Estou tendo problemas com os Appimage no arch com plasma [Resolvido]
Olá meus caros amigos, estou tendo problemas em relação aos appimages no arch. Quando baixo o app me deparo com diversos erros do kioskave5 e o baloo.
Seguem as saídas deles
Baloo:
Application: Extrator de arquivos do Baloo (baloo_file_extractor), signal: Segmentation fault
Content of s_kcrashErrorMessage: std::unique_ptr<char []> = {get() = <optimized out>}
[KCrash Handler]
#6  0x00007f16b8a03dbf in sqfs_init (fs=fs@entry=0x55931e6473b0, fd=20, offset=offset@entry=100024, subdir=subdir@entry=0x55931e649 <error: Cannot access memory at address 0x55931e649>) at /usr/src/debug/squashfuse/squashfuse-0.3.0/fs.c:98
#7  0x00007f16b8a03f0b in sqfs_open_image (fs=0x55931e6473b0, image=<optimized out>, offset=100024, subdir=0x55931e649 <error: Cannot access memory at address 0x55931e649>) at /usr/src/debug/squashfuse/squashfuse-0.3.0/util.c:77
#8  0x00007f16b8b2180c in appimage::core::impl::TraversalType2::Priv::Priv(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (path="/home/felipe/Downloads/pcloud", this=0x55931e647380) at /usr/include/c++/12.2.1/bits/basic_string.h:233
#9  appimage::core::impl::TraversalType2::TraversalType2(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) (this=0x55931e633570, path="/home/felipe/Downloads/pcloud", this=<optimized out>, path=Python Exception <class 'gdb.error'>: value has been optimized out
) at /usr/src/debug/libappimage/libappimage-1.0.4-5/src/libappimage/core/impl/TraversalType2.cpp:284
#10 0x00007f16b8b21ada in appimage::core::PayloadIterator::Private::Private(appimage::core::AppImage const&, bool) (this=0x55931e5f6bd0, appImage=<optimized out>, atEnd=<optimized out>, this=<optimized out>, appImage=<optimized out>, atEnd=<optimized out>) at /usr/src/debug/libappimage/libappimage-1.0.4-5/src/libappimage/core/PayloadIterator.cpp:50
#11 0x00007f16b8b21c69 in appimage::core::PayloadIterator::PayloadIterator(appimage::core::AppImage const&) (this=0x7ffc9f981900, appImage=..., this=<optimized out>, appImage=<optimized out>) at /usr/src/debug/libappimage/libappimage-1.0.4-5/src/libappimage/core/PayloadIterator.cpp:136
#12 0x00007f16b8b21cce in appimage::core::AppImage::files() const (this=this@entry=0x7ffc9f981940) at /usr/src/debug/libappimage/libappimage-1.0.4-5/src/libappimage/core/AppImage.cpp:74
#13 0x00007f16b8b21e2f in appimage_list_files(char const*) (path=<optimized out>) at /usr/src/debug/libappimage/libappimage-1.0.4-5/src/libappimage/libappimage.cpp:66
#14 0x00007f16baaedd36 in KFileMetaData::AppImageExtractor::extract(KFileMetaData::ExtractionResult*) (this=<optimized out>, result=0x7ffc9f981db0) at /usr/src/debug/kfilemetadata/kfilemetadata-5.108.0/src/extractors/appimageextractor.cpp:239
#15 0x000055931d9c1499 in Baloo::App::index(Baloo::Transaction*, QString const&, unsigned long long) (this=this@entry=0x7ffc9f982460, tr=0x7f16b40112a0, url=..., id=id@entry=377390186364967) at /usr/src/debug/baloo/baloo-5.108.0/src/file/extractor/app.cpp:170
#16 0x000055931d9c324e in Baloo::App::processNextFile() (this=0x7ffc9f982460) at /usr/src/debug/baloo/baloo-5.108.0/src/file/extractor/app.cpp:102
#17 0x00007f16bead34b7 in QtPrivate::QSlotObjectBase::call(QObject*, void**) (a=0x7ffc9f981f70, r=<optimized out>, this=<optimized out>, this=<optimized out>, r=<optimized out>, a=<optimized out>) at ../../include/QtCore/../../src/corelib/kernel/qobjectdefs_impl.h:398
#18 QSingleShotTimer::timerEvent(QTimerEvent*) (this=0x55931e5e63c0) at kernel/qtimer.cpp:322
#19 0x00007f16beac3cee in QObject::event(QEvent*) (this=0x55931e5e63c0, e=0x7ffc9f9820a0) at kernel/qobject.cpp:1324
#20 0x00007f16bea9c2f8 in QCoreApplication::notifyInternal2(QObject*, QEvent*) (receiver=0x55931e5e63c0, event=0x7ffc9f9820a0) at kernel/qcoreapplication.cpp:1064
#21 0x00007f16beaea9bb in QTimerInfoList::activateTimers() (this=0x55931e59ea60) at kernel/qtimerinfo_unix.cpp:643
#22 0x00007f16beaeaf9a in timerSourceDispatch(GSource*, GSourceFunc, gpointer) (source=<optimized out>) at kernel/qeventdispatcher_glib.cpp:183
#23 0x00007f16bd50fa31 in g_main_dispatch (context=0x7f16b4000ee0) at ../glib/glib/gmain.c:3460
#24 g_main_context_dispatch (context=0x7f16b4000ee0) at ../glib/glib/gmain.c:4200
#25 0x00007f16bd56ccc9 in g_main_context_iterate.isra.0 (context=context@entry=0x7f16b4000ee0, block=block@entry=1, dispatch=dispatch@entry=1, self=<optimized out>) at ../glib/glib/gmain.c:4276
#26 0x00007f16bd50d0e2 in g_main_context_iteration (context=0x7f16b4000ee0, may_block=1) at ../glib/glib/gmain.c:4343
#27 0x00007f16beaeb15c in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) (this=0x55931e5978c0, flags=...) at kernel/qeventdispatcher_glib.cpp:423
#28 0x00007f16bea9b004 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) (this=this@entry=0x7ffc9f982350, flags=..., flags@entry=...) at ../../include/QtCore/../../src/corelib/global/qflags.h:69
#29 0x00007f16bea9c4a3 in QCoreApplication::exec() () at ../../include/QtCore/../../src/corelib/global/qflags.h:121
#30 0x00007f16bef3bed2 in QGuiApplication::exec() () at kernel/qguiapplication.cpp:1870
#31 0x000055931d9b8d4e in main(int, char**) (argc=<optimized out>, argv=<optimized out>) at /usr/src/debug/baloo/baloo-5.108.0/src/file/extractor/main.cpp:43
[Inferior 1 (process 7442) detached]
e o Kioslave5:
Application: kioslave5 (kioslave5), signal: Segmentation fault
[KCrash Handler]
#4  0x00007f0214052dbf in sqfs_init () at /usr/lib/libsquashfuse.so.0
#5  0x00007f0214052f0b in sqfs_open_image () at /usr/lib/libsquashfuse.so.0
#6  0x00007f02140a680c in appimage::core::impl::TraversalType2::TraversalType2(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) () at /usr/lib/libappimage.so.1.0
#7  0x00007f02140a6ada in  () at /usr/lib/libappimage.so.1.0
#8  0x00007f02140a6c69 in appimage::core::PayloadIterator::PayloadIterator(appimage::core::AppImage const&) () at /usr/lib/libappimage.so.1.0
#9  0x00007f02140a6cce in appimage::core::AppImage::files() const () at /usr/lib/libappimage.so.1.0
#10 0x00007f02140ae0a3 in appimage::utils::PayloadEntriesCache::readAllEntries() () at /usr/lib/libappimage.so.1.0
#11 0x00007f02140afe9e in appimage::utils::PayloadEntriesCache::buildCache() () at /usr/lib/libappimage.so.1.0
#12 0x00007f02140b02a2 in appimage::utils::PayloadEntriesCache::PayloadEntriesCache(appimage::core::AppImage const&) () at /usr/lib/libappimage.so.1.0
#13 0x00007f02140b02fe in appimage::utils::ResourcesExtractor::ResourcesExtractor(appimage::core::AppImage const&) () at /usr/lib/libappimage.so.1.0
#14 0x00007f02140a74cf in appimage_read_file_into_buffer_following_symlinks () at /usr/lib/libappimage.so.1.0
#15 0x00007f0214198530 in  () at /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so
#16 0x00007f021d35c8c9 in  () at /usr/lib/qt/plugins/kf5/kio/thumbnail.so
#17 0x00007f021d3625d5 in  () at /usr/lib/qt/plugins/kf5/kio/thumbnail.so
#18 0x00007f021d251a14 in  () at /usr/lib/libKF5KIOCore.so.5
#19 0x00007f021d24e106 in KIO::SlaveBase::dispatch(int, QByteArray const&) () at /usr/lib/libKF5KIOCore.so.5
#20 0x00007f021d24625e in KIO::SlaveBase::dispatchLoop() () at /usr/lib/libKF5KIOCore.so.5
#21 0x00007f021d35e2c2 in kdemain () at /usr/lib/qt/plugins/kf5/kio/thumbnail.so
#22 0x00005569b1a121fd in  ()
#23 0x00007f021ca39850 in  () at /usr/lib/libc.so.6
#24 0x00007f021ca3990a in __libc_start_main () at /usr/lib/libc.so.6
#25 0x00005569b1a12455 in  ()
[Inferior 1 (process 10105) detached]
Se puderem ajudar, eu agradeço muito!
Obs.: Baixei os sinais de depuração do Plasma
Adendo: Problema resolvido na atualização do splashfuse 4
Boa tarde. Tente instalar o fuse
sudo pacman -S fuse
Tentei e não resolveu.
Resolvi o problema!!!
Era um problema com o Squashfuse. Portanto, para o pessoal que passar pelo mesmo problema segue a solução!
Baixe o downgrade
sudo pacman -S downgrade
Depois abaixa o squashfuse para o 2.0
sudo downgrade squashfuse
e voilá!
fonte: Kioslave5 closed unexpectedly - Issues & Assistance - Garuda Linux Forum
Po, era so o empacotador ter empacotado o squashfuse 2.0 junto, é ■■■■, appimage é ótimo, mas os caras deixa dependência de fora.
Eu me importo de baixar um executável maior não, eu so não quero ter problema.
