Áudio sumiu do nada!
Fui instalar o studio do tiktok na minha máquina, utlizando o wine. Não instalou e fiquei sem áudio no pc. Setup do meu pc e defeito descrito nas prints
Tente reinstalar os pacotes e reinicie depois a máquina
sudo apt update && sudo apt install --reinstall linux-firmware alsa-firmware-loaders
Não deu certo !
lspci -k
Para ver se o modulo está carregando
Tente
rm -r ~/.config/pulse
systemctl --user restart wireplumber pipewire pipewire-pulse
deu isto aqui no terminal
davi@davi-GIFA-T81D11:\~$ lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Root Complex
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 IOMMU
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] Zeppelin Switch Upstream (PCIE SW.US)
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Zeppelin Switch Upstream (PCIE SW.US)
Kernel driver in use: pcieport
Kernel modules: shpchp
00:08.0 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:08.2 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. \[AMD\] FCH SMBus Controller (rev 61)
Subsystem: Advanced Micro Devices, Inc. \[AMD\] FCH SMBus Controller
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. \[AMD\] FCH LPC Bridge (rev 51)
Subsystem: Advanced Micro Devices, Inc. \[AMD\] FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. \[AMD\] Raven/Raven2 Device 24: Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. \[AMD\] Device 43bc (rev 02)
Subsystem: ASMedia Technology Inc. Device 1142
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
01:00.1 SATA controller: Advanced Micro Devices, Inc. \[AMD\] Device 43b8 (rev 02)
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
Kernel modules: ahci
01:00.2 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] Device 43b3 (rev 02)
Subsystem: ASMedia Technology Inc. Device 0201
02:04.0 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] 300 Series Chipset PCIe Port (rev 02)
Subsystem: ASMedia Technology Inc. 300 Series Chipset PCIe Port
02:05.0 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] 300 Series Chipset PCIe Port (rev 02)
02:06.0 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] 300 Series Chipset PCIe Port (rev 02)
02:07.0 PCI bridge: Advanced Micro Devices, Inc. \[AMD\] 300 Series Chipset PCIe Port (rev 02)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Kernel driver in use: r8169
Kernel modules: r8169
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. \[AMD/ATI\] Picasso/Raven 2 \[Radeon Vega Series / Radeon Vega Mobile Series\] (rev cc)
Subsystem: Advanced Micro Devices, Inc. \[AMD/ATI\] Picasso/Raven 2 \[Radeon Vega Series / Radeon Vega Mobile Series\]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
07:00.1 Audio device: Advanced Micro Devices, Inc. \[AMD/ATI\] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
Subsystem: Advanced Micro Devices, Inc. \[AMD/ATI\] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
07:00.2 Encryption controller: Advanced Micro Devices, Inc. \[AMD\] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
07:00.3 USB controller: Advanced Micro Devices, Inc. \[AMD\] Raven2 USB 3.1
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Raven2 USB 3.1
07:00.6 Audio device: Advanced Micro Devices, Inc. \[AMD\] Family 17h/19h HD Audio Controller
Subsystem: Advanced Micro Devices, Inc. \[AMD\] Family 17h/19h HD Audio Controller
08:00.0 SATA controller: Advanced Micro Devices, Inc. \[AMD\] FCH SATA Controller \[AHCI mode\] (rev 61)
Subsystem: Advanced Micro Devices, Inc. \[AMD\] FCH SATA Controller \[AHCI mode\]
depois apareceu isso
davi@davi-GIFA-T81D11:\~$ rm -r \~/.config/pulse
Voltou ao normal !! Muito Obrigado !!!
Davi, depois de reiniciar o computador, o audio continuou funcionando normal?
não precisei dar restart no pc
Entendi, mas depois vale fazer um restart para checar se está funcionando certinho.
Uma vez eu tive um problema similar com audio após instalar um aplicativo de câmera no meu fedora. E toda vez que eu reiniciava o pc eu precisava rodar o comando novamente.
Por isso eu disse para você testar se o audio está se mantendo ok após o restart.
ok. vou fazer agora !
vc tem razão! sumiu o áudio. Vou ter que rodar o comando denovo !
Certo, então vamos tentar diagnosticar o problema. Minha suspeita é que seja algo parecido com o que aconteceu comigo: o aplicativo que instalei iriun webcan estava sobrescrevendo as configurações do meu pipewire com parâmetros inválidos e, com isso, o pipewire não conseguia subir sozinho.
Executa o seguinte comando e me informa a saída:
systemctl --user status wireplumber pipewire pipewire-pulse
Com ele vamos ver os status dos serviços.
Pois é, eu desinstalei o iriun webcam agora.
No terminal deu isso:
davi@davi-GIFA-T81D11:\~$ systemctl --user status wireplumber pipewire pipewire-pulse
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset>
Active: active (running) since Tue 2026-09-01 11:30:44 -03; 1min 11s ago
Main PID: 1679 (wireplumber)
Tasks: 6 (limit: 32690)
Memory: 9.3M (peak: 10.3M)
CPU: 317ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wirepl>
└─1679 /usr/bin/wireplumber
set 01 11:30:44 davi-GIFA-T81D11 systemd\[1660\]: Started wireplumber.service - M>
set 01 11:30:44 davi-GIFA-T81D11 wireplumber\[1679\]: SPA handle 'api.libcamera.e>
set 01 11:30:44 davi-GIFA-T81D11 wireplumber\[1679\]: PipeWire's libcamera SPA mi>
set 01 11:30:45 davi-GIFA-T81D11 wireplumber\[1679\]: BlueZ system service is not>
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: e>
TriggeredBy: ● pipewire.socket
Main PID: 1676 (pipewire)
Tasks: 3 (limit: 32690)
Memory: 6.0M (peak: 6.8M)
CPU: 169ms
lines 1-23
Então temos um suspeito em jogo kkkk
Percebi que a saída do systemctl truncou, faz o redirecionamento dela para o less através do seguinte comando e me informa a saída, por favor:
systemctl --user status wireplumber pipewire pipewire-pulse | less
IMPORTANTE: executa o comando logo após reiniciar o computador (antes de você executar esse comando que faz o audio voltar).
Isso é importante para conseguirmos ver o status mais que ele fica logo após o erro.
Dei restart 2 vezes e o áudio não sumiu, depois que desinstalei o irium.
Ah, perfeito!
Se não for utilizar o iriun webcam, acho que já achamos nossa solução :sweat_smile:.
Se for utilizar, ainda podemos buscar uma solução.
Nem vou usar o iriun. Muito Obrigado. Vou dar como resolvido!!
