Anunciado algumas horas atrás, a mais recente versão de testes do Proton ( proton-6.3-6-rc ) traz mudanças importantes na forma como os jogos armazenam seus saves, permitindo que o Steam Cloud Sync funcione adequadamente em uma variedade maior de títulos. Porém, os desenvolvedores alertam que nesta versão de testes, existe a chance de seus saves serem apagados , então, faça um backup antes de testar a nova versão.
Alguns dos títulos que agora funcionam corretamente:
Forza Horizon 4
Tokyo Xanadu eX+
Sonic Adventure 2
Rez Infinite
Elite Dangerous
Blood of Steel
Homeworld Remastered Collection
Star Wars Knights of the Old Republic
eFootball PES 2021
Guardians VR
3D Aim Trainer
Confira as demais correções diretamente no Git do projeto.
opened 07:12PM - 12 Aug 21 UTC
closed 02:56PM - 01 Sep 21 UTC
Hello. We've put together a new Proton 6.3 build for you to test.
**But Wa… it! Please Read This First!** In this build, we have reconfigured where games store their save files in order to fix the Steam cloud sync feature for a number of games. Your save data will be migrated automatically and should continue to function even when switching between Proton versions. While we have done a good amount of testing on this and don't expect there to be any problems, there is **a possibility of losing your save data** when using this build. If you have very precious save data, we suggest you back up your data, or avoid using this build for now. On the flip side, we strongly appreciate any extra testing you can do with this build to help ensure there aren't any lurking save data issues. **Thank you for reading this paragraph.**
In the Steam client, the Proton 6.3 app should have a "**proton-6.3-6-rc**" beta branch which you can choose to start testing the 6.3-6 Release Candidates. You may need to restart the Steam client to see it. Note that the name of the build in the Steam Settings dialog will not be updated. I will post changes here when we push new builds. The source for the latest RC build is available on the proton_6.3-next branch in these repositories. This branch may receive forced updates.
In this issue, we are interested only in problems that are new to the 6.3-6 RC builds. If you find new problems in the "next" branch, please confirm that the problem does not occur in on the "default" branch before reporting it here. **In particular, if you find your save data has changed in an unexpected way, please report that here.**
Here is the tentative changelog. As always, this changelog has not yet been verified by our QA staff, and can change before the final release as we add or remove features during RC testing.
- The following games are now playable:
- Tokyo Xanadu eX+
- Sonic Adventure 2
- Rez Infinite
- Elite Dangerous
- Blood of Steel
- Homeworld Remastered Collection
- Star Wars Knights of the Old Republic
- Guardians VR
- 3D Aim Trainer
- Fix Microsoft Flight Simulator hang while loading.
- Fix Unreal Engine 4 update installation, which impacted Everspace 2 and KARDS.
- Better cursor capture behavior for fullscreen windows.
- Improve input handling after focus loss in some games like Warhammer: Chaosbane and Far Cry Primal.
- Correct game save locations to improve Steam cloud sync behavior in:
- Guilty Gear -Strive-
- Death Stranding
- Katamari Damacy Reroll
- Scarlet Nexus
- Fix text input and clipboard pasting in Origin overlay and launcher.
- Fix some music not playing in Planet Coaster.
- Improve non-English experience in Cyberpunk 2077 and Rockstar Games launchers.
- Improve launcher behavior in Swords of Legends Online.
- Fix Mafia III: Definitive Edition performance when FPS limiter is enabled.
- Fix audio playback issues in Fallout: New Vegas, Oblivion, Borderlands 3, and Deep Rock Galactic.
- Improve video playback in Deep Rock Galactic, The Medium, Nier: Replicant, and Contra: Rogue Corps.
- Update wine-mono to [6.3.0](https://github.com/madewokherd/wine-mono/releases/tag/wine-mono-6.3.0).
- Update DXVK to [v1.9.1](https://github.com/doitsujin/dxvk/releases/tag/v1.9.1).
- Update vkd3d-proton to [v2.4](https://github.com/HansKristian-Work/vkd3d-proton/releases/tag/v2.4).
- Update FAudio to [20.08](https://github.com/FNA-XNA/FAudio/releases/tag/21.08).
- Optionally support Nvidia's NVAPI GPU support library and DLSS. It is disabled by default and can be enabled with PROTON_ENABLE_NVAPI=1.
13 curtidas
