Sim, ja tentei todos os tutoriais possiveis kkkk
Instalar a versão compatível no ubuntu
To install Java 8 Update 231 (8u231) on Ubuntu, you must manually download the Oracle JDK/JRE 8u231 .tar.gz archive from the Oracle Java Archive, as it is no longer available in default repositories.
Prerequisites
Ubuntu Terminal access.
An Oracle account to download the file (required for older versions).
Download
jdk-8u231-linux-x64.tar.gzfrom the Oracle Java SE 8 Archive.
Step-by-Step Installation Instructions
Create a directory for Java:
bash
sudo mkdir -p /usr/local/java -
Move and Extract the Archive:
Assuming you downloaded the file to yourDownloadsfolder, move it and extract it:bash
cd ~/Downloads sudo tar -zxvf jdk-8u231-linux-x64.tar.gz -C /usr/local/java -
Set Up Environment Variables:
Open the/etc/profilefile to add the Java paths:bash
sudo nano /etc/profileAdd the following lines at the end of the file:
bash
JAVA_HOME=/usr/local/java/jdk1.8.0_231 PATH=$PATH:$HOME/bin:$JAVA_HOME/bin export JAVA_HOME export PATHSave and close the file (Ctrl+O, Enter, Ctrl+X).
Configure Update Alternatives:
Tell the system to use this specific Java version:bash
sudo update-alternatives --install "/usr/bin/java" "java" "/usr/local/java/jdk1.8.0_231/bin/java" 1 sudo update-alternatives --install "/usr/bin/javac" "javac" "/usr/local/java/jdk1.8.0_231/bin/javac" 1 -
Verify the Installation:
bash
java -version
Boa sorte
