Ao atualizar o libreoffice da versão 6.3.5 para 6.4.2 ocorreu erro (na interface gráfica).
Fui para o terminal, dei um “sudo apt install -f” e obtive o seguinte resultado:
sudo apt install -f
[sudo] senha para elvio:
Corrigindo dependências… Pronto
The following additional packages will be installed:
libjuh-java libjurt-java libreoffice-common libreoffice-help-common libreoffice-help-de libreoffice-help-en-gb libreoffice-help-en-us libreoffice-help-es libreoffice-help-fr
libreoffice-help-it libreoffice-help-pt libreoffice-help-pt-br libreoffice-help-ru libreoffice-help-zh-cn libreoffice-help-zh-tw libreoffice-java-common libreoffice-l10n-de
libreoffice-l10n-en-gb libreoffice-l10n-en-za libreoffice-l10n-es libreoffice-l10n-fr libreoffice-l10n-it libreoffice-l10n-pt libreoffice-l10n-pt-br libreoffice-l10n-ru
libreoffice-l10n-zh-cn libreoffice-l10n-zh-tw libreoffice-math libreoffice-pdfimport libridl-java libuno-cppu3 libuno-cppuhelpergcc3-3 libuno-purpenvhelpergcc3-3 libuno-sal3
libuno-salhelpergcc3-3 libunoil-java libunoloader-java uno-libs-private
Pacotes sugeridos:
hunspell-dictionary-de | myspell-dictionary-de libreoffice-grammarcheck-de libreoffice-grammarcheck-en-gb mythes-en-gb libreoffice-grammarcheck-en-za libreoffice-help-en-za
mythes-en-za hyphen-es libreoffice-grammarcheck-es mythes-es libreoffice-grammarcheck-fr libreoffice-grammarcheck-it hunspell-dictionary-pt | myspell-dictionary-pt hyphen-pt
libreoffice-grammarcheck-pt mythes-pt libreoffice-grammarcheck-pt-br mythes-pt-br libreoffice-grammarcheck-ru hunspell-dictionary-zh-cn | myspell-dictionary-zh-cn hyphen-zh-cn
libreoffice-grammarcheck-zh-cn mythes-zh-cn hunspell-dictionary-zh-tw | myspell-dictionary-zh-tw hyphen-zh-tw libreoffice-grammarcheck-zh-tw mythes-zh-tw
Os pacotes a seguir serão REMOVIDOS:
uno-libs3
Os NOVOS pacotes a seguir serão instalados:
libjuh-java libjurt-java libridl-java libuno-cppu3 libuno-cppuhelpergcc3-3 libuno-purpenvhelpergcc3-3 libuno-sal3 libuno-salhelpergcc3-3 libunoil-java libunoloader-java
uno-libs-private
Os pacotes a seguir serão atualizados:
libreoffice-common libreoffice-help-common libreoffice-help-de libreoffice-help-en-gb libreoffice-help-en-us libreoffice-help-es libreoffice-help-fr libreoffice-help-it
libreoffice-help-pt libreoffice-help-pt-br libreoffice-help-ru libreoffice-help-zh-cn libreoffice-help-zh-tw libreoffice-java-common libreoffice-l10n-de libreoffice-l10n-en-gb
libreoffice-l10n-en-za libreoffice-l10n-es libreoffice-l10n-fr libreoffice-l10n-it libreoffice-l10n-pt libreoffice-l10n-pt-br libreoffice-l10n-ru libreoffice-l10n-zh-cn
27 pacotes atualizados, 11 pacotes novos instalados, 1 a serem removidos e 1 não atualizados.
16 pacotes não totalmente instalados ou removidos.
É preciso baixar 0 B/70,4 MB de arquivos.
Depois desta operação, 11,9 MB de espaço em disco serão liberados.
Você quer continuar? [S/n]
Extraindo templates dos pacotes: 100%
(Lendo banco de dados … 442728 ficheiros e directórios actualmente instalados.)
A preparar para desempacotar …/libreoffice-math_1%3a6.4.2-0ubuntu0.18.04.2_amd64.deb …
A descompactar libreoffice-math (1:6.4.2-0ubuntu0.18.04.2) sobre (1:6.3.5~rc2-0ubuntu0.18.04.1~lo1) …
dpkg: erro ao processar o arquivo /var/cache/apt/archives/libreoffice-math_1%3a6.4.2-0ubuntu0.18.04.2_amd64.deb (–unpack):
a tentar sobre-escrever ‘/usr/lib/libreoffice/share/config/soffice.cfg/modules/smath/menubar/menubar.xml’, que também está no pacote libreoffice-common 1:6.3.5~rc2-0ubuntu0.18.04.1~lo1
dpkg-deb: erro: colar subprocess was killed by signal (Pipe quebrado)
Restoring backup of /usr/share/doc/libreoffice-math …
E: Sub-process /usr/bin/dpkg returned an error code (1)
Como estou em “homeoffice”, estou postando para ver se alguém já passou pela mesma situação e se tem solução, tipo, remover completamente o libreoffice e instalar novamente (ou instalar via flatpak)… enfim, aguardo sugestões.
editando…
como tenho que ter o pacote instalado tb para minhas atividades, no momento, para resolver, baixei os pacotes .deb e instalei manualmente.
depois terei que ver como adicionar um PPA válido para manter atualizado.
Também removi o PPA de Fontes de Aplicativos
