Adaptador Bluetooth
Pessoal, bom dia, Eu comprei um adaptador Bluetooth da F3 5.0 pra colocar no meu pc, no inicio ele abria o programa do Bluetooth mas não achava nenhum dispositivo para parear, comecei a ver uns tutoriais na internet e agora nem abre mais o programa. Podem me ajudar ? Pois preciso de Bluetooth na maquina pra aulas da faculdade. Uso o Mint, e estou numa briga lascada com isso.
Desde ja agradeço.
Aaaa só lembrando testei no window 11 e funcionou normal
o modelo do adaptador é rtl8761b
william@william-dell:~$ inxi -F --filter
System:
  Kernel: 5.4.0-91-generic x86_64 bits: 64 Desktop: Cinnamon 5.2.7
  Distro: Linux Mint 20.3 Una
Machine:
  Type: Desktop System: Dell product: OptiPlex 3040 v: N/A serial: <filter>
  Mobo: Dell model: 05XGC8 v: A01 serial: <filter> UEFI [Legacy]: Dell
  v: 1.18.1 date: 12/08/2021
CPU:
  Topology: Quad Core model: Intel Core i5-6500 bits: 64 type: MCP
  L2 cache: 6144 KiB
  Speed: 900 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900
Graphics:
  Device-1: Intel HD Graphics 530 driver: i915 v: kernel
  Display: x11 server: X.Org 1.20.13 driver: modesetting
  unloaded: fbdev,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.0.3
Audio:
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  driver: snd_hda_intel
  Device-2: Plantronics Plantronics Blackwire 3220 Series type: USB
  driver: plantronics,snd-usb-audio,usbhid
  Device-3: Lenovo Lenovo FHD Webcam type: USB
  driver: snd-usb-audio,uvcvideo
  Sound Server: ALSA v: k5.4.0-91-generic
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 4.48 TiB used: 1.44 TiB (32.2%)
  ID-1: /dev/sda model: SDLF1CRR-019T-1HAZ size: 1.75 TiB
  ID-2: /dev/sdb vendor: Western Digital model: WD30EZRX-00SPEB0
Partition:
  ID-1: / size: 287.37 GiB used: 55.55 GiB (19.3%) fs: ext4 dev: /dev/sda6
Sensors:
  System Temperatures: cpu: 47.5 C mobo: 29.8 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 216 Uptime: 1h 30m Memory: 7.68 GiB used: 1.29 GiB (16.8%)
  Shell: bash inxi: 3.0.38
Esse modelo de adaptador só funciona a partir do Kernel 5.8. Recomendo que use o Linux Mint Edge, pois ele vem com o Kernel mais recente fora da caixa. Ou faça o upgrade de Kernel usando a ferramenta do próprio Mint.
Referência: Realtek RTL8761B - LinuxReviews
Amigo, eu instalei o Kernel 13 e funcionou. muito obrigado de verdade, estava precisando por conta da faculdade. vlw de coração. Deus te abençoe
