Problema com 8812au (talvez) no kernel 6.12.101
Pessoal, estou usando o MX Linux e atualmente estou no kernel 6.12.100+deb13-amd64, que está funcionando normalmente.
O problema é que o 6.12.101 está dando kernel panic no meu PC, então estou permanecendo no 6.12.100.
Durante uma atualização, porém, o DKMS tenta compilar o driver Wi-Fi 8812au/5.13.6 para o kernel 6.12.101 e apresenta alguns erros e não consigo utilizar este kernel.
o log;
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/rtw_roch.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-internal.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-internal-enc.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-gcm.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-ccm.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-omac1.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/ccmp.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/gcmp.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-siv.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/aes-ctr.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/sha256-internal.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/sha256.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/sha256-prf.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/crypto/rtw_crypto_wrap.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/core/rtw_swcrypto.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/osdep_service.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/os_intfs.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/usb_intf.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/usb_ops_linux.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/ioctl_linux.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/xmit_linux.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/mlme_linux.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/recv_linux.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/ioctl_cfg80211.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/rtw_cfgvendor.o
  CC [M]  /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/wifi_regd.o
/var/lib/dkms/8812au/5.13.6/build/os_dep/linux/ioctl_cfg80211.c:10529:32: error: initialization of ‘int (*)(struct wiphy *, struct net_device *, struct cfg80211_chan_def *)’ from incompatible pointer type ‘int (*)(struct wiphy *, struct cfg80211_chan_def *)’ [-Wincompatible-pointer-types]
10529 |         .set_monitor_channel = cfg80211_rtw_set_monitor_channel,
/var/lib/dkms/8812au/5.13.6/build/os_dep/linux/ioctl_cfg80211.c:10529:32: note: (near initialization for ‘rtw_cfg80211_ops.set_monitor_channel’)
make[3]: *** [/usr/src/linux-headers-6.12.101+deb13-common/scripts/Makefile.build:234: /var/lib/dkms/8812au/5.13.6/build/os_dep/linux/ioctl_cfg80211.o] Error 1
make[3]: ** Esperando que outros processos terminem.
make[2]: *** [/usr/src/linux-headers-6.12.101+deb13-common/Makefile:1992: /var/lib/dkms/8812au/5.13.6/build] Error 2
make[1]: *** [/usr/src/linux-headers-6.12.101+deb13-common/Makefile:236: __sub-make] Error 2
make[1]: Saindo do diretório '/usr/src/linux-headers-6.12.101+deb13-amd64'
make: *** [Makefile:2516: modules] Error 2
# exit code: 2
# elapsed time: 00:00:18
Dito isso, existe alguma correção para funcionar o kernel 6.12.101? Ou seria melhor simplesmente manter o 6.12.100 ?
Obrigado!
8812au parece não ser compatível.
Eu removia p kernel novo. E esperaria a próxima atualização
Então é melhor manter o que estou usando (6.12.100) para evitar kernel panic e remover o kernel que está dando problemas…? como posso remover ele de maneira segura e deixar por padrão no inicializador o 6.12.000?
Depois eu vejo.
Mas acho que a melhor opção é instalar o kernel lts.
Isso para qualquer distro.
Só é recomendado ao contrário se não tiver algum problema ou um drive novo no kernel atualizado.
Ué aqui no meu Fedora já tenho o Kernel 7.1.8, não fizestes os updates (atualizações) no MxLinux ?
Utilizo o MX Linux com a interface KDE Plasma… a versão AHS que disponibiliza o kernel mais recente, não utilizo o AHS.
