Luz do teclado não funciona
Boa noite,
Não consigo ativar o led do teclado quando pressiono a tecla “Scroll Lock”.
Dados da máquina:
System:
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 Desktop: KDE Plasma
    v: 5.24.3 Distro: Manjaro Linux
Machine:
  Type: Desktop Mobo: Colorful And Development model: H510M-T M.2 v: V20
    serial: <superuser required> UEFI: American Megatrends LLC. v: 5.19
    date: 08/19/2021
CPU:
  Info: quad core model: Intel Core i3-10105F bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 2479 min/max: 800/4400 cores: 1: 2922 2: 1223 3: 3667
    4: 3699 5: 2106 6: 3302 7: 1117 8: 1803
Graphics:
  Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
    driver: amdgpu v: kernel
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
    gpu: amdgpu resolution: 1360x768
  OpenGL: renderer: AMD Radeon RX 550 / 550 Series (POLARIS12 DRM 3.42.0
    5.15.28-1-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.7
Audio:
  Device-1: Intel driver: snd_hda_intel
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-2: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 1.13 TiB used: 39.77 GiB (3.4%)
  ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
  ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
Partition:
  ID-1: / size: 40.55 GiB used: 10.68 GiB (26.3%) fs: ext4 dev: /dev/sdb7
  ID-2: /boot/efi size: 511 MiB used: 292 KiB (0.1%) fs: vfat
    dev: /dev/sdb6
  ID-3: /home size: 226.81 GiB used: 5.13 GiB (2.3%) fs: ext4
    dev: /dev/sda4
Swap:
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sdb5
Sensors:
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 263 Uptime: 4m Memory: 15.5 GiB used: 1.73 GiB (11.2%)
  Shell: Zsh inxi: 3.3.14
https://wiki.archlinux.org/title/keyboard_backlight
Aqui em pt-br
https://wiki.archlinux.org/title/Keyboard_backlight_(Português)
É mencionado o diretório /sys/class/leds/tpacpi::kbd_backlight
Porém não tenho isso e nem consigo criar um
Num teclado “”“gamer”"" que eu tenho aqui em casa, xset led 3 faz o serviço (apesar de que, conforme indica o artigo, pode ser necessário testar os vários números entre 1 e 32).
Instalou o pacote?
https://archlinux.org/packages/?name=brightnessctl
Testei todos os números e não deu certo
Instalei e funcionou mas tive que alterar o comando mencionado no wiki de:
brightnessctl --device='tpacpi::kbd_backlight' set 1
Para:
brightnessctl --device='input23::scrolllock' set 1
Descobri que esse era o dispositivo com esse comando:
Obrigado pela ajuda!
