Depois de algumas horas de uso aparece esse problema:
GDBus.Error:org.freedesktop.DBus.Error.LimitsExceeded: Sending user’s quota exceeded
Não tenho nenhuma quota de usuário ativada no sistema. As minhas opções de Desligar, Reiniciar somem, não consigo mais aumentar ou baixar o brilho… nem abrir outros aplicativos…
Vi que talvez esse problema tivesse relação com a Nvida, mas aqui ta tudo 100% no driver
https://www.reddit.com/r/Fedora/comments/um3quj/sending_users_quota_exceeded_error_popping_up/
Quem poderá me Socorrer?
Detalhes:
sem quota e sem erros na nvida
System:
Kernel: 5.18.11-200.fc36.x86_64 arch: x86_64 bits: 64 Desktop: GNOME
v: 42.3.1 Distro: Fedora release 36 (Thirty Six)
Machine:
Type: Laptop System: Alienware product: Alienware m15 R6 v: N/A
serial: <filter>
Mobo: Alienware model: 0MK6FH v: A01 serial: <filter> UEFI: Alienware
v: 1.12.0 date: 04/11/2022
Battery:
ID-1: BAT0 charge: 67.1 Wh (100.0%) condition: 67.1/84.3 Wh (79.6%)
CPU:
Info: 8-core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
cache: L2: 10 MiB
Speed (MHz): avg: 2033 min/max: 800/4600 cores: 1: 1481 2: 1578 3: 1675
4: 2237 5: 1151 6: 801 7: 4567 8: 801 9: 2332 10: 3738 11: 2288 12: 2742
13: 801 14: 923 15: 4619 16: 801
Graphics:
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] driver: nvidia
v: 515.57
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo
Display: web server: X.Org v: 1.20.14 with: Xwayland v: 22.1.3 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,vesa gpu: nvidia,nvidia-nvswitch
resolution: 1920x1080
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57
Audio:
Device-1: Intel Tiger Lake-H HD Audio driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.18.11-200.fc36.x86_64 running: yes
Sound Server-2: PipeWire v: 0.3.55 running: yes
Network:
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Realtek driver: r8169
IF: enp46s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: see --recommends
Drives:
Local Storage: total: 1.84 TiB used: 950.95 GiB (50.4%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC711 NVMe 1TB
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
Partition:
ID-1: / size: 952.27 GiB used: 269.06 GiB (28.3%) fs: btrfs dev: /dev/dm-0
ID-2: /boot size: 973.4 MiB used: 273.9 MiB (28.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-3: /boot/efi size: 598.8 MiB used: 14 MiB (2.3%) fs: vfat
dev: /dev/nvme0n1p1
ID-4: /home size: 952.27 GiB used: 269.06 GiB (28.3%) fs: btrfs
dev: /dev/dm-0
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A
Info:
Processes: 665 Uptime: 1h 16m Memory: 62.45 GiB used: 5.77 GiB (9.2%)
Shell: Bash inxi: 3.3.19
Pode parecer besteira, mas “se você você esta utilizando uma instalação padrão com selinux ativado” experimente fazer.
sudo touch /.autorelabel
e reiniciar issó vai verificar todo sistema de arquivos e reetiquetar de acordo com o selinux, será aplicado na próxima inicialização “que com certeza vai demorar, então seja paciente e aguarde” você pode verificar o que ele está fazendo teclando ESC no plymouth.
Dependendo do tipo e aonde um arquivo é alterado no sistema o selinux começa a bloquear algumas coisas para o usuário via interface gráfica, se vocẽ executar “sudo reboot” ou “sudo systemctl restart” de dentro do terminal vai rolar normalmente, mas se você executar só systemctl restart sem sudo não vai funcionar o que é errado e normalmente teria que funcionar solicitando a senha via popup do polkit.
PS: Belo papel de parede
vou para o boot com o rd.break e fazer o .autorelabel, espero que der certo kkk
Vixe, o journalctl não mostra nada de mensagens de erro?
Um Core meu fica nos quase 100% e
Se der um systemctl stop nvidia-powerd.service o sistema volta ao normal
Complicado, eu não consigo reproduzr pois meu hardware é intel.
