Emergency mode no CachyOS
Depois um desligamento forçado (no botão) do meu desktop, meu sistema CachyOS só boota no Emergency Mode,
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
[ OK ] Reached target Local File Systems.
Starting Rule-based Manager for Device Events and Files...
[ OK ] Finished Virtual Console Setup.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Started Journal Service.
Starting Create System Files and Directories...
[ OK ] Finished Create System Files and Directories.
[ 1.978393]
[ OK ] Finished Coldplug All udev Devices.
	Starting Show Plymouth Boot Screen...
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, or "exit" to continue bootup.
Cannot open access to console, the root account is locked. See sulogin(8) man page for more details.
Press Enter to continue.
Eu pesquisei sobre e vi vários casos parecidos, mas não consegui utilizar as mesmas soluções para o meu, eu bootei um Live USB do CachyOS nessa máquina, copiei o output do “journalctl -xb“ e tentei usar a ferramenta de chroot do próprio CachyOS, que teoricamente, resolveria o meu problema, mas ela dá erro,
[root@CachyOS liveuser]# cachy-chroot
Info: Found 4 block devices
Info: Found partition: Partition: /dev/sda1: FS: exfat UUID: 4E21-0000
Info: Found partition: Partition: /dev/sda2: FS: vfat UUID: 223C-F3F8
Info: Found partition: Partition: /dev/nvme0n1p1: FS: vfat UUID: 463E-2D73
Info: Found partition: Partition: /dev/nvme0n1p2: FS: btrfs UUID: d0218780-0ae3-434e-8532-0e72a37c67a2
✔ Select the block device for the root partition (use arrow keys):  · Partition: /dev/nvme0n1p2: FS: btrfs UUID: d0218780-0ae3-434e-8532-0e72a37c67a2
Info: Selected BTRFS partition, mounting and listing subvolumes...
Info: Mounting partition /dev/nvme0n1p2 at /tmp/cachyos-chroot-temp-mount-d0218780-0ae3-434e-8532-0e72a37c67a2-QpwVU2 with options: []
mount: /tmp/cachyos-chroot-temp-mount-d0218780-0ae3-434e-8532-0e72a37c67a2-QpwVU2: fsconfig() failed: File exists.
       dmesg(1) may have more information after failed mount system call.
Error: Failed to mount partition /dev/nvme0n1p2 at /tmp/cachyos-chroot-temp-mount-d0218780-0ae3-434e-8532-0e72a37c67a2-QpwVU2
Pelo que eu vi, o problema todo parece ter algo a ver com fstab, algo que eu sou bem leigo.
O sistema é um processador Ryzen 5 5500, GPU RTX 4060, 16GB de RAM, instalado em um SSD NVME de 1TB, só esse sistema no SSD e não tenho outros discos instalados.
Manda ele aqui
Perdão, mas eu não sei como seria a melhor forma de mandar um arquivo de 4886 linhas, eu deveria mandar só o início?
Joga no https://pastebin.com/ e compartilha o link
Não consegui postar a saída como pública nesse site, eu coloquei nesse link como um quebra galho Dontpad .
“Pastebin’s SMART filters have detected potentially offensive or questionable content in your Paste.
The content you are trying to publish has been deemed potentially offensive or questionable by our filters, because of this you’re receiving this warning.
This Paste can only be published with the visibility set to “Private”.”
Eu também usar btrfs check, mas ele reporta que está montado
Opening filesystem to check…
ERROR: /dev/sda2 is currently mounted, use --force if you really intend to check the filesystem
Mas quando eu tento desmontar usando umount, ele reporta que não está montado.
Da um btrfs check /dev/nvme0n1p2
sudo btrfs check /dev/nvme0n1p2
Checking filesystem on /dev/nvme0n1p2
[1/7] checking root items
[2/7] checking extents
[3/7] checking free space tree
[4/7] checking fs roots
[5/7] checking only csums items (without verifying data)
[6/7] checking root refs
[7/7] checking quota groups skipped (not enabled on this FS)
found 736168554496 bytes used, no error found
total csum bytes: 716918192
total tree bytes: 1890058240
total fs tree bytes: 949157888
total extent tree bytes: 156581888
btree space waste bytes: 242946146
file data blocks allocated: 1639896793088
referenced 792720752640
Ops, acho que estava apontando pro lugar errado
mkdir -p /mnt/btrfs
mount -o recovery /dev/nvme0n1p2 /mnt/btrfs
E rode o btrfs subvolume list /mnt/btrfs aparece certinho tipo @, @home, @snapshots, etc?
Se não aparecer, é o motivo do emergency mode
sudo mount -o recovery /dev/nvme0n1p2 /mnt/btrfs
mount: /mnt/btrfs: fsconfig() failed: btrfs: Unknown parameter 'recovery'.
Tira o recovery, falha minha
mount: /mnt/btrfs: can’t find in /etc/fstab.
Tenta mount -o subvol=@ /dev/nvme0n1p2 /mnt
Se não funcionar, aí eu ja não sei mais o que fazer.
mount: /mnt: fsconfig() failed: File exists.
Complicado isso
umount -R /mnt
e tenta de novo
Mesma coisa, exatamente a mesma mensagem
Faz pelo LiveCD
Eu consegui. Encontrei um problema similar em BTRFS: File system unmountable, no boot and access possible - #5 by DromundKaas - Newbie - EndeavourOS , usei as ferramentas do btrfs rescue seguindo a documentação deles (btrfs-rescue(8) — BTRFS documentation), que me levou a usar a opção zero-log, deu tudo certo, o disposito é montando e meu PC voltou a dar boot normal, muito obrigado pela ajuda!
Opa valeu por compartilhar!! Já vou deixar anotado aqui :+1:
