Então galera, o problema é o seguinte: quando tento tirar print de qualquer coisa, desde que eu não esteja no modo tela cheia tudo funciona perfeitamente, quando estou no modo tela cheia a foto sai simplesmente a resolução da minha tela em png com absolutamente nenhuma imagem, uma foto sem fundo:
Segue abaixo as informações do meu sistema, caso ajude
$ inxi -Fxz
System:
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME 3.38.1 Distro: Manjaro Linux
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2006 date: 11/13/2019
CPU:
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 81468
Speed: 1376 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 2166 2: 1279 3: 1547 4: 1547 5: 1272 6: 1378 7: 1546 8: 1547 9: 2115
10: 1326 11: 1324 12: 1416
Graphics:
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus ID: 08:00.0
Display: x11 server: X.org 1.20.9 driver: amdgpu,ati
unloaded: modesetting,radeon resolution: <xdpyinfo missing>
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.38.0
5.8.18-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Audio:
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.3
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 447.13 GiB used: 77.32 GiB (17.3%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
Partition:
ID-1: / size: 48.97 GiB used: 15.84 GiB (32.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 389.64 GiB used: 61.48 GiB (15.8%) fs: ext4
dev: /dev/sda3
Swap:
ID-1: swap-1 type: file size: 1024.0 MiB used: 0 KiB (0.0%)
file: /swapfile1
Sensors:
System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1083
Info:
Processes: 321 Uptime: 6h 22m Memory: 15.63 GiB used: 3.45 GiB (22.1%)
Init: systemd Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1129
Shell: Zsh v: 5.8 inxi: 3.1.08
