Instalei o CloudReady no pen drive bootvel mas não estou conseguindo instalar o sistema, na hora que eu vou apagar os dados dá erro e aparecem várias linhas de código
Olá @Paulo_Pessoa. Por um acaso você criou o boot pen drive usando a extensão do Chrome chamado “Chromebook Recovery Utility”?
não, como que faz?
[u'/usr/sbin/parted', u'--script', u'/dev/mmcblk0', u'mklabel', u'gpt']
failed. returncode:1
, output:Error: Input/output error during write on /dev/mmcblk0
, traceback:Traceback (most recent call last): File "/opt/neverware/auto_install.py", line 145, in reformat run_cmd(['/usr/sbin/parted', '--script', dest, 'mklabel', 'gpt']) File "/opt/neverware/auto_install.py", line 115, in run_cmd output = subprocess.check_output(cmd, stderr=subprocess.STDOUT) File "/usr/lib64/python2.7/subprocess.py", line 223, in check_output raise CalledProcessError(retcode, cmd, output=output) CalledProcessError: Command '['/usr/sbin/parted', '--script', '/dev/mmcblk0', 'mklabel', 'gpt']' returned non-zero exit status 1
[u'/usr/sbin/chromeos-install', u'--dst', u'/dev/mmcblk0', u'--yes', u'--skip_dst_removable', u'--target_bios', u'efi']
, output:initctl: Unknown instance: This will install from '/dev/sda' to '/dev/mmcblk0'. This will erase all data at this destination: /dev/mmcblk0 64+0 records in 64+0 records out 32768 bytes (33 kB, 32 KiB) copied, 0.0569145 s, 576 kB/s ERROR: I/O error when trying to write primary GPT
, traceback:Traceback (most recent call last): File "/opt/neverware/auto_install.py", line 256, in main install(dest) File "/opt/neverware/auto_install.py", line 214, in install run_chromeos_install(dest, is_efi) File "/opt/neverware/auto_install.py", line 165, in run_chromeos_install output = run_cmd(cmd) File "/opt/neverware/auto_install.py", line 115, in run_cmd output = subprocess.check_output(cmd, stderr=subprocess.STDOUT) File "/usr/lib64/python2.7/subprocess.py", line 223, in check_output raise CalledProcessError(retcode, cmd, output=output) CalledProcessError: Command '['/usr/sbin/chromeos-install', '--dst', '/dev/mmcblk0', '--yes', '--skip_dst_removable', '--target_bios', 'efi']' returned non-zero exit status 1
essas são as linhas de codigo que aparece
Entendo, certo, vamos lá! Primeiro, no Google Chrome você baixa e instala a extensão “Chromebook Recovery Utility” na loja web do Google. Vai aparecer uma pergunta “Add “Chromebook Recovery Utility”?”, Add App. Seguinte passo seria executar o app e vai aparecer “Criar uma Mídia Recuperável” em Inglês “Create a recovery media”, então no canto superior direito tem uma engrenagem, clica nela e clica em “usar imagem local” e seleciona a imagem do Cloudready, vai estar algo com .bin.zip. Plugue o pen drive no usb e selecione ele depois clique em “Continue”. Aguarde o procedimento completar e depois tentar instalar o Cloudready.
Seu pendrive bootável e seu HD estão com erros de leitura, façã uma formatação lenta nos dois e tente novamente
Já instalei o cloudready experimentalmente algumas vezes. Usava um Celeron J1800. Após algumas atualizações o sistema não instalava mais pois não tinha mais suporte. Confirmei fazendo um pendrive de versão antiga e instalando. Após atualizar parava de funcionar.
O pendrive pode ser feito com o Balena etcher. Você baixa a imagem para Mac os e abre no Balena gravando direto no pendrive.
Quando o pendrive inicia no PC tudo deverá funcionar, as vezes não funcionara a impressora ou adaptadores USB de wi-fi ,mas a placa de rede funciona por cabo. Não tem suporte a scanner. Cd-rom e DVD só funcionam em modo leitura.
Quando você clica em instalar todo o HD é formatado apagando tudo e instalando por cima particionando de um modo específico do cloudready que tem cerca de 30 partições em sistemas de arquivo diferentes e vários tamanhos.
Quando instalei retirei o SSD e coloquei um SSD de 120 GB e deixei instalar. Depois retirei este SSD e coloquei em um case e dava boot por ele e funcionou perfeitamente.
Então voltei a colocar o SSD com windows 10 e Linux mint na porta sata e fiquei com um sistema triboot: se iniciasse pelo case USB iniciava o cloudready , e se iniciasse pelo SSD interno podia selecionar entre o Windows 10 ou Linux. O problema é que quando reinstalei o Linux o grub sobrescreveu o grub do cloudready e este não funcionou mais. Se fizer isto desconecte o case USB ao reinstalar o Linux ou windows e selecione o boot do cloudready só na BIOS.
O sistema é fácil de usar , basicamente só um navegador Chrome e atalhos para Web apps e uma íntegracao perfeita com os serviços do Google , você faz login com um email do Google. O sistema é sólido.
Mas prefiro o Ubuntu ou Linux mint pois tem suporte a scanner e a mais dispositivos.
Isso tbm funciona com o Chrome os?
Chorme OS teria de pesquisar e testar, pois quem portabiliza o sistema para laptops, pcs X86_64 “non Chorme OS” é o Projeto Brunch, o CloudReady era um projeto próprio até a Google comprar ele.
Eu tô com um problema durante a inicialização, acredito que um pouco antes da instalação o (O BOOT INICIA NORMALMENTE ) notebook positivo c4500c não conecta wifi, como não possuo conector RJ-45 A instalação se torna inviável sem conexão—
SE ALGUÉM SOUBER DE ALGUMA SOLUÇÃO ALTERNATIVA EU AGRADEÇO
O Cloudready tem uma compatibilidade de hardware limitada . Costumava usar em um computador com soc j 1800 da Intel e o sistema rodava bem e era bem rápido, mas não reconhecia o dongle Wi-Fi USB nem o de Bluetooth. Conectava a internet pelo cabo de rede.
Ele conseguia imprimir em uma Hp 1115 e em outra 2136 ( que é uma multifuncional e não há suporte para escanear pelo cloudready) . Já uma Hp Ink tank 116 não funcionou. Com o tempo , após uma atualização, o vídeo passou a não funcionar bem e tive que abandonar a experimentação pois logo após parou de dar boot.
Sugiro a você comprar um dongle Wi-Fi USB em que na caixa esteja escrito que tenha compatibilidade com Linux pois terá uma chance de fazer funcionar. No mercado livre existem adaptadores RJ 45 para USB que podem funcionar também.
O Cloudready não tem suporte para hardware muito antigo nem muito novo , não tem suporte a scanner e outros equipamentos que o Linux suporta.
Atualmente uso só o Linux Mint Cinnamon que suporta todos estes hardware citados.
