@Rodrigo_Chile @Capezotte gente aconteceu de novo, dessa vez foi quando fui apagar um arquivo que baixei, cliquei na tecla delete no arquivo no thunar e os painéis sumiram! Tentei os comandos de vocês e não adiantou, entro no thunar e meus arquivos meio que sumiram!
e quando tento o comando xfce4-panel &
aparece isso:
(xfce4-panel:9216): Gtk-WARNING **: 23:17:09.003: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
Gtk:ERROR:…/…/…/…/gtk/gtkiconhelper.c:494:ensure_surface_for_gicon: assertion failed (error == NULL): Failed to load /home/steph/.icons/Tela-pink-dark/scalable/apps/image-missing.svg: Erro ao abrir arquivo /home/steph/.icons/Tela-pink-dark/scalable/apps/image-missing.svg: Arquivo ou diretório inexistente (g-io-error-quark, 1)
(wrapper-2.0:9220): xfce4-panel-wrapper-WARNING **: 23:17:09.052: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
(wrapper-2.0:9222): xfce4-panel-wrapper-WARNING **: 23:17:09.068: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
(wrapper-2.0:9222): Gdk-ERROR **: 23:17:09.225: The program ‘wrapper-2.0’ received an X Window System error.
This probably reflects a bug in the program.
The error was ‘BadWindow (invalid Window parameter)’.
(Details: serial 191 error_code 3 request_code 18 (core protocol) minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the GDK_SYNCHRONIZE environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
(wrapper-2.0:9220): Gdk-ERROR **: 23:17:09.246: The program ‘wrapper-2.0’ received an X Window System error.
(Details: serial 156 error_code 3 request_code 18 (core protocol) minor_code 0)
(wrapper-2.0:9227): xfce4-panel-wrapper-WARNING **: 23:17:09.317: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9227): xfce4-panel-wrapper-WARNING **: 23:17:09.320: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9223): xfce4-panel-wrapper-WARNING **: 23:17:09.321: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9223): xfce4-panel-wrapper-WARNING **: 23:17:09.323: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9223): xfce4-panel-wrapper-WARNING **: 23:17:09.325: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
** (wrapper-2.0:9229): WARNING **: 23:17:09.332: No outputs have backlight property
(wrapper-2.0:9224): xfce4-panel-wrapper-WARNING **: 23:17:09.381: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9234): xfce4-panel-wrapper-WARNING **: 23:17:09.387: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9224): xfce4-panel-wrapper-WARNING **: 23:17:09.388: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9229): xfce4-panel-wrapper-WARNING **: 23:17:09.400: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9225): xfce4-panel-wrapper-WARNING **: 23:17:09.410: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9225): GLib-GIO-CRITICAL **: 23:17:09.449: g_file_new_for_path: assertion ‘path != NULL’ failed
(wrapper-2.0:9225): GLib-GIO-CRITICAL **: 23:17:09.449: g_file_monitor_file: assertion ‘G_IS_FILE (file)’ failed
(wrapper-2.0:9225): GLib-GObject-WARNING **: 23:17:09.455: invalid (NULL) pointer instance
(wrapper-2.0:9225): GLib-GObject-CRITICAL **: 23:17:09.456: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(wrapper-2.0:9225): Gtk-WARNING **: 23:17:09.459: Attempting to add a widget with type GtkToggleButton to a container of type XfcePanelPlugin, but the widget is already inside a container of type XfcePanelPlugin, please remove the widget from its existing container first.
(wrapper-2.0:9225): xfce4-panel-wrapper-WARNING **: 23:17:09.460: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
(wrapper-2.0:9225): xfce4-panel-wrapper-WARNING **: 23:17:09.482: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
DockbarX 0.93
DockbarX init
(wrapper-2.0:9229): Gtk-WARNING **: 23:17:09.838: Could not load a pixbuf from icon theme.
(wrapper-2.0:9229): xfce4-panel-wrapper-WARNING **: 23:17:09.869: ProviderSignal call failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.167 was not provided by any .service files
DockbarX reload
Traceback (most recent call last):
File “/usr/share/xfce4/panel/plugins/xfce4-dockbarx-plug”, line 239, in
dbx = DockBarXFCEPlug()
File “/usr/share/xfce4/panel/plugins/xfce4-dockbarx-plug”, line 89, in init
self.dockbar.load()
File “/usr/lib/python2.7/dist-packages/dockbarx/dockbar.py”, line 552, in load
self.reload(tell_parent=False)
File “/usr/lib/python2.7/dist-packages/dockbarx/dockbar.py”, line 628, in reload
self.__on_window_opened(self.screen, window)
File “/usr/lib/python2.7/dist-packages/dockbarx/dockbar.py”, line 815, in __on_window_opened
self.__add_window(window)
File “/usr/lib/python2.7/dist-packages/dockbarx/dockbar.py”, line 988, in __add_window
window=window)
File “/usr/lib/python2.7/dist-packages/dockbarx/dockbar.py”, line 883, in __make_groupbutton
group = Group(self, identifier, desktop_entry, pinned)
File “/usr/lib/python2.7/dist-packages/dockbarx/groupbutton.py”, line 176, in init
self.button = GroupButton(self)
File “/usr/lib/python2.7/dist-packages/dockbarx/groupbutton.py”, line 1443, in init
self.drag_source_set_icon_pixbuf(self.icon_factory.get_icon(32))
File “/usr/lib/python2.7/dist-packages/dockbarx/iconfactory.py”, line 128, in get_icon
return self.__find_icon_pixbuf(size)
File “/usr/lib/python2.7/dist-packages/dockbarx/iconfactory.py”, line 534, in __find_icon_pixbuf
return self.icon_theme.load_icon(icon_name,size,0)
gio.Error: Erro ao abrir arquivo /home/steph/.icons/Tela-pink-dark/scalable/apps/firefox.svg: Arquivo ou diretório inexistente
steph@zorin-os:~$
