quando tento abrir uma maquina virtual no virtualbox ele aparece esse erro:
Kernel driver not installed (rc=-1908) The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please reinstall virtualbox-dkms package and load the kernel module by executing 'modprobe vboxdrv' as root. If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information. where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
sendo que durante a instalação havia aparecido esse erro:
virtualbox.service - LSB: VirtualBox Linux kernel module Loaded: loaded (/etc/init.d/virtualbox; generated) Active: failed (Result: exit-code) since Wed 2020-03-11 21:22:16 -04; 7ms ago Docs: man:systemd-sysv-generator(8) Process: 30238 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE) mar 11 21:22:16 jronca-300E5M-300E5L systemd[1]: Starting LSB: VirtualBox Linux kernel module... mar 11 21:22:16 jronca-300E5M-300E5L virtualbox[30238]: * Loading VirtualBox kernel modules... mar 11 21:22:16 jronca-300E5M-300E5L virtualbox[30238]: * modprobe vboxdrv failed. Please use 'dmesg' to find out why mar 11 21:22:16 jronca-300E5M-300E5L virtualbox[30238]: ...fail! mar 11 21:22:16 jronca-300E5M-300E5L systemd[1]: virtualbox.service: Control process exited, code=exited status=1 mar 11 21:22:16 jronca-300E5M-300E5L systemd[1]: virtualbox.service: Failed with result 'exit-code'. mar 11 21:22:16 jronca-300E5M-300E5L systemd[1]: Failed to start LSB: VirtualBox Linux kernel module.
e quando executo o comando ‘modprobe vboxdrv’ aparece o seguinte erro:
modprobe: ERROR: could not insert ‘vboxdrv’: Operation not permitted
alguém sabe como proceder nessa situação?
