Eu uso o openSUSE Krypton, que é o Tumbleweed com os repositórios KDE Frameworks Unstable, KDE Applications Unstable, KDE Extras Unstable e Qt5 Unstable. Eu tenho todas essas dependências instaladas. No entanto, por se tratar do futuro KDE Plasma 5.21, esse LightlyShaders não é compatível com essa versão do KWin que uso. Aqui está o log do processo inteiro:
silas@lenovoSUSE ~/A/L/qt5build (master) [1]>
cmake …/ -DCMAKE_INSTALL_PREFIX=/usr -DQT5BUILD=ON
– The C compiler identification is GNU 10.2.1
– The CXX compiler identification is GNU 10.2.1
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: /usr/bin/cc - skipped
– Detecting C compile features
– Detecting C compile features - done
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/c++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Installing in the same prefix as Qt, adopting their path scheme.
– Setting build type to ‘Debug’ as none was specified.
– Looking for GLIBC
– Looking for GLIBC - found
– Performing Test _OFFT_IS_64BIT
– Performing Test _OFFT_IS_64BIT - Success
– Performing Test HAVE_DATE_TIME
– Performing Test HAVE_DATE_TIME - Success
– Found KF5Config: /usr/lib64/cmake/KF5Config/KF5ConfigConfig.cmake (found version “5.79.0”)
– Found KF5ConfigWidgets: /usr/lib64/cmake/KF5ConfigWidgets/KF5ConfigWidgetsConfig.cmake (found version “5.79.0”)
– Found KF5CoreAddons: /usr/lib64/cmake/KF5CoreAddons/KF5CoreAddonsConfig.cmake (found version “5.79.0”)
– Found KF5Crash: /usr/lib64/cmake/KF5Crash/KF5CrashConfig.cmake (found version “5.79.0”)
– Found KF5GlobalAccel: /usr/lib64/cmake/KF5GlobalAccel/KF5GlobalAccelConfig.cmake (found version “5.79.0”)
– Found Gettext: /usr/bin/msgmerge (found version “0.21”)
– Found KF5I18n: /usr/lib64/cmake/KF5I18n/KF5I18nConfig.cmake (found version “5.79.0”)
– Found KF5KIO: /usr/lib64/cmake/KF5KIO/KF5KIOConfig.cmake (found version “5.79.0”)
– Found KF5Service: /usr/lib64/cmake/KF5Service/KF5ServiceConfig.cmake (found version “5.79.0”)
– Found KF5Init: /usr/lib64/cmake/KF5Init/KF5InitConfig.cmake (found version “5.79.0”)
– Found KF5Notifications: /usr/lib64/cmake/KF5Notifications/KF5NotificationsConfig.cmake (found version “5.79.0”)
– Found KF5WidgetsAddons: /usr/lib64/cmake/KF5WidgetsAddons/KF5WidgetsAddonsConfig.cmake (found version “5.79.0”)
– Found KF5WindowSystem: /usr/lib64/cmake/KF5WindowSystem/KF5WindowSystemConfig.cmake (found version “5.79.0”)
– Found KF5GuiAddons: /usr/lib64/cmake/KF5GuiAddons/KF5GuiAddonsConfig.cmake (found version “5.79.0”)
– Found KF5: success (found suitable version “5.79.0”, minimum required is “5.9.0”) found components: Config ConfigWidgets CoreAddons Crash GlobalAccel I18n KIO Service Init Notifications Service WidgetsAddons WindowSystem GuiAddons
– Found X11: /usr/include
– Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so
– Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Found PkgConfig: /usr/bin/pkg-config (found version “1.7.3”)
– Found XCB_XCB: /usr/lib64/libxcb.so (found version “1.14”)
– Found XCB_RENDER: /usr/lib64/libxcb-render.so (found version “1.14”)
– Found XCB_SHAPE: /usr/lib64/libxcb-shape.so (found version “1.14”)
– Found XCB_XFIXES: /usr/lib64/libxcb-xfixes.so (found version “1.14”)
– Found XCB_SHM: /usr/lib64/libxcb-shm.so (found version “1.14”)
– Found XCB_ATOM: /usr/lib64/libxcb-util.so (found version “0.4.0”)
– Found XCB_AUX: /usr/lib64/libxcb-util.so (found version “0.4.0”)
– Found XCB_COMPOSITE: /usr/lib64/libxcb-composite.so (found version “1.14”)
– Found XCB_CURSOR: /usr/lib64/libxcb-cursor.so (found version “0.1.3”)
– Found XCB_DAMAGE: /usr/lib64/libxcb-damage.so (found version “1.14”)
– Found XCB_DPMS: /usr/lib64/libxcb-dpms.so (found version “1.14”)
– Found XCB_DRI2: /usr/lib64/libxcb-dri2.so (found version “1.14”)
– Found XCB_DRI3: /usr/lib64/libxcb-dri3.so (found version “1.14”)
– Found XCB_EVENT: /usr/lib64/libxcb-util.so (found version “0.4.0”)
– Found XCB_EWMH: /usr/lib64/libxcb-ewmh.so (found version “0.4.1”)
– Found XCB_GLX: /usr/lib64/libxcb-glx.so (found version “1.14”)
– Found XCB_ICCCM: /usr/lib64/libxcb-icccm.so (found version “0.4.1”)
– Found XCB_IMAGE: /usr/lib64/libxcb-image.so (found version “0.4.0”)
– Found XCB_KEYSYMS: /usr/lib64/libxcb-keysyms.so (found version “0.4.0”)
– Found XCB_PRESENT: /usr/lib64/libxcb-present.so (found version “1.14”)
– Found XCB_RANDR: /usr/lib64/libxcb-randr.so (found version “1.14”)
– Found XCB_RECORD: /usr/lib64/libxcb-record.so (found version “1.14”)
– Found XCB_RENDERUTIL: /usr/lib64/libxcb-render-util.so (found version “0.3.9”)
– Found XCB_RES: /usr/lib64/libxcb-res.so (found version “1.14”)
– Found XCB_SCREENSAVER: /usr/lib64/libxcb-screensaver.so (found version “1.14”)
– Found XCB_SYNC: /usr/lib64/libxcb-sync.so (found version “1.14”)
– Found XCB_UTIL: /usr/lib64/libxcb-util.so (found version “0.4.0”)
– Could NOT find XCB_XEVIE (missing: XCB_XEVIE_LIBRARY) (found version “”)
– Found XCB_XF86DRI: /usr/lib64/libxcb-xf86dri.so (found version “1.14”)
– Found XCB_XINERAMA: /usr/lib64/libxcb-xinerama.so (found version “1.14”)
– Found XCB_XKB: /usr/lib64/libxcb-xkb.so (found version “1.14”)
– Could NOT find XCB_XPRINT (missing: XCB_XPRINT_LIBRARY) (found version “”)
– Found XCB_XTEST: /usr/lib64/libxcb-xtest.so (found version “1.14”)
– Found XCB_XV: /usr/lib64/libxcb-xv.so (found version “1.14”)
– Found XCB_XVMC: /usr/lib64/libxcb-xvmc.so (found version “1.14”)
– Found XCB: /usr/lib64/libxcb.so;/usr/lib64/libxcb-render.so;/usr/lib64/libxcb-shape.so;/usr/lib64/libxcb-xfixes.so;/usr/lib64/libxcb-shm.so;/usr/lib64/libxcb-util.so;/usr/lib64/libxcb-composite.so;/usr/lib64/libxcb-cursor.so;/usr/lib64/libxcb-damage.so;/usr/lib64/libxcb-dpms.so;/usr/lib64/libxcb-dri2.so;/usr/lib64/libxcb-dri3.so;/usr/lib64/libxcb-ewmh.so;/usr/lib64/libxcb-glx.so;/usr/lib64/libxcb-icccm.so;/usr/lib64/libxcb-image.so;/usr/lib64/libxcb-keysyms.so;/usr/lib64/libxcb-present.so;/usr/lib64/libxcb-randr.so;/usr/lib64/libxcb-record.so;/usr/lib64/libxcb-render-util.so;/usr/lib64/libxcb-res.so;/usr/lib64/libxcb-screensaver.so;/usr/lib64/libxcb-sync.so;/usr/lib64/libxcb-xf86dri.so;/usr/lib64/libxcb-xinerama.so;/usr/lib64/libxcb-xkb.so;/usr/lib64/libxcb-xtest.so;/usr/lib64/libxcb-xv.so;/usr/lib64/libxcb-xvmc.so (found version “1.14”)
– Configuring done
– Generating done
CMake Warning:
Manually-specified variables were not used by the project:QT5BUILD– Build files have been written to: /home/silas/Applications/LightlyShaders/qt5build
silas@lenovoSUSE ~/A/L/qt5build (master)> make
Scanning dependencies of target kwin4_lightlyshaders_config_autogen
[ 7%] Generating lightlyshaders_config.json
About to parse service type file “/usr/share/kservicetypes5/kcmodule.desktop”
Found property definition “X-KDE-FactoryName” with type “QString”
Found property definition “X-KDE-ParentComponents” with type “QStringList”
Found property definition “X-KDE-CfgDlgHierarchy” with type “QString”
Found property definition “X-KDE-System-Settings-Parent-Category” with type “QString”
Found property definition “X-KDE-KInfoCenter-Category” with type “QString”
Found property definition “X-KDE-Weight” with type “int”
Found property definition “X-KDE-PluginKeyword” with type “QString”
Found property definition “X-KDE-OnlyShowOnQtPlatforms” with type “QStringList”
Found property definition “X-KDE-KCM-Args” with type “QStringList”
Generated “/home/silas/Applications/LightlyShaders/qt5build/lightlyshaders_config.json”
[ 15%] Automatic MOC for target kwin4_lightlyshaders_config
[ 15%] Built target kwin4_lightlyshaders_config_autogen
[ 23%] Generating ui_lightlyshaders_config.h
[ 30%] Generating kwineffects_interface.cpp, kwineffects_interface.h
[ 38%] Generating kwineffects_interface.moc
[ 46%] Building CXX object CMakeFiles/kwin4_lightlyshaders_config.dir/kwin4_lightlyshaders_config_autogen/mocs_compilation.cpp.o
In file included from /home/silas/Applications/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/EWIEGA46WW/moc_lightlyshaders_config.cpp:10,
from /home/silas/Applications/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/mocs_compilation.cpp:2:
/home/silas/Applications/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/EWIEGA46WW/…/…/…/lightlyshaders_config.h:13:10: warning: ‘virtual void LightlyShadersConfig::save()’ can be marked override [-Wsuggest-override]
13 | void save();
/home/silas/Applications/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/EWIEGA46WW/…/…/…/lightlyshaders_config.h:14:10: warning: ‘virtual void LightlyShadersConfig::load()’ can be marked override [-Wsuggest-override]
14 | void load();
/home/silas/Applications/LightlyShaders/qt5build/kwin4_lightlyshaders_config_autogen/EWIEGA46WW/…/…/…/lightlyshaders_config.h:15:10: warning: ‘virtual void LightlyShadersConfig::defaults()’ can be marked override [-Wsuggest-override]
15 | void defaults();
[ 53%] Building CXX object CMakeFiles/kwin4_lightlyshaders_config.dir/lightlyshaders_config.cpp.o
In file included from /home/silas/Applications/LightlyShaders/lightlyshaders_config.cpp:1:
/home/silas/Applications/LightlyShaders/lightlyshaders_config.h:13:10: warning: ‘virtual void LightlyShadersConfig::save()’ can be marked override [-Wsuggest-override]
13 | void save();
/home/silas/Applications/LightlyShaders/lightlyshaders_config.h:14:10: warning: ‘virtual void LightlyShadersConfig::load()’ can be marked override [-Wsuggest-override]
14 | void load();
/home/silas/Applications/LightlyShaders/lightlyshaders_config.h:15:10: warning: ‘virtual void LightlyShadersConfig::defaults()’ can be marked override [-Wsuggest-override]
/home/silas/Applications/LightlyShaders/lightlyshaders_config.cpp: In constructor ‘LightlyShadersConfig::LightlyShadersConfig(QWidget*, const QVariantList&)’:
/home/silas/Applications/LightlyShaders/lightlyshaders_config.cpp:51:28: warning: ‘static KAboutData* KAboutData::pluginData(const QString&)’ is deprecated: Since 5.76. See API docs [-Wdeprecated-declarations]
51 | : KCModule(KAboutData::pluginData(QStringLiteral(“kwin4_effect_lightlyshaders”)), parent, args)
In file included from /usr/include/KF5/KCoreAddons/KAboutData:1,
from /home/silas/Applications/LightlyShaders/lightlyshaders_config.cpp:16:
/usr/include/KF5/KCoreAddons/kaboutdata.h:467:24: note: declared here
467 | static KAboutData pluginData(const QString &componentName);
/home/silas/Applications/LightlyShaders/lightlyshaders_config.cpp:51:84: warning: ‘static KAboutData KAboutData::pluginData(const QString&)’ is deprecated: Since 5.76. See API docs [-Wdeprecated-declarations]
51 | boutData::pluginData(QStringLiteral(“kwin4_effect_lightlyshaders”)), parent, args)
| ^In file included from /usr/include/KF5/KCoreAddons/KAboutData:1,
467 | static KAboutData *pluginData(const QString &componentName);
[ 61%] Building CXX object CMakeFiles/kwin4_lightlyshaders_config.dir/kwineffects_interface.cpp.o
[ 69%] Linking CXX shared module kwin4_lightlyshaders_config.so
[ 69%] Built target kwin4_lightlyshaders_config
Scanning dependencies of target kwin4_effect_lightlyshaders_autogen
[ 76%] Automatic MOC for target kwin4_effect_lightlyshaders
AutoMoc warning“SRC:/lightlyshaders.cpp”
includes the moc file “lightlyshaders.moc”, but does not contain a Q_OBJECT, Q_GADGET, Q_NAMESPACE, Q_NAMESPACE_EXPORT, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON, K_PLUGIN_CLASS_WITH_JSON, K_PLUGIN_FACTORY, K_PLUGIN_FACTORY_WITH_JSON or K_PLUGIN_CLASS_WITH_JSON macro.[ 76%] Built target kwin4_effect_lightlyshaders_autogen
[ 84%] Building CXX object CMakeFiles/kwin4_effect_lightlyshaders.dir/kwin4_effect_lightlyshaders_autogen/mocs_compilation.cpp.o
In file included from /home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/…/…/…/dbus.h:5,
from /home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/moc_dbus.cpp:10,
from /home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/mocs_compilation.cpp:2:
/home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/…/…/…/lightlyshaders.h:43:10: warning: ‘virtual void LightlyShadersEffect::reconfigure(KWin::Effect::ReconfigureFlags)’ can be marked override [-Wsuggest-override]
43 | void reconfigure(ReconfigureFlags flags);
/home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/…/…/…/lightlyshaders.h:45:10: warning: ‘virtual void LightlyShadersEffect::paintWindow(KWin::EffectWindow*, int, QRegion, KWin::WindowPaintData&)’ can be marked override [-Wsuggest-override]
45 | void paintWindow(KWin::EffectWindow* w, int mask, QRegion region, KWin::WindowPaintData& data);
/home/silas/Applications/LightlyShaders/qt5build/kwin4_effect_lightlyshaders_autogen/EWIEGA46WW/…/…/…/lightlyshaders.h:46:17: warning: ‘virtual int LightlyShadersEffect::requestedEffectChainPosition() const’ can be marked override [-Wsuggest-override]
46 | virtual int requestedEffectChainPosition() const { return 99; }
[ 92%] Building CXX object CMakeFiles/kwin4_effect_lightlyshaders.dir/lightlyshaders.cpp.o
In file included from /home/silas/Applications/LightlyShaders/dbus.h:5,
from /home/silas/Applications/LightlyShaders/lightlyshaders.cpp:20:
/home/silas/Applications/LightlyShaders/lightlyshaders.h:43:10: warning: ‘virtual void LightlyShadersEffect::reconfigure(KWin::Effect::ReconfigureFlags)’ can be marked override [-Wsuggest-override]
/home/silas/Applications/LightlyShaders/lightlyshaders.h:45:10: warning: ‘virtual void LightlyShadersEffect::paintWindow(KWin::EffectWindow*, int, QRegion, KWin::WindowPaintData&)’ can be marked override [-Wsuggest-override]
/home/silas/Applications/LightlyShaders/lightlyshaders.h:46:17: warning: ‘virtual int LightlyShadersEffect::requestedEffectChainPosition() const’ can be marked override [-Wsuggest-override]
/home/silas/Applications/LightlyShaders/lightlyshaders.cpp: In member function ‘void LightlyShadersEffect::prePaintWindow(KWin::EffectWindow*, KWin::WindowPrePaintData&, int)’:
/home/silas/Applications/LightlyShaders/lightlyshaders.cpp:208:48: error: cannot convert ‘int’ to ‘std::chrono::milliseconds’ {aka ‘std::chrono::duration<long int, std::ratio<1, 1000> >’}
208 | KWin::effects->prePaintWindow(w, data, time);
| int
In file included from /home/silas/Applications/LightlyShaders/lightlyshaders.h:23,
/usr/include/kwineffects.h:838:102: note: initializing argument 3 of ‘virtual void KWin::EffectsHandler::prePaintWindow(KWin::EffectWindow*, KWin::WindowPrePaintData&, std::chrono::milliseconds)’
838 | ectWindow* w, WindowPrePaintData& data, std::chrono::milliseconds presentTime) = 0;
| ~~~~~~~~~~~~~~~~^/home/silas/Applications/LightlyShaders/lightlyshaders.cpp:228:44: error: cannot convert ‘int’ to ‘std::chrono::milliseconds’ {aka ‘std::chrono::duration<long int, std::ratio<1, 1000> >’}
228 | KWin::effects->prePaintWindow(w, data, time);
| int
| ~~~~~~~~~~~~~~~~^In file included from /usr/include/qt5/QtDBus/qtdbusglobal.h:43,
from /usr/include/qt5/QtDBus/qdbusabstractadaptor.h:43,
from /usr/include/qt5/QtDBus/QDBusAbstractAdaptor:1,
from /home/silas/Applications/LightlyShaders/dbus.h:4,
/home/silas/Applications/LightlyShaders/lightlyshaders.cpp: In member function ‘void LightlyShadersEffect::fillRegion(const QRegion&, const QColor&)’:
/home/silas/Applications/LightlyShaders/lightlyshaders.cpp:355:41: warning: ‘QVector QRegion::rects() const’ is deprecated: Use begin()/end() instead [-Wdeprecated-declarations]
355 | foreach (const QRect & r, reg.rects())
In file included from /usr/include/qt5/QtGui/qmatrix.h:45,
from /usr/include/qt5/QtGui/qtransform.h:43,
from /usr/include/qt5/QtGui/qimage.h:48,
from /usr/include/qt5/QtGui/QImage:1,
from /usr/include/kwinglobals.h:14,
from /usr/include/kwineffects.h:18,
/usr/include/qt5/QtGui/qregion.h:125:20: note: declared here
125 | QVector rects() const;
make[2]: *** [CMakeFiles/kwin4_effect_lightlyshaders.dir/build.make:95: CMakeFiles/kwin4_effect_lightlyshaders.dir/lightlyshaders.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:128: CMakeFiles/kwin4_effect_lightlyshaders.dir/all] Error 2
make: *** [Makefile:160: all] Error 2
Como pode ver, o erro acontece quando uso o mais recente do KDE Plasma, não o mais estável. O LightlyShaders precisa ser modificado para o novo KWin, algo que só vai acontecer quando o 5.21 já ter sido lançado. Por isso que especifiquei que era o openSUSE Krypton, não o openSUSE Tumbleweed normal. Caso tenha instalado os repositórios do KDE Unstable em uma instalação do Tumbleweed existente, você esqueceu de especificar a troca das fontes dos repositórios para usar as do KDE Unstable no lugar das do openSUSE.
mas “funcionava” em todas as plataformas e exigia quase nenhuma mudança na DE ou engine.
