36:48: run with --install /usr/bin/gnome-www-browser gnome-www-browser /usr/bin/google-chrome-stable 200
update-alternatives 2022-05-16 14:36:48: run with --install /usr/bin/google-chrome google-chrome /usr/bin/google-chrome-stable 200
update-alternatives 2022-05-16 14:37:08: run with --install /usr/bin/x-terminal-emulator x-terminal-emulator /usr/bin/konsole 40
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/vim vim /usr/bin/vim.basic 30
update-alternatives 2022-05-16 16:08:09: link group vim updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/vimdiff vimdiff /usr/bin/vim.basic 30
update-alternatives 2022-05-16 16:08:09: link group vimdiff updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/rvim rvim /usr/bin/vim.basic 30
update-alternatives 2022-05-16 16:08:09: link group rvim updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/rview rview /usr/bin/vim.basic 30
update-alternatives 2022-05-16 16:08:09: link group rview updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/vi vi /usr/bin/vim.basic 30 --slave /usr/share/man/da/man1/vi.1.gz vi.da.1.gz /usr/share/man/da/man1/vim.1.gz --slave /usr/share/man/de/man1/vi.1.gz vi.de.1.gz /usr/share/man/de/man1/vim.1.gz --slave /usr/share/man/fr/man1/vi.1.gz vi.fr.1.gz /usr/share/man/fr/man1/vim.1.gz --slave /usr/share/man/it/man1/vi.1.gz vi.it.1.gz /usr/share/man/it/man1/vim.1.gz --slave /usr/share/man/ja/man1/vi.1.gz vi.ja.1.gz /usr/share/man/ja/man1/vim.1.gz --slave /usr/share/man/pl/man1/vi.1.gz vi.pl.1.gz /usr/share/man/pl/man1/vim.1.gz --slave /usr/share/man/ru/man1/vi.1.gz vi.ru.1.gz /usr/share/man/ru/man1/vim.1.gz --slave /usr/share/man/man1/vi.1.gz vi.1.gz /usr/share/man/man1/vim.1.gz
update-alternatives 2022-05-16 16:08:09: link group vi updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:09: run with --install /usr/bin/view view /usr/bin/vim.basic 30 --slave /usr/share/man/da/man1/view.1.gz view.da.1.gz /usr/share/man/da/man1/vim.1.gz --slave /usr/share/man/de/man1/view.1.gz view.de.1.gz /usr/share/man/de/man1/vim.1.gz --slave /usr/share/man/fr/man1/view.1.gz view.fr.1.gz /usr/share/man/fr/man1/vim.1.gz --slave /usr/share/man/it/man1/view.1.gz view.it.1.gz /usr/share/man/it/man1/vim.1.gz --slave /usr/share/man/ja/man1/view.1.gz view.ja.1.gz /usr/share/man/ja/man1/vim.1.gz --slave /usr/share/man/pl/man1/view.1.gz view.pl.1.gz /usr/share/man/pl/man1/vim.1.gz --slave /usr/share/man/ru/man1/view.1.gz view.ru.1.gz /usr/share/man/ru/man1/vim.1.gz --slave /usr/share/man/man1/view.1.gz view.1.gz /usr/share/man/man1/vim.1.gz
update-alternatives 2022-05-16 16:08:09: link group view updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:10: run with --install /usr/bin/ex ex /usr/bin/vim.basic 30 --slave /usr/share/man/da/man1/ex.1.gz ex.da.1.gz /usr/share/man/da/man1/vim.1.gz --slave /usr/share/man/de/man1/ex.1.gz ex.de.1.gz /usr/share/man/de/man1/vim.1.gz --slave /usr/share/man/fr/man1/ex.1.gz ex.fr.1.gz /usr/share/man/fr/man1/vim.1.gz --slave /usr/share/man/it/man1/ex.1.gz ex.it.1.gz /usr/share/man/it/man1/vim.1.gz --slave /usr/share/man/ja/man1/ex.1.gz ex.ja.1.gz /usr/share/man/ja/man1/vim.1.gz --slave /usr/share/man/pl/man1/ex.1.gz ex.pl.1.gz /usr/share/man/pl/man1/vim.1.gz --slave /usr/share/man/ru/man1/ex.1.gz ex.ru.1.gz /usr/share/man/ru/man1/vim.1.gz --slave /usr/share/man/man1/ex.1.gz ex.1.gz /usr/share/man/man1/vim.1.gz
update-alternatives 2022-05-16 16:08:10: link group ex updated to point to /usr/bin/vim.basic
update-alternatives 2022-05-16 16:08:10: run with --install /usr/bin/editor editor /usr/bin/vim.basic 30 --slave /usr/share/man/da/man1/editor.1.gz editor.da.1.gz /usr/share/man/da/man1/vim.1.gz --slave /usr/share/man/de/man1/editor.1.gz editor.de.1.gz /usr/share/man/de/man1/vim.1.gz --slave /usr/share/man/fr/man1/editor.1.gz editor.fr.1.gz /usr/share/man/fr/man1/vim.1.gz --slave /usr/share/man/it/man1/editor.1.gz editor.it.1.gz /usr/share/man/it/man1/vim.1.gz --slave /usr/share/man/ja/man1/editor.1.gz editor.ja.1.gz /usr/share/man/ja/man1/vim.1.gz --slave /usr/share/man/pl/man1/editor.1.gz editor.pl.1.gz /usr/share/man/pl/man1/vim.1.gz --slave /usr/share/man/ru/man1/editor.1.gz editor.ru.1.gz /usr/share/man/ru/man1/vim.1.gz --slave /usr/share/man/man1/editor.1.gz editor.1.gz /usr/share/man/man1/vim.1.gz
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/figlet figlet /usr/bin/figlet-toilet 20
update-alternatives 2022-05-16 17:49:48: link group figlet updated to point to /usr/bin/figlet-toilet
update-alternatives 2022-05-16 17:49:48: run with --quiet --install /usr/bin/pager pager /usr/bin/w3m 25 --slave /usr/share/man/man1/pager.1.gz pager.1.gz /usr/share/man/man1/w3m.1.gz
update-alternatives 2022-05-16 17:49:48: run with --quiet --install /usr/bin/www-browser www-browser /usr/bin/w3m 25 --slave /usr/share/man/man1/www-browser.1.gz www-browser.1.gz /usr/share/man/man1/w3m.1.gz
update-alternatives 2022-05-16 17:49:48: link group www-browser updated to point to /usr/bin/w3m
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/compare compare /usr/bin/compare-im6.q16 10000 --slave /usr/share/man/man1/compare.1.gz compare.1.gz /usr/share/man/man1/compare-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group compare updated to point to /usr/bin/compare-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/compare-im6 compare-im6 /usr/bin/compare-im6.q16 10000 --slave /usr/share/man/man1/compare-im6.1.gz compare-im6.1.gz /usr/share/man/man1/compare-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group compare-im6 updated to point to /usr/bin/compare-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/animate animate /usr/bin/animate-im6.q16 10000 --slave /usr/share/man/man1/animate.1.gz animate.1.gz /usr/share/man/man1/animate-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group animate updated to point to /usr/bin/animate-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/animate-im6 animate-im6 /usr/bin/animate-im6.q16 10000 --slave /usr/share/man/man1/animate-im6.1.gz animate-im6.1.gz /usr/share/man/man1/animate-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group animate-im6 updated to point to /usr/bin/animate-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/convert convert /usr/bin/convert-im6.q16 10000 --slave /usr/share/man/man1/convert.1.gz convert.1.gz /usr/share/man/man1/convert-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group convert updated to point to /usr/bin/convert-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/convert-im6 convert-im6 /usr/bin/convert-im6.q16 10000 --slave /usr/share/man/man1/convert-im6.1.gz convert-im6.1.gz /usr/share/man/man1/convert-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group convert-im6 updated to point to /usr/bin/convert-im6.q16
update-alternatives 2022-05-16 17:49:48: run with --install /usr/bin/composite composite /usr/bin/composite-im6.q16 10000 --slave /usr/share/man/man1/composite.1.gz composite.1.gz /usr/share/man/man1/composite-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:48: link group composite updated to point to /usr/bin/composite-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/composite-im6 composite-im6 /usr/bin/composite-im6.q16 10000 --slave /usr/share/man/man1/composite-im6.1.gz composite-im6.1.gz /usr/share/man/man1/composite-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group composite-im6 updated to point to /usr/bin/composite-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/conjure conjure /usr/bin/conjure-im6.q16 10000 --slave /usr/share/man/man1/conjure.1.gz conjure.1.gz /usr/share/man/man1/conjure-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group conjure updated to point to /usr/bin/conjure-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/conjure-im6 conjure-im6 /usr/bin/conjure-im6.q16 10000 --slave /usr/share/man/man1/conjure-im6.1.gz conjure-im6.1.gz /usr/share/man/man1/conjure-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group conjure-im6 updated to point to /usr/bin/conjure-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/import import /usr/bin/import-im6.q16 10000 --slave /usr/share/man/man1/import.1.gz import.1.gz /usr/share/man/man1/import-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group import updated to point to /usr/bin/import-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/import-im6 import-im6 /usr/bin/import-im6.q16 10000 --slave /usr/share/man/man1/import-im6.1.gz import-im6.1.gz /usr/share/man/man1/import-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group import-im6 updated to point to /usr/bin/import-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/identify identify /usr/bin/identify-im6.q16 10000 --slave /usr/share/man/man1/identify.1.gz identify.1.gz /usr/share/man/man1/identify-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group identify updated to point to /usr/bin/identify-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/identify-im6 identify-im6 /usr/bin/identify-im6.q16 10000 --slave /usr/share/man/man1/identify-im6.1.gz identify-im6.1.gz /usr/share/man/man1/identify-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group identify-im6 updated to point to /usr/bin/identify-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/stream stream /usr/bin/stream-im6.q16 10000 --slave /usr/share/man/man1/stream.1.gz stream.1.gz /usr/share/man/man1/stream-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group stream updated to point to /usr/bin/stream-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/stream-im6 stream-im6 /usr/bin/stream-im6.q16 10000 --slave /usr/share/man/man1/stream-im6.1.gz stream-im6.1.gz /usr/share/man/man1/stream-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group stream-im6 updated to point to /usr/bin/stream-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/display display /usr/bin/display-im6.q16 10000 --slave /usr/share/man/man1/display.1.gz display.1.gz /usr/share/man/man1/display-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group display updated to point to /usr/bin/display-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/display-im6 display-im6 /usr/bin/display-im6.q16 10000 --slave /usr/share/man/man1/display-im6.1.gz display-im6.1.gz /usr/share/man/man1/display-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group display-im6 updated to point to /usr/bin/display-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/montage montage /usr/bin/montage-im6.q16 10000 --slave /usr/share/man/man1/montage.1.gz montage.1.gz /usr/share/man/man1/montage-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group montage updated to point to /usr/bin/montage-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/montage-im6 montage-im6 /usr/bin/montage-im6.q16 10000 --slave /usr/share/man/man1/montage-im6.1.gz montage-im6.1.gz /usr/share/man/man1/montage-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group montage-im6 updated to point to /usr/bin/montage-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/mogrify mogrify /usr/bin/mogrify-im6.q16 10000 --slave /usr/share/man/man1/mogrify.1.gz mogrify.1.gz /usr/share/man/man1/mogrify-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group mogrify updated to point to /usr/bin/mogrify-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --install /usr/bin/mogrify-im6 mogrify-im6 /usr/bin/mogrify-im6.q16 10000 --slave /usr/share/man/man1/mogrify-im6.1.gz mogrify-im6.1.gz /usr/share/man/man1/mogrify-im6.q16.1.gz
update-alternatives 2022-05-16 17:49:49: link group mogrify-im6 updated to point to /usr/bin/mogrify-im6.q16
update-alternatives 2022-05-16 17:49:49: run with --remove figlet /usr/bin/toilet
update-alternatives 2022-05-16 18:16:00: run with --install /usr/bin/unrar unrar /usr/bin/unrar-nonfree 40 --slave /usr/share/man/man1/unrar.1.gz unrar.1.gz /usr/share/man/man1/unrar-nonfree.1.gz
update-alternatives 2022-05-16 18:16:00: link group unrar updated to point to /usr/bin/unrar-nonfree
update-alternatives 2022-05-21 16:43:45: run with --install /usr/share/plymouth/themes/text.plymouth text.plymouth /usr/share/plymouth/themes/kubuntu-text/kubuntu-text.plymouth 60
update-alternatives 2022-05-21 16:43:45: run with --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/bgrt/bgrt.plymouth 110
update-alternatives 2022-05-21 16:43:46: run with --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/kubuntu-logo/kubuntu-logo.plymouth 150 --slave /usr/share/plymouth/themes/default.grub default.plymouth.grub /usr/share/plymouth/themes/kubuntu-logo/kubuntu-logo.grub
update-alternatives 2022-05-25 17:56:05: run with --install /usr/bin/x-www-browser x-www-browser /usr/bin/google-chrome-stable 200
update-alternatives 2022-05-25 17:56:05: run with --install /usr/bin/gnome-www-browser gnome-www-browser /usr/bin/google-chrome-stable 200
update-alternatives 2022-05-25 17:56:05: run with --install /usr/bin/google-chrome google-chrome /usr/bin/google-chrome-stable 200
o estranho é que quando ele “fica um tempo parado na tela de login” acaba entrando no modo de proteção de tela, e onde carregar a “painel de notificação” ai quando faço logo fica com a tela preta;
Também sempre que ligou/reinicio após fazer login aparece a tela “Gerenciador de falhas da KDE”
Experimentou o nomodeset?
Esses registros dos dias 16, 21 e 25 não incluem nenhum pacote que pareça ter potencial para causar esse tipo de problema – mas não tenho certeza sobre qual alteração foi feita de Plymouth, no dia 21.
Você instalou um novo tema do Plymouth? – Já experimentou desfazer e / ou desinstalar esse tema? – Ou foi só uma atualização comum?
Você não sabe se o problema surgiu após as alterações do dia 16? – Pode ter sido um pouco antes? – Pode ter começado após as modificações do dia 21?
Tentei fazer esse modo ao carregar Grub, porem aqui pra mim não aparece a tela do Grub, e na sequencia já aparece a logo “Dell” e em seguida já cai na tele do login.
Ainda não cheguei a fazer a instalação de um novo tema, e ainda não desfiz/desinstalar o tema,
e também não lembro se foi atualização comum.
Na real não tenho 100% de certeza de que o problema apareceu apos as atualizações,
Pela minhas contas eu comecei a procurar uma solução para o problema no dia 21,
logo apos te se deparado com a situação.
Seu computador tem apenas o Kubuntu instalado?
Para exibir o Grub, mantenha apertada a tecla Shift durante o Boot.
Se não alterou nem instalou novo tema, não há necessidade de desfazer nem de desinstalar.
Então verifique a última atualização antes do dia 21.
Sim, apenas o kubuntu
Entendi, irei tentar acessa a tela do Grub
Irei colocar a qui informação do Gerenciador de falhas do KDE,
 Application: Plasma (plasmashell), signal: Segmentation fault
[KCrash Handler]
#4  0x00007ff7a9b4a58f in ?? () from /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
#5  0x00007ff7a9b3eec5 in ?? () from /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
#6  0x00007ff7a9b2419b in ?? () from /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
#7  0x00007ff7a9dfba6c in ?? () from /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
#8  0x00007ff7a9cec0c9 in ?? () from /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
#9  0x00007ff7aa2164b0 in vaPutImage () from /lib/x86_64-linux-gnu/libva.so.2
#10 0x00007ff7aa2b7b23 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvaapi.so
#11 0x00007ff7aa2771a9 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvaapi.so
#12 0x00007ff7aa285e70 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvaapi.so
#13 0x00007ff7aa85e056 in ?? () from /lib/x86_64-linux-gnu/libgstbase-1.0.so.0
#14 0x00007ff7aac32649 in gst_element_change_state () from /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#15 0x00007ff7aac32d55 in ?? () from /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
#16 0x00007ff7aad45174 in ?? () from /lib/x86_64-linux-gnu/libQt5MultimediaGstTools.so.5
#17 0x00007ff7aad44278 in QGstreamerVideoWindow::QGstreamerVideoWindow(QObject*, QByteArray const&) () from /lib/x86_64-linux-gnu/libQt5MultimediaGstTools.so.5
#18 0x00007ff7b0192d9f in ?? () from /usr/lib/x86_64-linux-gnu/qt5/plugins/mediaservice/libgstmediaplayer.so
#19 0x00007ff7b0197bc5 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/plugins/mediaservice/libgstmediaplayer.so
#20 0x00007ff7b00af7af in ?? () from /lib/x86_64-linux-gnu/libQt5Multimedia.so.5
#21 0x00007ff7b00ee0cf in QMediaPlayer::QMediaPlayer(QObject*, QFlags<QMediaPlayer::Flag>) () from /lib/x86_64-linux-gnu/libQt5Multimedia.so.5
#22 0x00007ff7b01c349f in ?? () from /usr/lib/x86_64-linux-gnu/qt5/qml/QtMultimedia/libdeclarative_multimedia.so
#23 0x00007ff81347dd05 in QQmlObjectCreator::createInstance(int, QObject*, bool) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#24 0x00007ff813480d81 in QQmlObjectCreator::setPropertyBinding(QQmlPropertyData const*, QV4::CompiledData::Binding const*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#25 0x00007ff81348131f in QQmlObjectCreator::setupBindings(bool) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#26 0x00007ff81347d283 in QQmlObjectCreator::populateInstance(int, QObject*, QObject*, QQmlPropertyData const*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#27 0x00007ff81347e274 in QQmlObjectCreator::createInstance(int, QObject*, bool) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#28 0x00007ff81347ef03 in QQmlObjectCreator::create(int, QObject*, QQmlInstantiationInterrupt*, int) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#29 0x00007ff81340fbd1 in QQmlIncubatorPrivate::incubate(QQmlInstantiationInterrupt&) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#30 0x00007ff8134104dd in QQmlEnginePrivate::incubate(QQmlIncubator&, QQmlContextData*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#31 0x00007ff813409d6f in QQmlComponent::create(QQmlIncubator&, QQmlContext*, QQmlContext*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#32 0x00007ff813991133 in ?? () from /lib/x86_64-linux-gnu/libQt5Quick.so.5
#33 0x00007ff8139923b3 in ?? () from /lib/x86_64-linux-gnu/libQt5Quick.so.5
#34 0x00007ff813405910 in QQmlPropertyPrivate::write(QObject*, QQmlPropertyData const&, QVariant const&, QQmlContextData*, QFlags<QQmlPropertyData::WriteFlag>) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#35 0x00007ff813328651 in QV4::QObjectWrapper::setProperty(QV4::ExecutionEngine*, QObject*, QQmlPropertyData*, QV4::Value const&) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#36 0x00007ff813328ec2 in QV4::QObjectWrapper::setQmlProperty(QV4::ExecutionEngine*, QQmlContextData*, QObject*, QV4::String*, QV4::QObjectWrapper::RevisionMode, QV4::Value const&) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#37 0x00007ff813329065 in QV4::QObjectWrapper::virtualPut(QV4::Managed*, QV4::PropertyKey, QV4::Value const&, QV4::Value*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#38 0x00007ff8132eef62 in QV4::Object::virtualResolveLookupSetter(QV4::Object*, QV4::ExecutionEngine*, QV4::Lookup*, QV4::Value const&) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#39 0x00007ff813343202 in ?? () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#40 0x00007ff8133475af in ?? () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#41 0x00007ff8132d972e in QV4::Function::call(QV4::Value const*, QV4::Value const*, int, QV4::ExecutionContext const*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#42 0x00007ff813464905 in QQmlJavaScriptExpression::evaluate(QV4::CallData*, bool*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#43 0x00007ff813415beb in QQmlBoundSignalExpression::evaluate(void**) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#44 0x00007ff813416de8 in ?? () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#45 0x00007ff813449725 in QQmlNotifier::emitNotify(QQmlNotifierEndpoint*, void**) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#46 0x00007ff811eef2ec in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#47 0x00007ff8134cd00d in QQmlTimer::event(QEvent*) () from /lib/x86_64-linux-gnu/libQt5Qml.so.5
#48 0x00007ff812bae713 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#49 0x00007ff811eb7e2a in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#50 0x00007ff811ebaf17 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#51 0x00007ff811f11a57 in ?? () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#52 0x00007ff810287d1b in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#53 0x00007ff8102dc6f8 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#54 0x00007ff8102853c3 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#55 0x00007ff811f110a8 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#56 0x00007ff811eb674b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#57 0x00007ff811ebece4 in QCoreApplication::exec() () from /lib/x86_64-linux-gnu/libQt5Core.so.5
#58 0x000055efae72bdce in ?? ()
#59 0x00007ff8117d3d90 in __libc_start_call_main (main=main@entry=0x55efae72af70, argc=argc@entry=1, argv=argv@entry=0x7ffd489f0168) at ../sysdeps/nptl/libc_start_call_main.h:58
#60 0x00007ff8117d3e40 in __libc_start_main_impl (main=0x55efae72af70, argc=1, argv=0x7ffd489f0168, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7ffd489f0158) at ../csu/libc-start.c:392
#61 0x000055efae72bef5 in ?? ()
[Inferior 1 (process 1326) detached]
Acabei de realizar procedimento de entrar na opção do Grub “reinicie o computador, “shift apertado durante o boot” escolha o Kubuntu no Grub, e tecle “E” para editar” e acrescente nomodeset " CTRL-X para prosseguir com o boot."
ao fazer o procedimento pela segunda vez,
até que acabou carregando meu wallpaper e painel de notificações,
aparentemente tudo normal agora!
Acabou dando muito certo!,
Obrigado @frc_kde @thespation
Fico feliz que resolveu o problema.
Para tornar esta solução permanente, você pode executar este comando, e reconfigurar o Grub:
sudo dpkg-reconfigure grub-pc
Eu me limitei a clicar Enter (Ok, Ok), só para mostrar a sequência, pois eu não queria mudar nada.
Em 2017, eu tinha quiet splash (segunda tela), e substituí por nomodeset – para não ter de fazer isso manualmente a cada boot:
Obs.: – Ao eliminar o quiet splash, passei a ver todas as mensagens durante o boot – que antes eram escondidas pela animação de enfeite da distro.
Essas “mensagens de boot” às vezes ajudam a descobrir algum problema. – Elas ficam guardadas em /var/log/boot.log e você pode examiná-las de novo.
Compreendi,
Irei arruma um tempo para tentar fazer esse procedimento,
É que por agora não estou em casa.
Então talvez eu precise executa novamente o “nomodeset” por conta que após o processo dado como corrigido acabei desligado note,
Maravilha,
também irei tirar um tempo para aprende mais sobre esses assuntos citados por aqui.
Obrigado pela força!
@frc_kde
Olá Flavio,
Como eu imaginei que seria, ao ligar o note não trouxe meu wallpapers.
Então tiver que realizar o procedimento “nomodeset” novamente, e posteriormente rodei o
“sudo dpkg-reconfigure grub-pc” para torna a solução permanente,
e correio super certo!
Mais uma vez quero agradeço pela ajuda @frc_kde
:+1::facepunch:
Olá Flavio,
Quando puder poderia me auxiliar a verificar um problema que não estou conseguindo adicionar uma segunda tela.
Só de ligar o cabo HDMI não está reconhecendo.
