E ai galera, tive um pequeno problema na minha tela, e acabei desligando o PC no botão. Dai quando fui ligar novamente. O sistema não esta conseguindo dar boot.
Sistema: Mint 19.3, com dual boot. Tenho um SSD que tem o windows + SWAP + raiz. No HD tenho a /home e o disco \D.
mensgem do erro:
You are in emergency mode! After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" or "exit" to boot into default mode. Pressione ENTER para manutenção
Algumas saídas(em liveCD):
Obs: minha raiz esta no sda6
root@mint:~# fdisk -l
Disk /dev/loop0: 1.8 GiB, 1948299264 bytes, 3805272 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Disklabel type: gpt
Disk identifier: 502B3AAB-A13F-4CD0-991A-382B9AC16E59
Device Start End Sectors Size Type
/dev/sda1 2048 1023998 1021951 499M EFI System
/dev/sda2 1024000 1228799 204800 100M EFI System
/dev/sda3 1228800 1261567 32768 16M Microsoft reserved
/dev/sda4 1261568 152653823 151392256 72.2G Microsoft basic data
/dev/sda5 152653824 161042431 8388608 4G Linux swap
/dev/sda6 161042432 234440869 73398438 35G Linux filesystem
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: CE0EB285-B82D-4DC8-A435-A68911FBF222
/dev/sdb1 34 524290047 524290014 250G Linux filesystem
/dev/sdb2 524290048 1784875007 1260584960 601.1G Microsoft basic data
/dev/sdb3 1784875008 1953523711 168648704 80.4G Linux filesystem
Partition 1 does not start on physical sector boundary.
Meu arquivo fstab esta desta forma:
root@mint:~# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda6 during installation
UUID=8370d1ea-0b59-4329-afe1-2d7b40a02e9a / ext4 errors=remount-ro 0 1
#(teintei desta forma, sem sucesso) /dev/sda6 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=57D5-4F08 /boot/efi vfat umask=0077 0 1
# /home was on /dev/sdb1 during installation
UUID=679a09d0-1c52-4524-920e-fff323c9365f /home ext4 defaults 0 2
# swap was on /dev/sda5 during installation
UUID=15a3733a-c947-4798-9093-ff8071387c7b none swap sw 0 0
root@mint:~# lsblk -f
NAME FSTYPE LABEL UUID MOUNTPOINT
loop0 squashfs /rofs
sda
├─sda1 vfat 57D5-4F08
├─sda2 vfat D6C7-79E0
├─sda3
├─sda4 ntfs 1066F0D166F0B914
├─sda5 swap 15a3733a-c947-4798-9093-ff8071387c7b [SWAP]
└─sda6 ext4 8370d1ea-0b59-4329-afe1-2d7b40a02e9a
sdb
├─sdb1 ext4 679a09d0-1c52-4524-920e-fff323c9365f
├─sdb2 ntfs 5C0FD34B13ACBFB3
└─sdb3 ext4 913ea9d7-813f-42db-999c-c1e6c675e723
sdc iso9660 Linux Mint 19.3 Cinnamon 64-bit 2019-12-13-16-58-44-00 /cdrom
├─sdc1 iso9660 Linux Mint 19.3 Cinnamon 64-bit 2019-12-13-16-58-44-00
└─sdc2 vfat Linux Mint 19.3 Cinnamon 64-bit 833C-CDB0
root@mint:~# journalctl -xb
encontrei este erro nos logs (em vermelho)
Tentei fazer algumas coisas, como alterar o arquivo fstab. Mudei UIDD para dev/sda6. Mudar as opções de errors=remount-ro, para defaults
Teitei rodar: fsck.ext4 /dev/sd6 , mas como a unidade estava montada, ele me voltava erro e abortava o processo.
Fiz entao um liveCD(USB) e rodando o mesmo comando, obtenho a mesma saida:
root@mint:~# fsck.ext4 /dev/sda6 e2fsck 1.44.1 (24-Mar-2018) /dev/sda6 is mounted. e2fsck: Cannot continue, aborting.
Alguem tem alguma ideia de como posso estar resolvendo este problema?
