Mesa Huion HS64 para de funcionar quando movo o mouse ou teclado
Pessoal, boa noite!
Tenho uma mesa digitalizadora Huion HS64 e quero utilizar no Pop Os 22.04.
Ela conectou sozinha quando conectei, mas sempre que eu mexo no mouse/teclado, ela para de funcionar. Tenho que desplugar e lugar pra volta… aí se encosto no mouse, ela para de novo…
o que pode ser? Já instalei o digimend-kernel-drivers
Resumo
System:
  Kernel: 5.18.10-76051810-generic x86_64 bits: 64 Desktop: GNOME 42.3.1
    Distro: Pop!_OS 22.04 LTS
Machine:
  Type: Desktop System: Gigabyte product: B450M DS3H V2 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B450M DS3H V2 v: x.x serial: <superuser required>
    UEFI: American Megatrends LLC. v: F62 date: 01/27/2022
CPU:
  Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP cache:
    L2: 3 MiB
  Speed (MHz): avg: 4021 min/max: 2200/4650 cores: 1: 4256 2: 4183 3: 3717
    4: 4237 5: 3422 6: 4140 7: 4174 8: 4196 9: 3781 10: 4212 11: 3830 12: 4104
Graphics:
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nvidia
    v: 515.48.07
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
    resolution: 1360x768~60Hz
  OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 515.48.07
Audio:
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
  Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
  Device-3: FIFINE 683 Microphone type: USB driver: snd-usb-audio
  Sound Server-1: ALSA v: k5.18.10-76051810-generic running: yes
  Sound Server-2: PipeWire v: 0.3.56 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp4s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
  IF: wlxf4ec38954637 state: up mac: <filter>
Drives:
  Local Storage: total: 238.47 GiB used: 64.38 GiB (27.0%)
  ID-1: /dev/sda vendor: TeamGroup model: T253X2256G size: 238.47 GiB
Partition:
  ID-1: / size: 225.32 GiB used: 60.83 GiB (27.0%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 497 MiB used: 247.7 MiB (49.8%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 4 GiB used: 3.2 MiB (0.1%)
    dev: /dev/dm-0
Sensors:
  System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: nvidia temp: 58 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Info:
  Processes: 422 Uptime: 5h 32m Memory: 15.55 GiB used: 5.36 GiB (34.5%)
  Shell: Bash inxi: 3.3.13
EDIT—
Descobri que a Huion lançou drives oficiais para linux!
Baixei e instalei, mas o app não reconhece a mesa e continua o problema…
Milagrosamente começou a funcionar normal… tinha desistido ontem, aí hoje fui tentar de novo e deu bom…
Este tópico foi fechado automaticamente 7 dias depois da última resposta. Novas respostas não são mais permitidas.
