Boa tarde, Pessoal! Tudo bem?
Tenho um PC e adoro ele, mas o barulho constante de um ventilador ligado sempre me incomodou. Ultimamente tá me irritando muito passar o dia com isso.
Tem alguma Fonte silenciosa ?
Obrigado!
EDIT----
A fonte atual é uma Thunder 600 da Mancer.
Preciso de uma fonte mais silenciosa mesmo
PC Completo
System:
Kernel: 6.9.3-76060903-generic x86_64 bits: 64 Desktop: GNOME 42.9
Distro: Pop!_OS 22.04 LTS
Machine:
Type: Desktop System: Gigabyte product: B450M DS3H V2 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H V2 v: x.x serial: <superuser required>
BIOS: American Megatrends LLC. v: F62 date: 01/27/2022
CPU:
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP cache:
L2: 3 MiB
Speed (MHz): avg: 2199 min/max: 2200/4650 cores: 1: 2200 2: 2200 3: 2199
4: 2199 5: 2199 6: 2199 7: 2199 8: 2199 9: 2200 10: 2200 11: 2199 12: 2199
Graphics:
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nvidia
v: 555.58.02
Device-2: Anker PowerConf C200 type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nouveau
unloaded: fbdev,modesetting,vesa failed: nvidia gpu: nvidia resolution:
1: 1360x768~60Hz 2: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 555.58.02
Audio:
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Anker PowerConf C200 type: USB
Device-4: FIFINE 683 Microphone type: USB driver: snd-usb-audio
Sound Server-1: ALSA v: k6.9.3-76060903-generic running: yes
Sound Server-2: JACK v: 1.9.20 running: yes
Sound Server-3: PipeWire v: 1.0.3 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp9s0 state: down mac: <filter>
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
driver: rtw_8822bu
IF: wlx5c628b9f5554 state: up mac: <filter>
IF-ID-1: br-f439921ab147 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives:
Local Storage: total: 1.62 TiB used: 175.71 GiB (10.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S500G size: 465.76 GiB
ID-2: /dev/sda model: MV240GB size: 238.47 GiB
ID-3: /dev/sdb vendor: XrayDisk model: 1TB SSD size: 953.87 GiB
Partition:
ID-1: / size: 229.73 GiB used: 72.96 GiB (31.8%) fs: ext4 dev: /dev/sda1
Swap:
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) dev: /dev/dm-0
ID-2: swap-2 type: zram size: 16 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors:
System Temperatures: cpu: 50.0 C mobo: 35.0 C gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Info:
Processes: 438 Uptime: 6h 7m Memory: 31.27 GiB used: 10.11 GiB (32.3%)
Shell: Bash inxi: 3.3.13
freeQ
Setembro 5, 2024, 6:38pm
2
Primeiro seria importante saber qual processador você tem, e mais importante que isso qual o TDP
não é pq é water cooler q é mais silencioso, até pelo contrario pois watter cooler alem de 3 fans tem uma bomba dagua.
Se quer referencia em cooler silencioso no pc, procure bequiet e noctua, se quiser pode até comprar um cooler mais simples e trocar somente os fans dele por noctua!
Antes de qualquer coisa: você tem certeza que o ruído está vindo do fan do cooler e não de um fan do gabinete?
Além disso, verificou se o dissipador não está sujo? Não está superaquecendo?
O cooler box da AMD (se for uma máquina AM4) não é para ser barulhento.
freeQ:
O TDP é uma medida importante, mas é preciso tomar cuidado. Isso porque existem processadores com um mesmo TDP e requisitos energéticos e de resfriamento bastante diferentes entre si.
Quanto ao water cooler, vale lembrar que existem opções com um, dois e três fans, que podem ser multiplicados por 2 no caso de configurações push-pull. De qualquer forma, a bomba é um ponto de fraqueza que sempre existirá e tende a dar defeito após alguns anos.
Water cooler em boa parte das vezes não compensa (já que o preço é elevado e muitos modelos entregam desempenho de air cooler de entrada). E outra, por mais que a chance seja baixa, eu já tive e o meu vazou bem em cima da placa de vídeo. Nunca mais eu compro esse tipo de coisa…
Vale a pena monitorar a temperatura do processador. Talvez a curva do ventilador esteja muito agressiva, já topando a velocidade mesmo em temperaturas médias. A tua placa tem a visualização da curva na BIOS? Coloca uma foto aqui se tiver.
Nunca fui de monitorar a temperatura.
Prestando mais atenção esses dias, acho que o real barulho está na fonte mesmo. Uma Thunder 600 da Mancer
As config do PC
Resumo
System:
Machine:
CPU:
L2: 3 MiB
Graphics:
v: 555.58.02
Audio:
Network:
driver: r8169
driver: rtw_8822bu
Bluetooth:
driver: btusb
address: <filter>
Drives:
Partition:
Swap:
Sensors:
Info:
Editei o post, agora minha dúvida tá certa. Foi mal.
help
Setembro 14, 2024, 10:29pm
8
Confirmado que é a fonte mesmo. Você pode limpar e lubrificar o rolamento do fan dela. Se quiser trocar mesmo é só focar em marcas conhecidas: corsair, cooler master, gigabyte, xpg, entre outras.
