Tentei instalar o SciLab pela própria pop_shop no pop_os 20.04 e o programa principal não funciona, os secundarios (Advanced e CLI) funcionam mas preciso do SciLab principal que não roda. Quando tento iniciá-lo pelo teminal tenho a seguinte saída:
Picked up _JAVA_OPTIONS: -Djava.class.path=/usr/share/java/flexdock.jar:/usr/share/java/skinlf.jar:/usr/share/java/looks.jar:/usr/share/java/commons-logging.jar:/usr/share/java/jhall.jar:/usr/share/java/lucene-core-4.10.4.jar:/usr/share/java/lucene-analyzers-common-4.10.4.jar:/usr/share/java/lucene-queryparser-4.10.4.jar:/usr/share/maven-repo/org/freehep/freehep-util/debian/freehep-util-debian.jar:/usr/share/maven-repo/org/freehep/freehep-io/debian/freehep-io-debian.jar:/usr/share/maven-repo/org/freehep/freehep-graphicsio/debian/freehep-graphicsio-debian.jar:/usr/share/java/freehep-graphicsio-emf-2.1.jar:/usr/share/java/freehep-graphics2d-2.1.1.jar:/usr/share/java/jrosetta-API.jar:/usr/share/java/jrosetta-engine-1.0.4.jar:/usr/share/java/jgraphx.jar:/usr/share/java/jogl2.jar:/usr/share/java/gluegen2-rt.jar:/usr/share/java/jeuclid-core.jar:/usr/share/java/jlatexmath-fop-1.0.7.jar:/usr/share/java/fop.jar:/usr/share/java/saxon.jar:/usr/share/java/batik.jar:/usr/share/java/xml-apis-ext.jar:/usr/share/java/commons-io.jar:/usr/share/java/xmlgraphics-commons.jar:/usr/share/java/avalon-framework.jar:/usr/share/java/jlatexmath-1.0.7.jar:/usr/share/java/ecj.jar:/usr/share/java/javax.activation.jar:/usr/share/java/jaxb-runtime.jar:/usr/share/scilab/modules/graphic_objects/jar/org.scilab.modules.graphic_objects.jar:/usr/share/scilab/modules/completion/jar/org.scilab.modules.completion.jar:/usr/share/scilab/modules/history_browser/jar/org.scilab.modules.history_browser.jar:/usr/share/scilab/modules/scinotes/jar/org.scilab.modules.scinotes.jar:/usr/share/scilab/modules/xcos/jar/org.scilab.modules.xcos.jar:/usr/share/scilab/modules/commons/jar/org.scilab.modules.commons.jar:/usr/share/scilab/modules/scirenderer/jar/scirenderer.jar:/usr/share/scilab/modules/ui_data/jar/org.scilab.modules.ui_data.jar:/usr/share/scilab/modules/javasci/jar/org.scilab.modules.javasci.jar:/usr/share/scilab/modules/localization/jar/org.scilab.modules.localization.jar:/usr/share/scilab/modules/gui/jar/org.scilab.modules.gui.jar:/usr/share/scilab/modules/core/jar/org.scilab.modules.core.jar:/usr/share/scilab/modules/history_manager/jar/org.scilab.modules.history_manager.jar:/usr/share/scilab/modules/jvm/jar/org.scilab.modules.jvm.jar:/usr/share/scilab/modules/action_binding/jar/org.scilab.modules.action_binding.jar:/usr/share/scilab/modules/graphic_export/jar/org.scilab.modules.graphic_export.jar:/usr/share/scilab/modules/preferences/jar/org.scilab.modules.preferences.jar:/usr/share/scilab/modules/external_objects_java/jar/org.scilab.modules.external_objects_java.jar:/usr/share/scilab/modules/helptools/jar/scilab_ru_RU_help.jar:/usr/share/scilab/modules/helptools/jar/scilab_images.jar:/usr/share/scilab/modules/helptools/jar/org.scilab.modules.helptools.jar:/usr/share/scilab/modules/helptools/jar/scilab_en_US_help.jar:/usr/share/scilab/modules/renderer/jar/org.scilab.modules.renderer.jar:/usr/share/scilab/modules/types/jar/org.scilab.modules.types.jar:/usr/share/scilab/modules/console/jar/org.scilab.modules.console.jar:/usr/share/scilab/modules/graph/jar/org.scilab.modules.graph.jar:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.scilab.modules.jvm.LibraryPath (file:/usr/share/scilab/modules/jvm/jar/org.scilab.modules.jvm.jar) to field java.lang.ClassLoader.sys_paths
WARNING: Please consider reporting this to the maintainers of org.scilab.modules.jvm.LibraryPath
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Could not access to the Main Scilab Class:
Exception in thread “main” java.lang.ExceptionInInitializerError
at org.scilab.modules.localization.Messages.gettext(Unknown Source)
at org.scilab.modules.commons.xml.XConfiguration.(Unknown Source)
at org.scilab.modules.core.Scilab.(Unknown Source)
Caused by: java.lang.NullPointerException
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2646)
at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:830)
at java.base/java.lang.System.loadLibrary(System.java:1870)
at org.scilab.modules.localization.MessagesJNI.(Unknown Source)
… 3 more
Scilab cannot create Scilab Java Main-Class (we have not been able to find the main Scilab class. Check if the Scilab and thirdparty packages are available).
Não entendo direito o que fazer para consertar isso. Sou novo em linux.
