Rider não inicia mais se estiver nos gráficos integrados da intel
Então, do dia pra noite o Rider não consegue mais iniciar quando estou nos gráficos integrados, o workoround tem sido fazer o switch para GPU dedicada Nvidia, porém ontem ele estava funcionando de boa.
Quando tento iniciar pelo terminal, ele me traz essa saida:
Invalid MIT-MAGIC-COOKIE-1 key
Start Failed
Failed to initialize graphics environment
java.awt.AWTError: Can't connect to X11 window server using ':99.0' as the value of the DISPLAY variable.
        at java.desktop/sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
        at java.desktop/sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:102)
        at java.base/java.security.AccessController.doPrivileged(Native Method)
        at java.desktop/sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:61)
        at java.base/java.lang.Class.forName0(Native Method)
        at java.base/java.lang.Class.forName(Class.java:315)
        at java.desktop/java.awt.GraphicsEnvironment$LocalGE.createGE(GraphicsEnvironment.java:101)
        at java.desktop/java.awt.GraphicsEnvironment$LocalGE.<clinit>(GraphicsEnvironment.java:83)
        at java.desktop/java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:129)
        at java.desktop/sun.awt.X11.XToolkit.<clinit>(XToolkit.java:233)
        at java.desktop/java.awt.Toolkit$2.run(Toolkit.java:588)
        at java.desktop/java.awt.Toolkit$2.run(Toolkit.java:583)
        at java.desktop/java.awt.Toolkit.getDefaultToolkit(Toolkit.java:582)
        at java.desktop/java.awt.Toolkit.getEventQueue(Toolkit.java:1499)
        at java.desktop/java.awt.EventQueue.invokeLater(EventQueue.java:1318)
        at com.intellij.idea.StartupUtil.lambda$scheduleInitUi$9(StartupUtil.java:347)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
        at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1$1.run(Executors.java:668)
        at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1$1.run(Executors.java:665)
        at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1.run(Executors.java:665)
        at java.base/java.lang.Thread.run(Thread.java:829)
Your JRE: 11.0.11+9-b1341.57 amd64 (JetBrains s.r.o.)
Estou usando a versão em flatpak por causa dos updates automáticos.
Minha distro no computador em questão é o openSUSE Leap 15.3.
Specs da máquina: i7 7500U (Intel HD 620, Mesa 20.2.4), 16gb de memória ram ddr4, 940MX, ssd 240gb para o / e um hd de 1tb para o /home.
Já tentei desinstalar, tirar as dependências com flatpak uninstall unused e instalar novamente, porém sem sucesso.
Acho que isso pode ajudar:
Infelizmente não funcionou. Até a dica do “xhost +” o bash deu que é um comando deconhecido :confused:
Tente usar a versão tarball fornecida pela JetBrains para ver se o mesmo ocorre… Pode ser algo da versão flatpak.
Acho improvavel, pois ontem mesmo ainda ainda funcionava e no meu desktop que usa o pacote mesa, por ser uma radeon, tá rodando de boa. O problema da versão .tar pra mim é por causa dos updates que não são automáticos : /
