| File system | Continuous TRIM ( discard option) |
Periodic TRIM (fstrim) |
References and notes |
| Bcachefs | Yes | No | |
| Btrfs | Yes | Yes | Asynchronous discard is enabled by default since kernel 6.2. |
| exFAT | Yes | Yes | fstrim is supported since kernel 5.13, [4] |
| ext3 | Yes | Yes | |
| ext4 | Yes | Yes | “discard, nodiscard(*)” in [5] |
| F2FS | Yes | Yes | |
| JFS | Yes | Yes | [6] |
| NILFS2 | Yes | Yes | |
| NTFS | Yes | No | ntfs3 kernel driver only supports continuous TRIM. |
| No | Yes | NTFS-3G driver only supports periodic TRIM. | |
| VFAT | Yes | Yes | fstrim is supported since kernel 4.19, [7] |
| XFS | Yes | Yes | [8] |
| Swap | Yes | No | Not technically a “file system”, but TRIM is still relevant. The “once” option provides scheduled trimming at startup. See swapon(8). |
info
