Problema com Bluetooth no linux mint 21
Gente alguém ai ta tendo problema com o Bluetooth, ele desapareceu do painel do linux mint 21 e não abriu mais de forma alguma, nem pelo terminal.
Já tentei reinstalar, instalar várias outras opções pela loja e nada o máximo que consegui foi fazer ele iniciar uma vez, e depois de reiniciar o pc o mesmo erro ocorre.
Segue abaixo as informações do sistema
System:
  Kernel: 5.15.0-48-generic x86_64 bits: 64 Desktop: Cinnamon 5.4.12
    Distro: Linux Mint 21 Vanessa
Machine:
  Type: Desktop Mobo: ASRock model: A320M-HD serial: <superuser required>
    UEFI: American Megatrends v: P6.00 date: 08/03/2019
CPU:
  Info: quad core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
    type: MT MCP cache: L2: 2 MiB
  Speed (MHz): avg: 2447 min/max: 1400/3700 cores: 1: 2624 2: 1230 3: 3044
    4: 3012 5: 2304 6: 1230 7: 3063 8: 3072
Graphics:
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro
  450/455/460/555/555X/560/560X]
    driver: amdgpu v: kernel
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
  OpenGL: renderer: AMD Radeon RX 560 Series (polaris11 LLVM 13.0.1 DRM
    3.42 5.15.0-48-generic)
    v: 4.6 Mesa 22.0.5
Audio:
  Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
    driver: snd_hda_intel
  Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-48-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
    driver: btusb
  Report: hciconfig ID: hci0 rfk-id: 1 state: down
    bt-service: enabled,running rfk-block: hardware: no software: no
    address: <filter>
Drives:
  Local Storage: total: 521.66 GiB used: 46.31 GiB (8.9%)
  ID-1: /dev/sda vendor: Western Digital model: WDS240G2G0A-00JH30
  ID-2: /dev/sdb vendor: Samsung model: HD321HJ size: 298.09 GiB
Partition:
  ID-1: / size: 218.51 GiB used: 46.3 GiB (21.2%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 518.5 MiB (25.3%) file: /swapfile
Sensors:
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 341 Uptime: 8h 32m Memory: 7.69 GiB used: 3.54 GiB (46.1%)
  Shell: Bash inxi: 3.3.13
Olá @welbert321, tudo bem contigo?
O primeiro passo para conseguir te ajudar é fornecer mais informações sobre o seu hardware, basta seguir as dicas deste post.
Outro ponto importante é que o Linux Mint mudou seu gestor de bluetooth padrão na versão 21, então, se você estiver tentando forçar a instalação do Blueberry pode estar aí o seu problema.
Veja as informações dos posts que eu linkei, e tente instalar o gerenciador novo.
:vulcan_salute:
Na verdade eu cheguei a ver sobre a mudança do gestor de Bluetooth, mas ja cheguei a reinstalar somente ele e remover os demais que havia instalado pra tentar resolver o erro, e continua da mesma forma não abre. Editei a postagem com as info do meu hardware.
Existe a chance de ser alguma configuração do seu usuário que esteja afetando o serviço do bluetooth, sugiro que reinstale os pacotes oficias da distro e depois crie um usuário em branco, só para testar se dessa forma o bluetooth funciona corretamente.
:vulcan_salute:
