Problema na instalação do Wine (mono e Gecko)
Olá pessoal, estou com um problema faz dias com a instalação do wine, nunca prestei muita atenção nas informações que aparecem no terminal, mas dessa vez resolvi postar para vocês verem se consegue achar a tradução do erro:
[email protected]:~$ winecfg
wine: created the configuration directory ‘/home/financeiro/.wine’
0012:err:ole:marshal_object couldn’t get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
0012:err:ole:marshal_object couldn’t get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
0012:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0012:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0012:err:ole:get_local_server_stream Failed: 80004002
0014:err:ole:marshal_object couldn’t get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
0014:err:ole:marshal_object couldn’t get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
0014:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0014:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0014:err:ole:get_local_server_stream Failed: 80004002
0017:fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
0017:fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
0017:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0017:err:mscoree:LoadLibraryShim error reading registry key for installroot
001c:fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
001c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
001c:err:mscoree:LoadLibraryShim error reading registry key for installroot
001c:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
0017:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0022:fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
0022:fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
0022:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0022:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0010:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0010:fixme:dwmapi:DwmIsCompositionEnabled 0000000006F00434
0027:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x2e3306d, context 0x544100, init_notify 0, handle 0x7cffa00): stub
0010:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0043:fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
0043:fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
0043:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0043:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
0041:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0041:fixme:dwmapi:DwmIsCompositionEnabled 060DDD14
0048:fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x285f537, context 0x2a38b8, init_notify 0, handle 0x6ebfce8): stub
0041:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
wine: configuration in L"/home/financeiro/.wine" has been updated.
wine: Read access denied for device L"\??\Z:\", FS volume label and serial are not available.
Desde já agradeço!
Olá,você instalou o wine de qual forma? ja tentou reinstalar? Pretende Fazer o que com quais configurações? Tente Fazer um topico um pouco mais específico…
Dei uma pesquisada e percebi que muitos usuarios chegaram a esse erro ao executar um app 32bits,tente executar isso no terminal:
sudo dpkg --add-architecture i386
