Audio picotando
Boa tarde,
Estou com um problema no manjaro. O áudio parece que fica conectando e desconectando rapidamente e assim dá um efeito de áudio picotado. Achei que poderia ser um problema de mal contato, porém testei a distro pelo pendrive e tudo funciona perfeitamente.
Quando desconecto meu fone e microfone, continua bugando. Essa mensagem fica aparecendo e sumindo toda hora sem parar:
System:
  Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: KDE Plasma v: 5.26.3 Distro: Manjaro Linux base: Arch Linux
Machine:
  Type: Desktop Mobo: Colorful And Development model: H510M-T M.2 v: V20
    serial: <superuser required> UEFI: American Megatrends LLC. v: 5.19
    date: 08/19/2021
CPU:
  Info: quad core model: Intel Core i3-10105F bits: 64 type: MT MCP
    arch: Comet Lake rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 3087 high: 3708 min/max: 800/4400 cores: 1: 1700 2: 2687
    3: 3701 4: 3705 5: 3708 6: 3699 7: 3701 8: 1802 bogomips: 59216
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
    driver: amdgpu v: kernel arch: GCN-4 bus-ID: 01:00.0 temp: 36.0 C
  Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
    unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 2560x1080
  API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 550 / 550 Series
    (polaris12 LLVM 14.0.6 DRM 3.42 5.15.78-1-MANJARO) direct render: Yes
Audio:
  Device-1: Intel vendor: Realtek driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.21 running: no
  Sound Server-2: PulseAudio v: 16.1 running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 1.14 TiB used: 137.69 GiB (11.8%)
  ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
  ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
  ID-3: /dev/sdc type: USB vendor: HP model: v165w size: 7.61 GiB
Partition:
  ID-1: / size: 64.91 GiB used: 12.3 GiB (18.9%) fs: ext4 dev: /dev/sdb7
  ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb6
  ID-3: /home size: 226.81 GiB used: 125.4 GiB (55.3%) fs: ext4
    dev: /dev/sda4
Swap:
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sdb5
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 271 Uptime: 7m Memory: 15.5 GiB used: 2.88 GiB (18.6%)
  Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1299 Shell: Zsh
  v: 5.9 inxi: 3.3.23
Obs: eu tenho dualboot, será que isso pode influenciar de alguma maneira?
Imagino que o problema seja a utilização de dois servidores simultâneos para o som. Utilize somente um servidor para o som (ou PulseAudio, ou PipeWire).
Se for usar somente o PipeWire verifique se o pacote pipewire-pulse está instalado.
https://wiki.archlinux.org/title/PipeWire
@Rodrigo_Chile acredita que rodar dois servidores simultâneos para o som poderia ser o problema?
O pipewire é parte do Wayland. Mesmo rodando em Xorg e no Pulseaudio, se a distro tem suporte a Wayland ele aparece; o caso é verificar qual metapacote está instalado, se o manjaro-pulse ou o manjaro-pipewire.
Outra coisa é verificar se o problema deriva do kernel, se é HD ou SSD, quanto se tem de swap. Vc já olhou em live, o que descarta hardware… e não, dualboot não afeta em nada
Bom, tenho exatamente o mesmo problema que o colega, usando Pop_OS 22.04 com pipewire e X11. Nos meus fones de ouvido ouço constantemente quando dou pause nos áudios que o fone fica dando uns cliques do tipo “vai e volta”/ “conecta e desconecta”.
Além disso, em alguns momentos em sons mais altos, como um tiro de uma arma mais barulhenta no jogo CSGO, o som “vaza” um pouco pelos alto falantes do próprio notebook. É como se o som saísse normal pelo fone, mas 10% “estoura” no alto falante normal da base do notebook. Eu achei bizarro, mas tem ocorrido comigo. Descobri um dia que tive que tirar o fone do ouvido para ouvir alguém conversando comigo e ao atirar percebi um pouco “vazando” pelo alto falante de forma estranha.
Alguém conseguiria me ajudar também?
Eu tava usando o PulseAudio, mas troquei para o PipeWire trocando o running do PulseAudio para “no” e o problema é o mesmo. E sim, o pacote pipewire-pulse está instalado
Em ambos os metapacotes o problema é o mesmo. Excluindo as possibilidades, talvez o problema esteja nos outros que vc citou.
Meu sistema está instalado no SSD e o \home no HD. E estou utilizando 8gb de swap no SSD.
O problema é que não sei fazer um diagnóstico desses fatores para ver qual é o erro.
Vocês podiam testar com o kernel mais recente para ver se já foi corrigido e também testar com o kernel mais antigo para ver se o bug foi adicionado nos novos patch do kernel.
@Yesman o kernel na instalação pode ser diferente do que esta no pendrive, porque o instalador pode ter baixando atualização durante o processo de instalar.
Eu tentei utilizar o kernel 5.4 e o 5.10, mas o problema persiste. Em relação a uma nova versão, tentei utilizar o 5.19 e o 6.0.8 mas minha placa de vídeo simplesmente desliga quando tento iniciar o sistema após escolher a versão no grub
Na verdade estava dizendo o 4.9 e o 6.1, mas deixa para lá.
Foi mal, eu sou leigo nisso. Tava instalando as versões que aparecem disponíveis nas configurações e testando. De qlqr forma, testei a 4.19 mas o problema continua.
@carlosalves91 eu não resolvi meu problema, mas encontrei um jeito de evitar.
Instala o PipeWire e o WirePlumber e dps troca o perfil de áudio pra “Saída Surround Analógico 4.0 + Entrada Estéreo analógico”
Antes de instalar o WirePlumber, eu não tinha essa opção
Aproveitando o tópico sobre problemas de som, seria bom informar que quem tem uma placa de vídeo AMD da série RX 6000+, e obviamente a usa como placa de som pelo HDMI, pode estar experimentando problemas de som intermitente no Steam, (seja no Windows ou no linux), no caso do Windows, o problema pode ser solucionado iniciando o Steam como Administrador, já no linux, o problema desaparece ao usar o Steam como FlatPak, passei semanas fazendo testes e não cheguei a conclusão de quem é o culpado, mais a solução está aí.
Interessante, mas no meu caso não é um ruido estranho. É apenas uma ligeira desconexão e conexão do dispositivo de saída, dando a impressão de um áudio picotado.
