estou usando brave-browser e os videos do youtube andam travando muito, então abri ele pelo terminal pra e me apareceu esse problema e outros tambem que acredito esta relacionado ao primeiro. quando instalei o linux mint xfce sem atualizar o brave estava funcionando perfeitamente, depois de instalar as atualizações aconteceu isso.
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null) [6056:6056:0222/092825.192953:ERROR:vaapi_wrapper.cc(417)] vaInitialize failed: unknown libva error [6056:6056:0222/092825.837041:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization libva error: va_getDriverName() failed with unknown libva error,driver_name=(null) [6084:6084:0222/092826.469626:ERROR:vaapi_wrapper.cc(417)] vaInitialize failed: unknown libva error [6031:6048:0222/092826.753996:ERROR:dat_file_util.cc(22)] GetDATFileData: the dat file is not found or corrupted /home/usuario/.config/BraveSoftware/Brave-Browser/jpolmkeojnkicccihhepfbkhcbicimpa/1.0.367/rs-1FEAF960-F377-11E8-8EB2-F2801F1B9FD1.dat [6031:6031:0222/092826.889130:ERROR:ad_block_base_service.cc(209)] Could not obtain ad block data
meu sistema
System: Host: NetBook Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic Machine: Type: Desktop System: PHILCO product: 10D v: N/A serial: <filter> Mobo: PHILCO model: 10D serial: <filter> BIOS: American Megatrends v: 1.01.BRI date: 06/26/2012 Battery: ID-1: BAT0 charge: 11.1 Wh condition: 11.1/24.4 Wh (45%) model: standard status: Full CPU: Topology: Dual Core model: Intel Atom N2600 bits: 64 type: MT MCP arch: Saltwell rev: 1 L2 cache: 512 KiB flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 12768 Speed: 1197 MHz min/max: 600/1600 MHz Core speeds (MHz): 1: 1197 2: 1197 3: 1596 4: 1596 Graphics: Device-1: Intel Atom Processor D2xxx/N2xxx Integrated Graphics vendor: Holco Enterprise Co /Shuttle driver: gma500 v: N/A bus ID: 00:02.0 Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa resolution: 1024x600~60Hz OpenGL: renderer: llvmpipe (LLVM 9.0 128 bits) v: 3.3 Mesa 19.2.8 direct render: Yes Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Holco Enterprise Co /Shuttle driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Sound Server: ALSA v: k5.3.0-40-generic Network: Device-1: JMicron JMC250 PCI Express Gigabit Ethernet vendor: Holco Enterprise Co /Shuttle driver: jme v: 1.0.8 port: e000 bus ID: 01:00.5 IF: enp1s0f5 state: down mac: <filter> Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter vendor: AzureWave AW-NE139H Half-size Mini PCIe Card driver: rtl8192ce v: kernel port: d000 bus ID: 02:00.0 IF: wls1 state: up mac: <filter> Drives: Local Storage: total: 298.09 GiB used: 9.87 GiB (3.3%) ID-1: /dev/sda vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB Partition: ID-1: / size: 292.41 GiB used: 9.87 GiB (3.4%) fs: ext4 dev: /dev/sda1 Sensors: System Temperatures: cpu: 62.0 C mobo: N/A Fan Speeds (RPM): N/A Info: Processes: 191 Uptime: 51m Memory: 1.93 GiB used: 806.7 MiB (40.9%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
