Instalei o big linux e fui acessar a Radio disney no Brave porém não carrega o player. Houve o mesmo problema na radio Hunter.fm porém depois de uma atualização no navegador foi solucionada. Tentei outros navegadores e o problema persistiu com a inicialização do player da radio.
Informações:
System:
Kernel: 5.15.120-1-MANJARO arch: x86_64 bits: 64 Desktop: KDE Plasma
v: 5.27.6 Distro: BigLinux based in Manjaro Linux
Machine:
Type: Laptop System: Acer product: Aspire E5-573G v: V3.72
serial: <superuser required>
Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
serial: <superuser required> UEFI: Insyde v: 1.25 date: 07/15/2015
Battery:
ID-1: BAT1 charge: 14.2 Wh (100.0%) condition: 14.2/37.0 Wh (38.4%)
CPU:
Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 1535 min/max: 500/2700 cores: 1: 2357 2: 2183 3: 800
4: 800
Graphics:
Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: NVIDIA GK208BM [GeForce 920M] driver: N/A
Device-3: Sunplus Innovation HD WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: i965 gpu: i915 resolution: 1366x768~60Hz
API: OpenGL v: 4.6 Mesa 21.3.9 Amber renderer: Mesa DRI Intel HD Graphics
5500 (BDW GT2)
Audio:
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio
Device-3: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel
API: ALSA v: k5.15.120-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.74 status: active
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp2s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
IF: wlp3s0 state: up mac: <filter>
Drives:
Local Storage: total: 111.79 GiB used: 5.79 GiB (5.2%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
Partition:
ID-1: / size: 111.49 GiB used: 5.79 GiB (5.2%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 111.49 GiB used: 5.79 GiB (5.2%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 111.49 GiB used: 5.79 GiB (5.2%) fs: btrfs
dev: /dev/sda2
Swap:
ID-1: swap-1 type: zram size: 7.68 GiB used: 256 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: file size: 256 MiB used: 0 KiB (0.0%)
file: /swapfc/swapfile/1
Sensors:
System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 237 Uptime: 5h 29m Memory: total: 8 GiB available: 7.68 GiB
used: 1.91 GiB (24.9%) Shell: Zsh inxi: 3.3.28
