Como usar meu mouse bluetooth?
Comprei um mouse da Logitech que funciona tanto pelo USB, quanto pelo bluetooth. Porém, na distro que estou usando, o bluetooth funciona somente para transferência de arquivos.
O que preciso instalar para que funcione? Não só com o mouse em específico, mas também, com fones bluetooth e outros periféricos.
Estou utilizando o Pop!_OS 21.04
Nos ajude a te ajudar, champs
  Kernel: 5.13.0-7620-generic x86_64 bits: 64 Desktop: GNOME 3.38.4
  Distro: Pop!_OS 21.04
Machine:
  Type: Convertible System: Positivo Tecnologia SA product: C464C v: N/A
  serial: <filter>
  Mobo: Positivo Tecnologia SA model: K116R v: 11174141 serial: <filter>
  UEFI: American Mdegatrends v: 1.07.X date: 07/13/2021
Battery:
  ID-1: BAT0 charge: 30.3 Wh condition: 37.0/37.0 Wh (100%)
CPU:
  Info: Dual Core model: Intel Celeron N4020 bits: 64 type: MCP
  L2 cache: 4 MiB
  Speed: 2714 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 2714 2: 2680
Graphics:
  Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
  Device-2: icSpring icspring camera type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting
  unloaded: fbdev,vesa resolution: 1280x720
  OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 21.2.2
Audio:
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
  driver: snd_hda_intel
  Sound Server: ALSA v: k5.13.0-7620-generic
Network:
  Message: No Device data found.
  Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
  driver: btusb,rtl8xxxu
  IF: wlx3095879a58ac state: up mac: <filter>
Bluetooth:
  Report: ID: hci0 state: up running pscan iscan inquiry bt-v: 2.1
  address: <filter>
Drives:
  Local Storage: total: 172.27 GiB used: 24.55 GiB (14.3%)
  ID-1: /dev/mmcblk0 vendor: BIWIN model: N/A size: 57.66 GiB
  ID-2: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1
Partition:
  ID-1: / size: 103.95 GiB used: 21.85 GiB (21.0%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 497 MiB used: 355.2 MiB (71.5%) fs: vfat
  dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) dev: /dev/dm-0
Sensors:
  System Temperatures: cpu: 56.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 242 Uptime: 17m Memory: 3.66 GiB used: 1.94 GiB (53.1%)
  Shell: Bash inxi: 3.3.01
Olá @aleeef tudo bem contigo?
Ao que tudo indica o chip bluetooth que veio integrado no seu notebook é um daqueles “complicados” de deixar redondinho. Encontrei este tutorial indicando a compilação do driver para conseguir ter todas as funcionalidades do chip.
Se nada der certo, talvez valha a pena considerar um adaptador USB bluetooth com um histórico melhor de compatibilidade.
:vulcan_salute:
Vou dar um chute e assumir que tu não fala inglês, e talvez tu siga aqueles passos cegamente, e acabe fazendo algo errado. Então eu vou explicar aqui o que deve ser feito com aquele driver.
Antes de tudo, vamos ter certeza de que a distro está preparada para o uso de dkms:
$ sudo apt install build-essential dkms
Instale os outros pacotes necessários, se esse já não estiverem presentes:
$ sudo apt install git libelf-dev
Acabei de checar aqui e o repositório do driver ainda está de pé:
$ git clone https://github.com/lwfinger/rtl8723bu.git
Aqui ele entra em root pra listar o driver velho na blacklist:
$ sudo -i
$ echo blacklist rtl8xxxu >> /etc/modprobe.d/blacklist.conf
$ exit
Agora entre no repositório que você clonou do git:
$ cd rtl8723bu
E execute esses comandos para instalar o driver em DKMS:
$ source dkms.conf
$ sudo mkdir /usr/src/$PACKAGE_NAME-$PACKAGE_VERSION
$ sudo cp -r core hal include os_dep platform dkms.conf Makefile rtl8723b_fw.bin /usr/src/$PACKAGE_NAME-$PACKAGE_VERSION
$ sudo dkms add $PACKAGE_NAME/$PACKAGE_VERSION
$ sudo dkms autoinstall $PACKAGE_NAME/$PACKAGE_VERSION
Eu não sei se esses comandos são todos necessários, não é asism que eu instalo drivers com o DKMS no meu PC. Mas eu também não vejo nenhuma razão para não funcionar.
– Boa sorte.
Gostaria de usar no bluetooth justamente para poupar uma entrada USB. O notebook que estou usando tem somente duas portas e uma delas já utilizada para o pendrive no roda minha distro roda.
Vou ler certinho tudo o que me passou!
Eu sou um estudante ainda e, por isso, estou estudando inglês ainda. Não sigo os passos cegamente. Quando vejo um site em inglês, leio o que sei e o resto eu traduzo. A única coisa que instalei com foi um app que deixa as opções bluetooth mais claras e fáceis de mexer (se não me engano, foi o blueman, ou algo assim)
Vou fazer o que tu me disseste e trago o feedback aqui mesmo
Este link leva pra uma página sobre um adaptador Wi-fi… não entendi
Seu notebook possui o chip WiFi e Bluetooth integrados na mesma placa, esse é o motivo do link.
Mas, com base no modelo que você identificou é possível procurar por outras soluções além da complicação do driver.
:vulcan_salute:
O driver do hardware Wi-Fi/Bluetooth to seu PC não é disponível originalmente. Você precisa instalá-lo via dkms, como eu mostrei no post. O que eu fiz foi simplesmente traduzir o link do @eddiecsilva com as informações de forma um pouco mais coesa. Siga os passos que eu lhe sugeri, e envie aqui o resultado.
Todos os comandos executados com sucesso. Agora é só reiniciar para ver se dá certo ou preciso algo mais?
Se executaram com sucesso, ao reiniciar o PC deve carregar o driver.
Quando reiniciei, apareceram duas opções de Wi-Fi e agora não consigo me conectar a nenhum Wi-Fi. Vou reinstalar o sistema, já estava ocorrendo outro problema mesmo.
Reinstalei o sistema e o mouse conectou normalmente. Obrigado mesmo assim pelo esforço :wink:
Sugiro adotar um programa de recuperação do sistema operacional como o Timeshift, vai te economizar um tempo reinstalando sistemas.
Apenas tenha em mente que por padrão ele resguarda o sistema e não seus dados de usuário. :wink:
:vulcan_salute:
Não precisa disso. Tudo o que tenho nesse laptop está em nuvem, tanto os sabes dos games quanto outros arquivos
