Eaí galera, tudo bem? Atualizei o Manjaro Gnome agora mesmo e ao reiniciar o meu computador algumas aplicações estão no modo claro, não importa qual tema eu selecione elas sempre ficam no modo claro, alguma forma de resolver isso? Já tentei reinstalar o tema mas o problema persiste.
inxi -Fxz ✔
System:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: GNOME v: 42.1 Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 11/13/2019
CPU:
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1545 high: 2072 min/max: 1550/3400 boost: enabled
cores: 1: 1920 2: 1745 3: 1474 4: 1364 5: 1463 6: 1515 7: 2072 8: 1508
9: 1363 10: 1375 11: 1371 12: 1376 bogomips: 81470
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 08:00.0
Device-2: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon gpu: amdgpu
resolution: 1920x1080~70Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Audio:
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Device-3: A4Tech REDRAGON Live Camera type: USB driver: uvcvideo
bus-ID: 3-2:2
Device-4: FIFINE Microphones K670 Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 447.13 GiB used: 253.79 GiB (56.8%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
Partition:
ID-1: / size: 58.76 GiB used: 30.48 GiB (51.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 196.9 MiB used: 274 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 379.8 GiB used: 223.3 GiB (58.8%) fs: ext4
dev: /dev/sda3
Swap:
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile1
Sensors:
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1118
Info:
Processes: 366 Uptime: 3m Memory: 15.62 GiB used: 2.43 GiB (15.5%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1387
Shell: Zsh v: 5.8.1 inxi: 3.3.15
