Estou tentando entrar na versão 1.8.9, mas está dando o seguinte erro:
Último log:
[11:21:19] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[11:21:19] [main/INFO]: Using primary tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[11:21:19] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLTweaker
[11:21:19] [main/INFO]: Forge Mod Loader version 11.15.1.2318 for Minecraft 1.8.9 loading
[11:21:19] [main/INFO]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_202, running on Linux:amd64:6.3.13_1, installed at /home/andrade/.minecraft/runtime/jre-legacy/linux/jre-legacy
[11:21:19] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[11:21:19] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[11:21:19] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[11:21:19] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:21:21] [main/INFO]: Found valid fingerprint for Minecraft Forge. Certificate fingerprint e3c3d50c7c986df74c645c0ac54639741c90a557
[11:21:21] [main/INFO]: Found valid fingerprint for Minecraft. Certificate fingerprint cd99959656f753dc28d863b46769f7f8fbaefcfc
[11:21:21] [main/INFO]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[11:21:21] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[11:21:21] [main/INFO]: Loading tweak class name net.minecraftforge.fml.common.launcher.TerminalTweaker
[11:21:21] [main/INFO]: Calling tweak class net.minecraftforge.fml.common.launcher.TerminalTweaker
[11:21:21] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[11:21:22] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_202]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_202]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_202]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_202]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Caused by: java.lang.UnsatisfiedLinkError: /home/andrade/.minecraft/bin/b8c2639d20d740bb180fc8d9d7c94f3f00ae1a31/liblwjgl64.so: libXxf86vm.so.1: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method) ~[?:1.8.0_202]
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941) ~[?:1.8.0_202]
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857) ~[?:1.8.0_202]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_202]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_202]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_202]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:87) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at net.minecraft.client.Minecraft.func_71386_F(Minecraft.java:2756) ~[ave.class:?]
at net.minecraft.client.main.Main.main(SourceFile:41) ~[Main.class:?]
... 6 more
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: net.minecraftforge.fml.relauncher.FMLSecurityManager$ExitTrappedException
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraftforge.fml.relauncher.FMLSecurityManager.checkPermission(FMLSecurityManager.java:30)
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.SecurityManager.checkExit(SecurityManager.java:761)
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.Runtime.exit(Runtime.java:107)
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at java.lang.System.exit(System.java:971)
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraft.launchwrapper.Launch.launch(Launch.java:138)
[11:21:22] [main/INFO]: [java.lang.ThreadGroup:uncaughtException:1052]: at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
