Abri o Synaptic, reinstalei o CUPS, desinstalei os Driver Epson e nada.
Abri o CUPS pelo navegador, exclui a impressora e adicionei novamente e nada. dá esse erro
Não sei se ajuda, mas achei o log de erro…
E [27/Sep/2019:15:51:05 -0300] [Job 34] Unable to open raster stream - : Broken pipe
E [27/Sep/2019:15:51:05 -0300] [Job 34] Job stopped due to filter errors; please consult the error_log file for details.
D [27/Sep/2019:15:51:05 -0300] [Job 34] The following messages were recorded from 15:51:05 to 15:51:05
D [27/Sep/2019:15:51:05 -0300] [Job 34] Applying default options…
D [27/Sep/2019:15:51:05 -0300] [Job 34] Adding start banner page “none”.
D [27/Sep/2019:15:51:05 -0300] [Job 34] Adding end banner page “none”.
D [27/Sep/2019:15:51:05 -0300] [Job 34] File of type application/vnd.cups-pdf-banner queued by “watiley”.
D [27/Sep/2019:15:51:05 -0300] [Job 34] hold_until=0
D [27/Sep/2019:15:51:05 -0300] [Job 34] Queued on “EPSON_EPSON_L3150” by “watiley”.
D [27/Sep/2019:15:51:05 -0300] [Job 34] time-at-processing=1569610265
D [27/Sep/2019:15:51:05 -0300] [Job 34] 4 filters for job:
D [27/Sep/2019:15:51:05 -0300] [Job 34] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [27/Sep/2019:15:51:05 -0300] [Job 34] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [27/Sep/2019:15:51:05 -0300] [Job 34] gstoraster (application/vnd.cups-pdf to application/vnd.cups-raster, cost 99)
D [27/Sep/2019:15:51:05 -0300] [Job 34] /opt/epson-inkjet-printer-escpr/cups/lib/filter/epson-escpr-wrapper (application/vnd.cups-raster to printer/EPSON_EPSON_L3150, cost 0)
D [27/Sep/2019:15:51:05 -0300] [Job 34] job-sheets=none,none
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[0]=“EPSON_EPSON_L3150”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[1]=“34”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[2]=“watiley”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[3]=“Test Page”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[4]=“1”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[5]=“job-uuid=urn:uuid:4510288f-b686-3175-6470-a9ad347574e7 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1569610265 time-at-processing=1569610265”
D [27/Sep/2019:15:51:05 -0300] [Job 34] argv[6]="/var/spool/cups/d00034-001"
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[0]=“CUPS_CACHEDIR=/var/cache/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[1]=“CUPS_DATADIR=/usr/share/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[2]=“CUPS_DOCROOT=/usr/share/cups/doc-root”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[3]=“CUPS_FONTPATH=/usr/share/cups/fonts”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[4]=“CUPS_REQUESTROOT=/var/spool/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[5]=“CUPS_SERVERBIN=/usr/lib/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[6]=“CUPS_SERVERROOT=/etc/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[7]=“CUPS_STATEDIR=/run/cups”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[8]=“HOME=/var/spool/cups/tmp”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[9]=“PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[10]=“SERVER_ADMIN=root@WZD”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[11]=“SOFTWARE=CUPS/2.2.7”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[12]=“TMPDIR=/var/spool/cups/tmp”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[13]=“USER=root”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[14]=“CUPS_MAX_MESSAGE=2047”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[15]=“CUPS_SERVER=/run/cups/cups.sock”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[16]=“CUPS_ENCRYPTION=IfRequested”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[17]=“IPP_PORT=631”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[18]=“CHARSET=utf-8”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[19]=“LANG=pt_BR.UTF-8”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[20]=“PPD=/etc/cups/ppd/EPSON_EPSON_L3150.ppd”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[21]=“RIP_MAX_CACHE=128m”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[22]=“CONTENT_TYPE=application/vnd.cups-pdf-banner”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[23]=“DEVICE_URI=dnssd://EPSON%20L3150%20Series._pdl-datastream._tcp.local/”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[24]=“PRINTER_INFO=EPSON EPSON L3150 Series”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[25]=“PRINTER_LOCATION=”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[26]=“PRINTER=EPSON_EPSON_L3150”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[27]=“PRINTER_STATE_REASONS=none”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[28]=“CUPS_FILETYPE=document”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[29]=“FINAL_CONTENT_TYPE=application/vnd.cups-raster”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[30]=“AUTH_I****”
D [27/Sep/2019:15:51:05 -0300] [Job 34] Started filter /usr/lib/cups/filter/bannertopdf (PID 19076)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Started filter /usr/lib/cups/filter/pdftopdf (PID 19077)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Started filter /usr/lib/cups/filter/gstoraster (PID 19078)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Started filter /opt/epson-inkjet-printer-escpr/cups/lib/filter/epson-escpr-wrapper (PID 19079)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Started backend /usr/lib/cups/backend/dnssd (PID 19080)
D [27/Sep/2019:15:51:05 -0300] [Job 34] pdftopdf: Last filter determined by the PPD: epson-escpr-wrapper; FINAL_CONTENT_TYPE: application/vnd.cups-raster => pdftopdf will not log pages in page_log.
D [27/Sep/2019:15:51:05 -0300] [Job 34] execv failed: No such file or directory
D [27/Sep/2019:15:51:05 -0300] [Job 34] PDF template file doesn’t have form. It’s okay.
D [27/Sep/2019:15:51:05 -0300] [Job 34] PID 19079 (/opt/epson-inkjet-printer-escpr/cups/lib/filter/epson-escpr-wrapper) stopped with status 102 (No such file or directory)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Hint: Try setting the LogLevel to “debug” to find out more.
D [27/Sep/2019:15:51:05 -0300] [Job 34] Resolving “EPSON L3150 Series._pdl-datastream._tcp.local”…
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: +connecting-to-device
D [27/Sep/2019:15:51:05 -0300] [Job 34] Resolving “EPSON L3150 Series”, regtype="_pdl-datastream.tcp", domain=“local.”…
D [27/Sep/2019:15:51:05 -0300] [Job 34] OUTFORMAT="(null)", so output format will be CUPS/PWG Raster
D [27/Sep/2019:15:51:05 -0300] [Job 34] PID 19076 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [27/Sep/2019:15:51:05 -0300] [Job 34] PID 19077 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [27/Sep/2019:15:51:05 -0300] [Job 34] Color Manager: Calibration Mode/Off
D [27/Sep/2019:15:51:05 -0300] [Job 34] Calling FindDeviceById(cups-EPSON_EPSON_L3150)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Found device /org/freedesktop/ColorManager/devices/cups_EPSON_EPSON_L3150
D [27/Sep/2019:15:51:05 -0300] [Job 34] Calling org.freedesktop.ColorManager.Device.Get(ProfilingInhibitors)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Calling GetProfileForQualifiers(RGB.PLAIN_NORMAL…)
D [27/Sep/2019:15:51:05 -0300] [Job 34] Failed to send: org.freedesktop.ColorManager.Device.NothingMatched:nothing matched expression ‘RGB.PLAIN_NORMAL.,RGB.PLAIN_NORMAL.,RGB..,RGB..,*’
D [27/Sep/2019:15:51:05 -0300] [Job 34] Failed to get profile filename for cups-EPSON_EPSON_L3150
D [27/Sep/2019:15:51:05 -0300] [Job 34] Color Manager: no profiles specified in PPD
D [27/Sep/2019:15:51:05 -0300] [Job 34] Color Manager: ICC Profile: None
D [27/Sep/2019:15:51:05 -0300] [Job 34] Ghostscript using Any-Part-of-Pixel method to fill paths.
D [27/Sep/2019:15:51:05 -0300] [Job 34] Ghostscript command line: gs -dQUIET -dPARANOIDSAFER -dNOPAUSE -dBATCH -dNOINTERPOLATE -dNOMEDIAATTRS -dShowAcroForm -sstdout=%stderr -sOutputFile=%stdout -sDEVICE=cups -r360x360 -dDEVICEWIDTHPOINTS=595 -dDEVICEHEIGHTPOINTS=841 -dcupsBitsPerColor=8 -dcupsColorOrder=0 -dcupsColorSpace=1 -dcupsCompression=1 -scupsPageSizeName=A4 -I/usr/share/cups/fonts -c ‘<</.HWMargins[8.400000 8.400000 8.400024 8.399963] /Margins[0 0]>>setpagedevice’ -f -
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[12]=“USER=root”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[13]=“CUPS_MAX_MESSAGE=2047”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[14]=“CUPS_SERVER=/run/cups/cups.sock”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[15]=“CUPS_ENCRYPTION=IfRequested”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[16]=“IPP_PORT=631”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[17]=“CHARSET=utf-8”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[18]=“LANG=pt_BR.UTF-8”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[19]=“PPD=/etc/cups/ppd/EPSON_EPSON_L3150.ppd”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[20]=“RIP_MAX_CACHE=128m”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[21]=“CONTENT_TYPE=application/vnd.cups-pdf-banner”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[22]=“DEVICE_URI=dnssd://EPSON%20L3150%20Series._pdl-datastream._tcp.local/”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[23]=“PRINTER_INFO=EPSON EPSON L3150 Series”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[24]=“PRINTER_LOCATION=”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[25]=“PRINTER=EPSON_EPSON_L3150”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[26]=“PRINTER_STATE_REASONS=none”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[27]=“CUPS_FILETYPE=document”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[28]=“FINAL_CONTENT_TYPE=application/vnd.cups-raster”
D [27/Sep/2019:15:51:05 -0300] [Job 34] envp[29]=“AUTH_INFO_REQUIRED=none”
D [27/Sep/2019:15:51:05 -0300] [Job 34] Start rendering…
D [27/Sep/2019:15:51:05 -0300] [Job 34] Processing page 1…
D [27/Sep/2019:15:51:05 -0300] [Job 34] Resolved as “socket://EPSOND78F7F.local:9100/”…
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -connecting-to-device,offline-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] Executing backend “/usr/lib/cups/backend/socket”…
D [27/Sep/2019:15:51:05 -0300] [Job 34] Looking up “EPSOND78F7F.local”…
D [27/Sep/2019:15:51:05 -0300] [Job 34] EPSOND78F7F.local=192.168.0.106
D [27/Sep/2019:15:51:05 -0300] [Job 34] hrDeviceDesc=“EPSON L3150 Series”
D [27/Sep/2019:15:51:05 -0300] [Job 34] prtMarkerColorantValue.1.1 = “black”
D [27/Sep/2019:15:51:05 -0300] [Job 34] prtMarkerColorantValue.1.2 = “cyan”
D [27/Sep/2019:15:51:05 -0300] [Job 34] prtMarkerColorantValue.1.3 = “magenta”
D [27/Sep/2019:15:51:05 -0300] [Job 34] prtMarkerColorantValue.1.4 = “yellow”
D [27/Sep/2019:15:51:05 -0300] [Job 34] ATTR: marker-colors=#000000,#00FFFF,#FF00FF,#FFFF00
D [27/Sep/2019:15:51:05 -0300] [Job 34] ATTR: marker-names=’“Black Ink Bottle”’,’“Cyan Ink Bottle”’,’“Magenta Ink Bottle”’,’“Yellow Ink Bottle”’
D [27/Sep/2019:15:51:05 -0300] [Job 34] ATTR: marker-types=ink,ink,ink,ink
D [27/Sep/2019:15:51:05 -0300] [Job 34] ATTR: marker-levels=-1,-1,-1,-1
D [27/Sep/2019:15:51:05 -0300] [Job 34] new_supply_state=0, change_state=ffff
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -developer-low-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -developer-empty-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -marker-supply-low-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -marker-supply-empty-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -opc-near-eol-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -opc-life-over-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -toner-low-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -toner-empty-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -waste-receptacle-almost-full-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -waste-receptacle-full-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -cleaner-life-almost-over-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -cleaner-life-over-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] new_state=0, change_state=ffff
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -media-empty-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -door-open-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -media-jam-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -input-tray-missing-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -output-tray-missing-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -marker-supply-missing-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -output-area-almost-full-report
D [27/Sep/2019:15:51:05 -0300] [Job 34] STATE: -output-area-full-warning
D [27/Sep/2019:15:51:05 -0300] [Job 34] backendWaitLoop(snmp_fd=5, addr=0x557d4c353538, side_cb=0x557d4b7a0360)
D [27/Sep/2019:15:51:05 -0300] [Job 34] PID 19080 (/usr/lib/cups/backend/dnssd) exited with no errors.
D [27/Sep/2019:15:51:05 -0300] [Job 34] Error: /ioerror in --showpage–
D [27/Sep/2019:15:51:05 -0300] [Job 34] Operand stack:
D [27/Sep/2019:15:51:05 -0300] [Job 34] true (/tmp/gs_YhAx17) --nostringval-- 1 true
D [27/Sep/2019:15:51:05 -0300] [Job 34] Execution stack:
D [27/Sep/2019:15:51:05 -0300] [Job 34] %interp_exit .runexec2 --nostringval-- showpage --nostringval-- 2 %stopped_push --nostringval-- showpage showpage false 1 %stopped_push 2045 2 3 %oparray_pop 2044 2 3 %oparray_pop 2025 2 3 %oparray_pop showpage 2026 4 3 %oparray_pop showpage showpage 2 1 1 showpage %for_pos_int_continue 2029 4 7 %oparray_pop showpage showpage 1890 3 9 %oparray_pop showpage showpage
D [27/Sep/2019:15:51:05 -0300] [Job 34] Dictionary stack:
D [27/Sep/2019:15:51:05 -0300] [Job 34] --dict:969/1684(ro)(G)-- --dict:1/20(G)-- --dict:82/200(L)-- --dict:82/200(L)-- --dict:133/256(ro)(G)-- --dict:312/450(ro)(G)-- --dict:32/32(L)-- --dict:6/9(L)-- --dict:7/20(L)–
D [27/Sep/2019:15:51:05 -0300] [Job 34] Current allocation mode is local
D [27/Sep/2019:15:51:05 -0300] [Job 34] Last OS error: Broken pipe
D [27/Sep/2019:15:51:05 -0300] [Job 34] GPL Ghostscript 9.26: Unrecoverable error, exit code 1
D [27/Sep/2019:15:51:05 -0300] [Job 34] Rendering completed
D [27/Sep/2019:15:51:05 -0300] [Job 34] PID 19078 (/usr/lib/cups/filter/gstoraster) stopped with status 1.
D [27/Sep/2019:15:51:05 -0300] [Job 34] End of messages
D [27/Sep/2019:15:51:05 -0300] [Job 34] printer-state=3(idle)
D [27/Sep/2019:15:51:05 -0300] [Job 34] printer-state-message=“Rendering completed”
D [27/Sep/2019:15:51:05 -0300] [Job 34] printer-state-reasons=none
esse erro é chato de resolver
qual a saída do
df -h
para ver se está com espaço
teria que ver o var/log/cups/error_log
cat var/log/cups/error_log
por exemplo pode estar faltando algum pacote
exemplo
gcc-multilib
apt install gcc-multilib
Ontem a noite estava fazendo aquelas configurações de instalar o dnsmasq e smuddy ‘acho que é assim’ acabei embaralhando o sistema, não tinha mais internet…kkkkkk
utilizei a imagem que tinha feito pelo SYSTEMBACK e restaurei… voltou a internet e de lambuja voltou a imprimir…kkkkkk
@swatquest valeu pela atenção mais uma vez.
Sou iniciando no Linux, estou utilizando a distro Debian 9. Eu estava com esse mesmo problema e através de sua ajuda consegui resolver!!! Muito obrigado por compartilhar seus conhecimentos. Deus te abençoe.
